I with this finding a centroid of a triangle
  • Thread starter Thread starter rock.freak667
    Centroid Triangle
The centroid of a triangle can be calculated using the equations \(\overline{x}= \frac{\int x dA}{\int dA}\) and \(\overline{y}=\frac{\int y dA}{\int dA}\). The area of a small rectangular element is defined as \(\delta A=y \delta x\), and the total area is obtained by integrating from 0 to b. The x-coordinate of the centroid is derived from the integral \(\overline{x}=\frac{\int_0 ^b \frac{h}{b}x^2}{\int_0 ^b \frac{h}{b}x}\). The discussion highlights the need for clarity in identifying the specific triangle being analyzed to accurately compute the centroid.
  • Understanding of integral calculus
  • Familiarity with the concept of centroids in geometry
  • Knowledge of LaTeX for mathematical expressions
  • Ability to visualize geometric shapes and their properties
  • Study the derivation of centroids for various geometric shapes
  • Learn about the application of integrals in calculating areas
  • Explore LaTeX formatting for mathematical equations
  • Investigate the properties of triangles and their centroid locations
Students in mathematics or engineering fields, educators teaching geometry, and anyone interested in understanding the mathematical principles behind finding centroids of geometric shapes.
rock.freak667
Homework Helper
Well I just need to understand how to find the centroid of a triangle, I know it's 2/3 from the vertex, but I need to know how finding it is done.
[tex]\overline{x}= \frac{\int x dA}{\int dA}[/tex]
[tex]\overline{y}=\frac{\int y dA}{\int dA}[/tex]
Firstly I drew a triangle using the equation y=hx/b.
Then I considered a small rectangular element, whose height is and width is [itex]\delta x[/itex].
the area of this element is
The Area of this small element is [itex]\delta A=y \delta x[/itex]
Now the sum of all the infinitesmal areas is given by
[tex]dA=\sum_{x=0}^{x=b} y \delta x[/tex]
as [itex]\delta x \rightarrow 0[/itex]
[tex]\int dA=\int_0 ^b y dx[/tex]
[tex]dA=\sum_{x=0} ^{x=b} y \delta x[/tex]
So the x-coordinate of the centroid is
[tex]\overline{x}=\frac{\int_0 ^b \frac{h}{b}x^2}{\int_0 ^b \frac{h}{b}x}[/tex]
This is correct so far I assume, but what I do not understand is how to get the y-coordinate which should be the same answer.
EDIT: If my latex is wrong, I will type it over, so far the preview is only showing latex which I have typed for previous questions and not what I actually typed in the post, yet when I post the message it says my latex code is invalid.
I think everyone's latex is failing tonight. Must have to do with the server migration. Let's just try this again later.
The centroid of a triangle is simply the average of its three points. I searched through the code for your LaTex but I could find nowhere that you actually state what triangle you are talking about!
