Is There an Error in the Angle Calculation for the Emergent Ray from a Prism?
The discussion centers on the calculation of the angle of the emergent ray from an equilateral triangular glass prism when monochromatic yellow light is incident at a 60° angle. The refractive index of the glass is specified as 1.54. The participant's calculations using Snell's Law indicate an angle of refraction of 18.94°, leading to confusion when attempting to calculate the angle of refraction back into the air, as the sine function yields a value greater than 1, indicating total internal reflection. The conclusion drawn is that the initial assumption of the emergent angle being 60° is incorrect based on the provided data.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of refractive indices and critical angles
  • Familiarity with ray diagrams and their construction
  • Basic principles of light behavior in prisms
  • Study the implications of total internal reflection in optical systems
  • Explore advanced applications of Snell's Law in different media
  • Learn about the critical angle and its significance in optics
  • Investigate the properties of equilateral triangular prisms in light refraction
Students of physics, particularly those studying optics, educators teaching light behavior, and anyone involved in optical engineering or design.
jemerlia
A ray of monochromatic yellow light is incident in air on an
equilateral triangular glass prism. This ray is in the same plane as
the equilateral triangular cross section of the prism; the angle
between the ray and the prism face is 60°, and the refractive index
of the glass is 1.54 for this light.
Find the angle the emergent ray makes with the prism face at
which it emerges. Illustrate your answer with a diagram.
The given answer is 60 degrees. The problem appears straightforward but it appears impossible to get the required result with the given data. Please check my solution and comment...
Snells law: n1*sin theta1 = n2 sin theta 2
For angle of refraction of the incident light - from air into the prism:
sin r = sin 30/1.54, r = 18.94 degrees
The angle of incidence upon striking the internal glass surface = 60-18.94
Therefore the angle of refraction - from glass back into the air:
= asin(1.54 * sin(60-18.94))
The difficulty is that the inner sin function gives a value > 1
Have I done something wrong?
60-18.94 = 41.06 is greater then the critical angle. Now draw the ray diagram and find the angle of incidence of the total internal reflected ray on the prism face.
Quite so... many thanks for your help!
