Could Weak Gravity Be Explained by Long-Wavelength Gravitons from Unruh Effect?
  • Context: Graduate
  • Thread starter Thread starter Dmitry67
    Gravitons
The discussion revolves around the potential explanation of weak gravity through the lens of long-wavelength gravitons as suggested by the Unruh effect. Participants explore the implications of the Unruh effect on particle existence in different frames and how this might relate to gravitational phenomena, particularly in the context of Earth’s gravity.
  • Some participants propose that weak gravity could be explained by long-wavelength gravitons, drawing parallels to the Unruh effect where particles exist in an accelerating frame but not in an inertial frame.
  • Others argue that the analogy with the Unruh effect raises questions about the nature of existence in different frames, suggesting that the idea might seem strange or counterintuitive.
  • A participant mentions that the Unruh effect is difficult to observe under normal conditions and that the effect for gravitons is significantly smaller than required to account for observed gravity.
  • There is a suggestion that the weakness of gravity might not stem from extra dimensions but rather from the small cross-section of long-wavelength gravitons.
  • Some participants express uncertainty about the implications of virtual particles in inertial frames and how they relate to observable phenomena, particularly in the context of melting a rock due to Unruh radiation.
  • One participant acknowledges a quantitative error in reasoning regarding the Unruh effect's contribution to gravity, admitting that the effect is much smaller than necessary.
Participants express a mix of agreement and disagreement. While some acknowledge the intriguing nature of the proposed ideas, others challenge the validity of the reasoning and calculations presented. The discussion remains unresolved regarding the relationship between the Unruh effect and the nature of gravity.
Participants note limitations in the applicability of the Unruh effect to gravitational phenomena, particularly regarding the scale of accelerations required for observable effects and the assumptions made about particle interactions in different frames.
Dmitry67
An interesting property of the Unruh effect is that the very existence of particles depends on a frame. Unruh particles exist in the accelerating frame but not in an inertial frame.
I think exactly the same is applicable to the gravitons for obvious reasons. So inertial pseudo-forces can be explained by the gravitons emitted from the horizon by Hawking process.
However the Unruh effect can be detected only on extremely high accelerations - 10^26 m/s², while for gravitons the effect is obvious for our real life accelerations.
My question is, is it logical to assume that weak (Earth) gravity comes from a very 'cold', long-wavelength gravitons (based on the temperature in Unruh formula)? If so, the relative 'weakness' of the gravity (in comparison with the other forces) can be not a result of an 'extra dimensions', but rather a very small cross-section because gravitons are very long wavelength?
I find the remark concerning the cross section absolutely pertinent and it fits into the essay that I try to develop (classical string theory describing a vacuum state).
A contrario, the fact that particles could exist (be detectable) in some frames -but not in all- is an analogy with the accepted representation we have from EM phenomenon. I ignore if it fits with an observable reality and I would because of that ignorance personaly take some distance with that idea. Indeed, if it would apply, then you could exist for your family but not for me, only because I would have an appropriate acceleration relatively to you... that sounds strange, dosn't it?
But if you know more about this, please tell me, I find it very fascinating...
Best regards
Best regards
At first it puzzled me too: I asked myself, say, we accelerate a rock and it melts from the Unruh radiation (in the rock''s frame). But how the same is explained in the inertial frame, where there is no radiation at all?
But then I read this:
Experimental Observation of the Unruh effect
Under experimentally achievable conditions for gravitational systems this effect would be too small to be observed. In 2005 [8] it was shown that if one takes an accelerated observer to be an electron circularly orbiting in a constant external magnetic field, then the experimentally verified Sokolov-Ternov effect coincides with the Unruh effect.
Of course, all charged particles in the rock accelerate and emit the radiation. So what we see as Unruh radiation in rocks frame are virtual particles in the inertial frame. These virtual particles produce the corrections to the emission which leads to heating.
So in any case observers always agree on the microscopic events (but not on the exact particle contents of these events!)
Returing to the subject, the Earth gravity is equivalent to Unruh temperature of 4*10^-20K, hence wavelength of about 6 parsecs.
Interesting idea...I like the concept but have not read anything confirming it it more detail.
"...So what we see as Unruh radiation in rocks frame are virtual particles in the inertial frame...So in any case observers always agree on the microscopic events (but not on the exact particle contents of these events!)"
I don't understand...can you explain a bit?? Also very interesting.
It is an only possibility I see.
1. All observers must agree on the macroscopic events. Otherwise it is really weird.
2. In the rocks frame the front of the rock melts from the Unruh radiation.
3. In the inertial frame hence the result (front of the rock melted) must be the same.
4. However, in the inertial frame there are no real particles hitting the rock, just virtual ones.
5. Hence the only possibility is to assume that the interaction of the accelerating particles (rock) with the virtual ones had caused the melting.
The detailed explanation must be extremely difficult because particles and object can ot just accelerate on their free will: they must be pushed from behind or accelerate in other fields. So we are talking about the multi-particle systems.
Lets say the rock is cooled to near 0K and has already adapted to the acceleration (contracted and in stationary mode so there are no sonic waves inside from the initial 'push'). Even it is cooled to 0K, atoms are making the zero point energy movements. However, as rock is accelerating, such movements become asymmetric on the surface, converting the energy of the acceleration into the heat. This is raw idea how it can be explained in the inertial frame.
Your reasoning is circular. Essentially, you suggest that we observe gravity because there are gravitons created by our acceleration. But what is acceleration, if there was no gravity (i.e., a background metric with respect to which non-geodesic motion can be defined) at the first place?
In addition, your reasoning is quantitatively wrong. It is true that the Unruh effect predicts creation of gravitons seen by accelerated observers, but this effect is very small just as for all other massless particles. This is actually a PROOF that the observed gravity is NOT a consequence of the Unruh effect.
Hm, I have to admit that you're right, based on my calculations the effect is at least by 16 orders lower then needed :( Unless gravitons are renerated more effectively by Unruh effect by some reason.
Have you noticed that you and me allways come very soon to an agreement, except when we discuss the MWI vs BM issue? :smile:
  • · Replies 21 ·
  • · Replies 264 ·
25K
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 26 ·
