What are some suggestions for a good circuit analysis program?
The discussion revolves around recommendations for circuit analysis programs, specifically focusing on schematic drawing capabilities, input voltage settings, and node voltage checking. Participants share their experiences with various software tools suitable for DC circuit analysis.
  • Exploratory, Technical explanation, Debate/contested
  • One participant mentions using Protel for circuit diagrams but seeks a program that allows for setting input voltages and checking voltages at different nodes, specifically for amplifiers and resistors.
  • Another participant recommends LT Spice as a good and free option for circuit analysis.
  • A participant expresses satisfaction with LT Spice but inquires about how to insert a potentiometer into the simulation.
  • One participant suggests using a DC voltage source as a substitute for a potentiometer in LT Spice, noting that the simulation needs to be re-run after changes.
  • Another participant mentions the availability of a potentiometer model in a Yahoo group dedicated to LT Spice, providing instructions for installation and encouraging feedback on its effectiveness.
Participants generally agree on the utility of LT Spice for circuit analysis, but there are varying approaches regarding the implementation of potentiometers, with some participants providing different methods and resources.
There are limitations regarding the specific functionalities of LT Spice and the potentiometer model, as well as the need for additional steps to incorporate certain features. The discussion does not resolve the effectiveness of the potentiometer model.
chopficaro
im currently using protel to draw circuit diagrams and it is fine for that. but, when trouble shooting a board, i'd like to have a schematic drawing program that would allow me to set my own input voltages and allow me to check the voltages at different nodes. the only components i need it to recognize are amplifiers and resistors. if it could do capacitors that would also be helpful, but i only expect to find programs that do DC calculations.
i liked the way logicworks was set up, it allowed me to set the inputs and place probes everywhere i wanted to test the outputs, but that program was only for logic gates, and the voltages checked were 1's and 0's nothing more.
any suggestions would be greatly appreciated.
thank you, lt spice is working very well so far. but would you happen to know how to insert a potentiometer?
I like LTSpice also. I have used a dc voltage source for a potentiometer in the past. You will have to re-run the simulation after every change.
Using Bob S's suggestion of dc voltage source will work if it's a dc circuit. Otherwise, you'll have to add a potentiometer model.
I've not used the potentiometer model, but you can find it at the Yahoo group devoted to LT Spice. You'll have to sign up for a (free) Yahoo account if you don't already have one, then you can join the LT Spice group here:
http://tech.groups.yahoo.com/group/LTspice
After joining that group, click on "Files", then "Tut", then "Potentiometer".
From there, click on the "potentiometer_standard.txt " file to get directions for installing the potentiometer models. It basically tells you to copy two files into specific folders on your computer, then restart LT Spice for the changes to take effect.
I haven't used the potentiometer models before, so if it works out let us know!
Good luck. :smile:
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 24 ·
