Interactive file naming for naming multiple files in fortran90
The discussion focuses on generating multiple files in Fortran90 with names based on a loop variable. The user seeks a method to create files named sequentially (e.g., name1.txt, name2.txt, ..., name11.txt) using a loop. A solution is provided that utilizes internal file writing to convert integers to strings, allowing dynamic file naming. The example code demonstrates how to implement this functionality effectively in Fortran90.
  • Understanding of Fortran90 syntax and file handling
  • Familiarity with internal file operations in Fortran
  • Basic knowledge of string manipulation in programming
  • Experience with loops and control structures in Fortran
  • Explore Fortran90 file I/O operations in detail
  • Learn about string manipulation techniques in Fortran90
  • Investigate the use of internal files for data conversion in Fortran
  • Review best practices for dynamic file naming in programming
Fortran developers, educators teaching Fortran programming, and anyone looking to automate file creation based on variable values in Fortran90.
dealove
I am looking for a way to create the files with names name according to value of variable in a loop.
For example (not actual code):
do i=1,11
open(10,file=name 'i'//".txt")
enddo
where 11 files with names: name1.txt, name2.txt...name11.txt will be created with the content.
Do you have any suggestion/code? I wrote it in C but, could not find some functions needed in fortran. Here is my C code:
#include
#include
#include
void int2str(int test, char *temp);
void main()
int i;
char str[15] = "temp\\name";
char filename[20], temp[10];
FILE *fptr;
int test = 355;
//clrscr();
for(i=1;i<11;i++)
strcpy(filename,str);
int2str(i, temp);
strcat(filename,temp);
strcat(filename,".txt");
fptr = fopen(filename,"w");
fprintf(fptr,"%s",filename);
fclose(fptr);
}void int2str(int test, char temp[10])
int k,i=0;
while(test > 0)
k = test % 10;
test = test/10;
temp = (char)(k + 48);
i++;
temp = '\0';
strrev(temp);
Technology news on Phys.org
I think your problem is how to convert a number to a string in fortran. It can be done by using
internal files:
write(str,fmt=*) i
where i is the number and str the string.
I hope this can help you further.
that works, with little modification.
program int2str
character(40) :: numchr
integer j,n
n=2
do j = 1,n
write(numchr,*) j
open (10, file = "foo" // trim(adjustl(numchr)) // ".dat")
enddo
end
  • · Replies 32 ·
  • · Replies 89 ·
  • · Replies 75 ·
