Connecting car alternators in parallel
  • Thread starter Thread starter agabrielauto
    Car Parallel
The discussion revolves around the feasibility and implications of connecting multiple car alternators in parallel to increase power output for recharging a battery pack, specifically targeting a requirement of 5.5 kW. Participants explore various configurations, potential issues, and safety concerns related to this approach.
  • Some participants express concern that connecting alternators in parallel could lead to synchronization issues due to their output being rectified AC, which varies with engine speed.
  • Others suggest that if alternators from the same manufacturer and size are used, they may be paralleled without significant issues, as their outputs are diode-fed, preventing feedback into the alternators.
  • A participant raises the importance of ensuring that alternator bodies are electrically isolated to avoid short circuits, especially if multiple alternators are used.
  • One participant proposes using a dedicated alternator for each battery in a series configuration to optimize battery lifespan, suggesting that this could be a more effective approach than paralleling multiple alternators.
  • Concerns are raised about the need for balanced belt tensions and the potential complications of feedback loops if alternators are connected in parallel without additional rectification measures.
  • Participants discuss the possibility of charging batteries while they are connected in series, emphasizing the need for electrical isolation between alternators to prevent short circuits.
There is no consensus on the best approach to connecting car alternators in parallel. Multiple competing views exist regarding the feasibility, safety, and efficiency of such configurations, with participants expressing differing opinions on the technical challenges involved.
Participants mention various assumptions, such as the need for electrical isolation and the implications of alternator output characteristics. There are unresolved questions about the specifics of feedback mechanisms and the impact of using different battery configurations.
This discussion may be of interest to individuals exploring alternative energy solutions, electric vehicle enthusiasts, and those looking to understand the complexities of integrating multiple power sources for battery charging.
agabrielauto
What happens if I connect two car alternators in parallel? Can I connect three or four alternators in parallel? I just want a cheap way to increase power. I need 5.5kw for recharging a battery pack.
I'm pretty sure that this is a bad idea; alternators do not output perfect DC, but rather, a rectified AC waveform that has a frequency that depends on how fast the engine is turning. It's hard enough to synchronize (phase) two generators that output nearly the same frequency (and voltage) but imagine doing that with two car alternators that have frequencies that vary quite a bit!
5.5 kW works out to 46 A (using 120 V) or 23 A (using 240 V)--even if you could find a charger, that's a lot of current (never mind what the charger's efficiency between wall to output is). You could probably use a big gas generator, but you'd still need something to convert the 120 V output to the appropriate voltage to charge the battery pack.
Is the battery pack only 12 volts total? This would be the only reason you would run the alternators in parallel with each other. And as MATLABdude pointed out, there are problems with that configuration.
If the pack is a group of 12 volt batteries in series then it would be feasible to place a single alternator in parallel with each battery. Though each alternator body would have to be electrically isolated from the others, as every alternator I've ever dealt with grounds the body.
If any of the alternator bodies were to come into contact with each other, it would generate a direct short circuit across a section of the battery pack, and major destruction, death, and/or putting your eye out, might ensue.
I believe that 2 alternators with internal regulators of the same manufacturer and size can be paralelled without any problems. The fact that they don't output pure DC is irrelevant. The outputs are diode fed so nothing can feed back into the alternator. The battery which IS pure DC doesn't feed back into the alternator between pulses, so another alternator wouldn't either. I've seen more than one machine with dual alternators that came that way from the factory. The main thing to remember when charging battery banks with alternators is to NEVER disconnect the battery while the alternator is turning. Make sure the alternator has come to a stop before disconnecting.
In theory that sounds reasonable. But alternators are also belt driven. You would want the belt tensions balanced as well, using the same pulleys, etc.
What sort of battery packs are you trying to charge?
I suspect that it can be done, with care. In an alternator, the rotor has a dc excitation, and the stator output is ac, which is rectified by two diodes. Feedback is taken from downstream of the two doides and fed back to the rotor to control the output voltage. If you connect two alternators in parallel, the two feedback loops will interfere with one another, unless you isolate the two alternator feedback loops by putting one additional rectifier diode per alternator downstream of the feedback loop. This extra diode drop will require that the regulated alternator output voltages be increased by the same amount.
Thanks for your answers!
It may sound crazy but I,m planning(in a near future) to test this connection in an electric vehicle:
1- DC electric motor with a special pulley adapter for connecting two high output alternators
2- alternators to DC/AC converter
3- converter to charger(ev charger)
4- charger to battery pack (96vdc)
Im just trying to extend the driving range!
Eeegads... Just add 6 more alternators. Batteries are like people: they are all different. A dedicated alternator for each battery, powered by regenerative braking, will optimize each batteries lifespan. All these converters will just add unnecessary time and expense to your project. KISS.
But then again, I'm poor... :cry:
Good luck. :smile:
Solar rules! :cool:
Yes that's my freakin solar powered boat... Do you think I could make this stuff up?
