Finding Current in a Delta Transformation Circuit
The discussion focuses on solving a circuit problem involving a delta transformation to find the current over a 1-ohm resistor. The user successfully calculated the equivalent resistance and total current, ultimately determining the current through the 1-ohm resistor to be I = 0.1904 A. A suggestion was made to utilize Kirchhoff's Current Law (KCL) for a more straightforward solution approach. The transformation between T-form and delta-form circuits was a key aspect of the problem-solving process.
  • Understanding of delta and T-form circuit transformations
  • Familiarity with Kirchhoff's Current Law (KCL)
  • Basic knowledge of equivalent resistance calculations
  • Ability to analyze electrical circuits
  • Study delta and T-form circuit transformations in detail
  • Learn how to apply Kirchhoff's Current Law (KCL) in circuit analysis
  • Explore techniques for calculating equivalent resistance in complex circuits
  • Practice solving circuit problems involving multiple resistors and configurations
Students studying electrical engineering, circuit designers, and anyone looking to enhance their skills in circuit analysis and transformations.
danilo_rj
http://i634.photobucket.com/albums/uu67/danilorj/circuito.jpg
Above is the picture of the circuit I'm trying to solve. The problem asks to find the current over the resistor of 1 ohm.
Well, I found the equivalent resistance of the circuit and thus the total current. But to do this, I transformed the T-form of the circuit between the resistors 70,1 and 20 ohms in a delta-transformation. My doubt is when I know the current in each branch of the delta-form how am I suppose to find the current in each branch of the t-form? What is the relation of current between them?
Welcome to the PF, danilo. Wouldn't it be easier to just solve the circuit using Kirchoff's Current Law (KCL) equations? That would be my first approach.
That's a nice idea, I haven't thought that. Well, I found the current over the resistor of 1 ohm as being I = 0.1904 A. I would appreciate If you could check this answer for me.
