W= -262.5 kg*m Sol'n: Calculate Force & Work of 5kg Sack Lifted 15m at 3.5 m/s
  • Thread starter Thread starter Jim4592
    Work
The discussion centers on calculating the force and work done when lifting a 5 kg sack of flour vertically at a constant speed of 3.5 m/s through a height of 15 m. The required lifting force is determined to be 49 N, counteracting the weight of the sack due to gravity. The work done on the sack by the lifting force is calculated as 735 J, while the work done by gravity is -735 J, indicating that the lifting force and displacement are in opposite directions. The key takeaway is that the net force must be zero for constant speed, necessitating an equal and opposite lifting force.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of work-energy principles (W=F*S*Cos(Θ))
  • Familiarity with gravitational acceleration (9.8 m/s²)
  • Basic concepts of force and displacement in physics
  • Study the implications of constant speed on net force in physics
  • Explore the relationship between force, work, and energy in mechanical systems
  • Learn about the concept of positive and negative work in physics
  • Investigate real-world applications of lifting forces and work calculations
Students in physics, educators teaching mechanics, and anyone interested in understanding the principles of force and work in lifting scenarios.
Jim4592
A 5.00 kg sack of flour is lifted vertically at a constant speed of 3.50 m/s through a height of 15.0 m.
a) How great a force is required?
b) How much work is done on the sack by the lifting force?
c) What becomes of this work?
Originally i assumed that acceleration at constant speed is the same as the speed, but then i realized that acceleration at constant speed is zero.
F=ma
F=5.00kg * 3.50 m/s
F = 17.5 kg * m/s
so when you include zero in the equation you get that there is no force?
But there has to be some force in order to calculate work
W=F*S*Cos(Θ)
W=F*(15.0m)*Cos(180) ; it would be 180 since its being lifted vertically correct?
I think i figured it out right after i typed it... would you use gravity acceleration?
F = 5 kg * -9.8 m/s
F = -49 kg m/s
W = -49 kg m/s * 15.0m * cos(180)
W = 735 J
Does that seem correct?
F = 5 kg * -9.8 m/s
F = -49 kg m/s
W = 735 J
You have the correct answer for the work, but your reasoning is a bit off. Since the object weighs 49N acting down (a kg m/s^2 is a Newton, by definition; the acceleration of gravity is 9.8 m/s^2 down), then in order for there to be no acceleration (constant speed implies no acceleration), the lifting force must be 49N up, (to give a net force of 0). The work done by that force is positive, since the displacement and lifting force are in the same direction. You seem to be calculating the work done by gravity, which is -735J (gravity acts down, displacement is up, so work done by gravity is negative.
