Electric force between 2 parallel plates
The problem involves an electron projected with an initial velocity and its interaction with an electric field between two parallel plates. Participants are tasked with determining the speed of the electron as it emerges from the field, while grappling with the need to understand the electric field's magnitude.
  • Participants discuss using kinematic equations to find the final velocity, with some suggesting that the acceleration can be derived from the electron's trajectory. Others express uncertainty about how to calculate the electric field's magnitude and question the necessity of knowing it.
The discussion is active, with various participants offering insights on how to approach the problem without directly calculating the electric field. Some have successfully navigated the problem, while others continue to seek clarification on specific calculations, such as time taken for the electron to reach the end of the plates.
There is a noted confusion regarding the equations used for time calculation and the relationship between distance, velocity, and acceleration. Participants are also navigating the constraints of the problem, particularly the need for the electric field's magnitude to apply certain equations.
Oblivion77
An electron is projected with an initial velocity of 1.6x10[tex]^{6}[/tex] m/s. If the electron just misses the upper plate as it emerges from the field, find the speed of the electron as it emerges from the field?
Electric force equation
I am stuck trying to figure out the magnitude of the electric field, once I can figure this out I know how to solve the problem. Any pointers on how to find the magnitude of the electric field?
Use ordinary kinematic means to determine the velocity.
You know the speed, hence how long for it to emerge.
In that time you also know the deflection so you can determine the acceleration.
That acceleration then yields the additional sideways component of velocity to calculate it's speed at that point right?
You don't need to know the magnitude of the electric field.
I was planning to use Vf^2 = Vo^2 +2ad to find the final velocity, but I am missing the acceleration component. To find the acceleration I wanted to use F = ma (knowing the mass of the electron). But I would need the magnitude of the electric field to find the force from E = F / q.
So how would I do this without using the electric field? I don't know what you mean about using the "deflection" to find the acceleration. How would I calculate that?
The horizontal velocity to the end of the plate gives you time.
Use the distance, acceleration, time relationship to determine acceleration.
Then you can use your V2, acceleration and distance.
Thanks for the advice, but this does not work. I get the answer wrong, the magnitude of the electric field is 364N/C, I am just not sure how to find it. When I use this electric field with the method I stated above I get the right answer. I just can't figure out how they got 364N/C :(
Once you determine the acceleration from the trajectory, then you can use f = ma to determine field intensity.
They ask really though for just the speed.
That equals (Vx2 +Vy2)1/2
Yes! Thank you so much, I figured it out now =)
I wondered if that wasn't it.
Glad you got it.
Good luck.
Please will someone explain how I am meant to calculate the time taken for the electron to reach the end of the plates. I'm just not getting it.
you have the horizontal distance and the velocity in x-direction is constant, so t = v / s
oh dear. that was rather dense of me. thank you! :)
You're welcome ^^
Sorry, I'm not getting the right answer..not sure where I'm going wrong..should it not be t=s/v because t=v/s yields an answer of 80,000,000
To check if an equation makes sense, look at the units. t = v/s → (m/s)/s = m/s^2; these are units of acceleration, not time, so this equation makes no sense.
Since v = s/t, t = s/v is correct. The units would be m/(m/s) = m(s/m) = s. Makes sense.
oh sorry, it's my mistake
it should be t = s/v
thank you :)
You're welcome
sorry for the mistake earlier ^^
  • · Replies 58 ·
  • · Replies 20 ·
