- 29,207
- 4,631
So, where you hit by the end of analog TV?
The discussion revolves around the transition from analog to digital television in the US, exploring the impacts of this change on viewers, particularly those in rural areas. Participants share personal experiences, technical challenges, and opinions regarding the effectiveness and implications of the digital switch.
Participants express a mix of satisfaction and frustration regarding the digital transition, with no clear consensus on its overall impact. While some appreciate the benefits of digital TV, others highlight significant drawbacks, particularly for those in rural areas.
Participants mention various personal experiences with signal strength and access to channels, indicating that the effectiveness of the digital transition may vary significantly based on location and infrastructure.
turbo-1 said:We used to get 8-10 analog channels over our huge VHF/UHF antenna/mast setup. Now we get only 2. One is the CBS affiliate and the other is a PBS station. The drive to all-digital broadcasting is quite detrimental to those of us in rural locations, and seems destined to line the pockets of satellite-TV companies. There aren't enough people in my area to justify the cost of cable, so we'll never have that option.
It may have been desirable from some viewpoints, but to people in rural locations, it seems that we have sacrificed a lot of access to information (weather reports, storm warnings, traffic disruptions) that might have been pretty valuable, but often taken for granted. If you are in the path of a cell of severe thunderstorms, and you can't get local weather reports, that's not good.Office_Shredder said:http://www.wired.com/epicenter/2009/06/fccbroadband/
In my opinion this needed to be done eventually. The FCC originally planned for everything to be switched over in 2006, but obviously that didn't happen. Ensuring a modern communications infrastructure is actually one thing the government has succeeded at fairly well from what I can tell
turbo-1 said:It may have been desirable from some viewpoints, but to people in rural locations, it seems that we have sacrificed a lot of access to information (weather reports, storm warnings, traffic disruptions) that might have been pretty valuable, but often taken for granted. If you are in the path of a cell of severe thunderstorms, and you can't get local weather reports, that's not good.
We have a converter, but guess what? The strength of the digital signal of a lot of the stations is insufficient, and unlike analog, you don't get a slightly degraded picture/sound with a weak signal - you get NO picture/sound. And no, the analog signals are totally gone.Office_Shredder said:I'm a little confused... why can't you get this information precisely? Did your local analog station just decide to quit transmitting instead of switching to digital, or did you decide not to get a digital to analog converter?
turbo-1 said:We have a converter, but guess what? The strength of the digital signal of a lot of the stations is insufficient, and unlike analog, you don't get a slightly degraded picture/sound with a weak signal - you get NO picture/sound. And no, the analog signals are totally gone.
Office_Shredder said:Now I'm confused; wouldn't it have made more sense to switch all of the digital frequencies to the VHF range when it got cleared up thanks to all the analog channels switching off?
Cyrus said:There is no reason for TV to use up spectrum. There are tons of other things that could use those same channels. Use groundwires for TV signals - this isn't the 1950s.
Cyrus said:One "expert" was saying that he expects a bit of a shift away from cable and satellite services, with more people going back to antenna. Many people will see the number of available channels increase significantly - quadruple the number in some cases - with the addition of HD, all for free.
Ivan Seeking said:I'm sure that would provide a great picture!![]()
Cyrus said:What are you talking about, my cable TV comes via a ground wire. The same wire can provide the free channels that use spectrum space.
Ivan Seeking said:Do you mean it is broadcast that way, or you can just get a signal that way?
Are you saying that your cable is on all grounds in your house?
Cyrus said:My TV get's its FIOS signal via a cable under the ground. Not a Radio Signal, just an electric Signal.
Ivan Seeking said:So they are not just transmitting on a ground wire.
