How Are Different Triaxial Tests Applied in Soil Mechanics for Design Purposes?
  • Thread starter Thread starter wkh023002
    Soil Test
The discussion focuses on the application of different triaxial tests in soil mechanics, specifically the Unconsolidated Undrained (UU), Consolidated Undrained (CU), and Consolidated Drained (CD) tests. The CD test is particularly emphasized for its relevance in design scenarios involving clay soils, especially during conditions like sudden drawdown in earth dam construction. Participants express confusion regarding the use of CD tests for clay, highlighting the importance of understanding drainage characteristics and field condition simulations in selecting the appropriate test.
  • Understanding of triaxial test types: UU, CU, and CD tests
  • Knowledge of soil permeability and drainage behavior
  • Familiarity with shear strength parameters in soil mechanics
  • Concept of field condition simulation in geotechnical engineering
  • Research the differences between UU, CU, and CD triaxial tests
  • Study the impact of soil permeability on drainage and shear strength
  • Explore case studies involving sudden drawdown in earth dam construction
  • Learn about the application of shear strength parameters in soil design
Geotechnical engineers, civil engineers, and students studying soil mechanics who seek to understand the practical applications of triaxial tests in design scenarios.
wkh023002
Soil mechanics--Triaxial test
Generally, the triaxial tests can be classified as three types, i.e., UU, CU, and CD tests. The type of test to be adopted depends on how best we can simulate the field conditions. In other words, the purpose of carrying out a particular test is to simulate field conditions as far as possible. For example, because of the high permeability of sand, consolidation occurs relatively rapidly and is usually completed during the application of the load. Shear strength parameters from CD tests are therefore generally used in design. Consider the following two cases:
a) In what situations, results from CD tests for a clay soil can be used in design.
b) A Earth dam is to be constructed. The soil on the site is clay. The initial water level is at the ground surface. During the construction, the water level has to be lowered in a short time, so that construction can proceed. This condition is commonly known as “sudden drawdown”. What type of triaxial tests would you recommend to carry out, and why?
I don't know why Consolidated Drained test can be used to test clay. Clay is impermeable and drainage can take very long time to complete. Any situation would allow this happen?
As for b), i think CD test should be used. Since it drainage allows fast drawdown.
but I am not sure if it is correct.
Actually, I am poor at soil mechanics. I would like to seek your help on this question
I am always confused with the abstract concepts!
Thanks!
Replying so that this thread isn't a no-reply, as per Greg's wishes.
If anyone has knowledge on this subject, feel free to reply.
Clay is not a consolidated rock (at least not saturated clay), so, in my judgment, a consolidated drain test would not be appropriate.
  • · Replies 41 ·
