Car fuel efficiency/throttle position?
  • Thread starter Thread starter QuantumPion
    Car Fuel Position
Driving for higher fuel efficiency involves maintaining a balance between throttle position and engine RPM. The optimal method is to accelerate with the throttle slightly open while delaying upshifting until reaching higher RPMs, ideally around 35% of redline and 80% of maximum torque. Manual transmissions are generally more efficient than automatics, with shifting at 2000 to 2200 RPM being recommended for better fuel economy. Additionally, keeping tires inflated, using synthetic oil, and maintaining a clean air filter can further enhance fuel efficiency. Overall, driving smoothly and in the appropriate gear is crucial for maximizing miles per gallon.
QuantumPion
Which method of driving results in higher fuel efficiency? a) accelerating with the throttle only slightly open and delaying upshifting until high engine RPM or b) accelerating with the throttle full open (pedal to the metal) but at low engine RPM/upshifting early?
The best engine efficiency based on BSFC (brake specific fuel consumption) maps is to run at about 35% of redline RPM and about 80% of maxumum torque (wide open throttle). I typically shift up (manual transmission) at about 2000 to 2200 RPM unless I need more acceleration. In the city, where you usually need no more than about 10 HP, I keep the RPM between 1500 and 2000 RPM, and usually get into 5th gear about 30 mph. The manual transmission is about 96% efficient, except in 4th gear which is about 98%. An automatic is typically only about 85% efficient,
The actual numbers are Dependant on the size of the engine.
Basically go as slow as possible in as high a gear as possible
regardless of the induction system, carb, direct port , throttle body..ifin you want to save MPG, drive it like you got an egg between the go pedal and yer foot!
better yet, switch to synthetic oil once the engine is broke in,
keep the tires inflated , max end of the recommended PSI, on 1990 and newer cars keep all windows UP..the old myth of no air conditioner and open the windows is not applicable to todays cars..max MPG requires mucho AERO and windows up gives max MPG, opening a window on new models severley impacts MPG
replace spark plugs after 30000 miles
go to Iridium spark plugs.. $ 8 each but require 5000 volts less to light
check and clean air filter regularly
light is better so take all those old empties out of the car
want to experiment a little
keep the car waxed..slick is better..ok maybe yields .1 more mpg but hey..it all helps
No. Driving in too high a gear will require more fuel than driving in a lower gear around the BSFC peak.
Correct. If that means changing down a gear and using less throttle, do it.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
22K
62K
