Chirality vs Helicity: Explaining the Difference
  • Context: Graduate
  • Thread starter Thread starter gremezd
    Chirality Helicity
The discussion revolves around the distinction between chirality and helicity in the context of particle physics, particularly focusing on their definitions, implications for massive and massless particles, and their roles in interactions like the weak force. Participants explore theoretical concepts and practical measurements related to these properties.
  • Some participants define helicity as the projection of spin along the momentum direction, while chirality relates to the transformation laws and representations of the Lorentz group.
  • It is noted that for massless particles, helicity and chirality can be considered identical, but for massive particles, helicity can change under Lorentz boosts.
  • One participant questions how to determine the chirality of a massive electron, given that it has both left-handed and right-handed components in its Dirac spinor.
  • Another participant suggests that measuring deflection in an inhomogeneous magnetic field (Stern-Gerlach experiment) could help determine chirality.
  • There is a discussion about whether chirality is an intrinsic property of an electron that cannot change or if it can vary depending on interactions, particularly in weak interactions where left-handed chirality is emphasized.
  • One participant uses an analogy of a naturally right-handed person who sometimes bats left-handed to illustrate the concept of chirality versus helicity.
  • Chirality is described as being associated with the weak interaction, while helicity pertains to the spin angular momentum in the direction of momentum.
Participants express varying interpretations of chirality and helicity, with some agreeing on their definitions and roles in particle interactions, while others raise questions about the nature of chirality in massive particles. The discussion remains unresolved regarding the intrinsic nature of chirality and its dependence on interactions.
Participants mention the historical context of the terms and their definitions, indicating that the meanings of chirality and helicity have evolved over time, particularly in relation to weak interactions.
gremezd
What is the difference between chirality and helicity? I know, that helicity shows the handedness of the particle. For example, we have a right-handed electron if its spin is aligned in the direction of its propagation. The concept of chirality is a bit similar to that of helicity, but something more abstract, I guess. Could maybe anyone explain what the chirality is and tell its difference from helicity?
Helicity is the projection of the spin on the momentum direction. Chirality refers to the transformation laws, or the representation of the Lorentz group the particle belongs to. If a particle is massless, the situation is simple : helicity can only take the two extreme +S and -S, and all observer agree on that. Therefore, helicity and chirality can be considered identical in the massless case. But for a massive particle, a Loretz boost can switch helicity. On the wiki page, they call helicity the "apparent chirality" in that case, which seems appropriate to me.
OK. Let's think of a massive electron. As long as it cannot propagate with the speed of light, it cannot have definite helicity, as we can boost to the other frame, where our electron's helicity would change. But again, as long as our electron is massive, it will have both parts, the left-handed and right-handed, of the Dirac spinor. So, how can we decide if our electron is of right-handed chirality or that of left-handed?
I suppose by measuring its deflection in an inhomogenous magnetic field...? ( AKA, Stern Gerlach).
As you point out, an electron can be given any helicity by boosting.
Chirality refers to the natural handedness a particle takes in the weak interaction.
For an electron this is left handed corresponding the the V-A interaction.
In etymology, the two words mean just about the same thing.
In 1957, the Physical Review made a decision after some discussion which word would mean which physical concept.
Clem, do you mean that the value of chirality (left-handed or right-handed) is "god given" to a particular electron and cannot change in its lifetime? Or, as you say, depending on interaction, all electrons are left-handed or all right-handed? (I just try to create some image of what chirality is in my mind, as I meet this word quite often and cannot grasp it decently..)
Think of it like a naturally right-handed person who bats left handed sometimes.
If baseball doesn't help, consider that "left-handed" has two different meanings for an electron.
Chirality was coined to describe how it naturally entered the weak interaction.
Helicity was used to describe its spin angular momentum ion the direction of its momentum.
11K
10K