Can I do that and still connect all the batteries in serie to supply the 96 volts needed?
I don't see the motor...
Yes.
But as a reminder:
OmCheeto, this a draw I did representing the picture in my mind about what you are saying. It is correct? If not explain, please...
Ups, is this one
http://gabrielauto.webs.com/apps/photos/photo?photoid=39042511
You could make up a shaft with several pulleys on it and drive an alternator from each pulley and charge a battery from each alternator.
Each alternator could have its own regulator like this.
So, you might have a big solid frame with a motor at one end and a bracket with a bearing on it at the other and a pulley shaft between the two. Then have alternators on each side of the shaft with their outputs going to batteries.
If the batteries were in series, you could leave them connected, but you would have to insulate the alternators from each other and put them in a closed box for safety.
If the batteries were in parallel, you would have to remove them for charging.
agabrielauto said:
Ups, is this one
Yes. That will work.
agabrielauto said:
Ups, is this one
As Bob S pointed out, feedback is via field winding current. Where are your field winding connections, and what regulates each?
I can't wait until you explain me how it is posible. I'm always tempted to ask why things happen.
So here goes the question.
How it is possible to charge each battery(with its own alternator), while at the same time have them connected in series to power a controler(or electrc motor 96vdc)??
Isn't suppose to make a short circuit.
As long as each alternator is electrically isolated from the others, the only path for charge to go is into its own battery. This assumes the batteries are not being used in a vehicle while they are charging, so there is no load on the batteries. It is charging from the mains.
It then behaves like a car alternator should, with its own regulator to stop charging when the battery is fully charged and to stop the voltage going too high.
Why do you see this as a problem?
Just pretend the alternators are batteries also. The circuit then becomes two sets of parallel series batteries.
The alternators have an added feature of having diode banks on their output. This prevents them from consuming power if their voltages drop below that of the batteries.
As vk6kro said,
"This assumes the batteries are NOT being used in a vehicle while they are charging".
That's my point.
I do want to recharge the batteries while being used. Just like a normal car.
If that,s not possible, then I would have to go back to my first Idea(at the beginning of this forum).
The problem is the bigger alternator I have found is 350 amps.
And I need 500amps or 5.5kw.
A very big problem, addressed earlier is
"If any of the alternator bodies were to come into contact with each other, it would generate a direct short circuit across a section of the battery pack, and major destruction, death, and/or putting your eye out, might ensue".
Unlike other generators or alternators, the automotive alternator has one side (usually negative) grounded to the case. This means that all the alternator cases have to be electrically isolated. But more important is the personnel safety issue. I heard of a guy who did not believe he could feel a shock from a 12 volt (or maybe it was 6 volt) auotmotive battery, so he soaked his hands in brine for several minutes, and then electrocuted himself. I suggest that if you plan to use this setup for a marine application, you do your boating in distilled water.
Good luck. :smile:
Solar rules! :cool:
Is that an advanced DC motor, about 8 HP ?? Nice rig!
Now I know what I can do with that old Chrysler foot that has been laying in my back yard for 17 years:biggrin:
:frown:
1(?) hp 12(?)vdc pride wheelchair broken(free!) motor that I fixed in about 15 minutes.
For research purposes only.
agabrielauto said:
As vk6kro said,
That's my point.
You would only want to use the alternators as a braking system. Otherwise it's a no win situation.
I would also test it out on a single alternator battery system to see if the idea is even valid.
Find out how much current each battery will accept at 70% DOD, 50% DOD, and 30% DOD.
This will give you an idea of how well the system will work at various depths of discharge.
Obviously, it's not going to do anything when the batteries are fully charged.
This company http://www.zena.net/
Give me this answer on how they do it :
This system would comprise three of our SR200.12 Power Generators ($675 ea.), one WC.12B Master Control Module ($195), two WC.12S Slave Control Modules ($165 ea.), and one WC.VR2 Voltage Regulator Module ($190).
The three generators would be mounted so as to be driven by a single engine (though multiple engines can be used) -- typically be means of a single serpentine belt pulley mounted to the engine's drive shaft. The individual output terminals of the three generators would be connected together and with our electronic controls perform as a single generator (though more efficiently since we produce much less waste heat during the generation process.
The total cost of the system would be $2740
Do any of you thinks that I could do this (2 alternator outputs to perform as a single generator) in a much easy and cheap way?
If you already have the alternators, why not just try it with one battery?
I think the regulators are just built into the alternators now.
Maybe it will all work OK. At least you can't hurt the alternators like that. They have diode outputs.
They may not share the load evenly, so maybe you could temporarily put meters in line to measure the currents from each alternator?
OmCheeto said:
:frown:
Sorry Omcheeto,
Should have used a capitol A, Advanced DC, are the motors used in most electric car conversions. They come in power ratings as high as 20 HP.
I might have some thoughts for the OP, but will have to come back later.
Hope everyone has a good day.
Ron
11K
