What is the maximum load capacity for my fabricated bracket?
The discussion revolves around determining the maximum load capacity of a fabricated bracket intended to support approximately 1000 kg. Participants explore the design considerations, calculations, and potential failure implications related to the bracket's load-bearing capabilities.
  • The original poster (OP) seeks guidance on calculations or formulas to determine the maximum load the bracket can support.
  • One participant suggests understanding the functionality of the bracket and identifying the weakest link in the design, emphasizing the role of linear bearings in load distribution.
  • Concerns are raised about the implications of bracket failure, including potential hazards from a significant load falling.
  • Another participant questions the type and specifications of the linear bearings being used, particularly their ability to handle various forces.
Participants have not reached a consensus on the calculations needed or the design considerations for the bracket. Multiple viewpoints on the structural integrity and safety implications remain present.
There are unresolved assumptions regarding the specific calculations required, the design of the bracket, and the characteristics of the linear bearings. The discussion does not clarify the exact parameters for load calculations.
Individuals interested in mechanical design, load analysis, or those working with fabricated structures may find this discussion relevant.
DJT1967
Hi Guys I hope you can help. I’m currently trying to modify some existing equipment and have a problem that I hope you good people can help me solve. I have a fabricated bracket that currently supports another bracket than runs on linear bearings to position its self.
see attached JPG for rough layout.
We would like the existing bracket to support a load of approximately 1000kgs and after doing some research and found some calculations that would appear to be roughly what I need but I’m not sure.
I was wondering if anyone here would be so kind as to point me in the right direction as to what calculation / formula I would need to calculate the maximum load the bracket will take.
Thanks in advance for your help.
I think it best to first understand the functionality, then look for the weakest link in the design.
The sliding bracket will rotate clockwise due to the eccentrically applied load. The outer (RHS) linear bearing will carry all the load, plus the negative load on the inner (LHS) linear bearing.
A 20 mm thick, 700 mm wide shelf supports the linear bearings. That shelf should be narrower so the outer (RHS) linear bearing that carries the load, can be closer to the vertical support structure.
If the purpose of the inner (LHS) linear bearing is to maintain the orientation of the sliding bracket, then consider mounting one linear bearing above the other so you can get both bearings to carry the load, and move the vertical force much closer to the vertical support structure.
You might consider mounting the shelf on edge as it will support the load better in that orientation.
What type of linear bearings are you considering? Make and model?
Can they take sideways or lifting forces as great as the vertical force?
That's a pretty significant load. What would happen if the bracket fails? How far can the load fall, and what kinds of things are underneath this assembly?
Oh duh, never mind. The OP is from 2008. o0)
