Equal Coefficients Polynomials
The discussion revolves around the justification for setting coefficients equal in polynomial equations, particularly in the context of linear independence and the properties of polynomial functions. Participants explore various proofs and perspectives on the equality of polynomials and their coefficients, touching on concepts from linear algebra and calculus.
  • One participant questions the method of setting coefficients equal in polynomial equations and proposes a justification based on linear independence of vectors in a vector space.
  • Another participant agrees that two polynomials are equal if and only if their coefficients are equal, citing the basis formed by {1, x, ..., x^n}.
  • A different participant suggests that the same reasoning applies to trigonometric functions like sine and cosine due to their linear independence.
  • Another contribution outlines a method of proving coefficient equality through evaluating polynomials and their derivatives at specific points.
  • One participant presents an alternative proof involving the implications of having more than n zeros for a polynomial equation, leading to the conclusion that coefficients must be equal.
  • A participant notes that the concept of linear independence may not be explicitly mentioned in all textbooks, particularly those not requiring linear algebra as a prerequisite.
  • Another participant introduces the idea that definitions of polynomials can vary, and in some contexts, "equal polynomials" means they have the same coefficients, while equality of the functions they represent can be more complex.
  • A further example is provided regarding modular arithmetic, illustrating a case where two different polynomials can represent the same function.
Participants generally agree on the principle that coefficients of equal polynomials must be equal, although there are differing views on the implications and definitions surrounding polynomial equality and linear independence. The discussion includes multiple perspectives and proofs, indicating that no single consensus has been reached on all aspects of the topic.
Some participants highlight that the understanding of polynomial equality may depend on the definitions used and the context in which polynomials are considered, such as in modular arithmetic. There are also mentions of potential limitations in textbooks regarding the treatment of linear independence.
Enjoicube
Here is something that always bugged me, and I think I have an explanation for it now, but I am wondering if it is correct. Alright, the problem to me was that back when I was in Diff-eq, to use undetermined coefficients with polynomials, we would always group together the terms on one side, and set the undetermined coefficients equal on the other side, as such:
2(x^2)+3x+5=a(x^2)+bx+c
would imply that a=2, b=3 and c=5
However, this method always seemed a little uncertain to me, and when I would ask about why we could set the coefficients equal, I was always given a handwaving argument or "doesn't it seem reasonable?"
Today, I came across an exercise in my linear algebra book that I think may justify this method; the exercise says "prove that if v1,...,vn are linearly independent vectors in the vector space U and each ai,bi belongs to the field F then a1*V1+...an*Vn=b1*V1+...bn*Vn [tex]\leftrightarrow[/tex] a1=b1,...,an=bn with
The proof in the forward direction (all I will prove):
Since a1*V1+...an*Vn=b1*V1+...bn*Vn[tex] subtract the right side of the equation to end up with<br /> (a1-b1)*<b>V1</b>+...(an-bn)*<b>Vn</b>=0<br /> <br /> and since these vectors are linearly independent, each ai-bi=0, so ai=bi for i=1,...,n<br /> <br /> Now, looking at the space Pn of polynomials of degree n, the set {1,x,(x^2),...,(x^n)} forms a basis, so each of these vectors must be linearly independent. That means that, as above, if we have<br /> <br /> 2(x^2)+3x+5=a(x^2)+bx+c<br /> <br /> Since the set vectors {1,x,(x^2)} is linearly independent, one can set the coefficients equal.<br /> <br /> Am I correct about using this theorem to justify this method of setting coefficients equal? I know it seems trivial, but if this is correct, someone who doesn't really understand why this works could try this method on a set of linearly dependent vectors, for which it isn't necessarily true![/tex]
Yes, the fact that two polynomials are equal if and only if the coefficients of the corresponding powers are equal follows from the fact that {1,x,...,x^n} is a basis.
Notice that this proof does not involve considering the polynomials as functions. If we consider two polynomials P(x) = Q(x), then we can generate an infinite set of linear equations:
P(1) - Q(1) = 0
P(2) - Q(2) = 0
from here you can if you wish complete the proof of the same fact using the tools of linear algebra.
I suppose the same argument goes for the trig functions sine and cosine, since they are linearly independent.
Even more simply, given two polynomials [itex]P(x)= a_nx^n+ a_{n-1}x^{n-1}+ \cdot\cdot\cdot+ a_1x+ a_0[/itex] and [itex]Q(x)= b_mx^m+ b_{m-1}x^{m-1}+ \cdot\cdot\cdot+ b_1x+ b_0[/itex], with P(x)= Q(x) for all x, setting x= 0 shows that [itex]a_0= b_0[/itex]. But we must also have P'(x)= Q'(x) and setting x= 0 shows that [itex]a_1= b_1[/itex]. Each successive derivative, at x= 0, gives the equality of the next coefficients.
Yet another proof. If
[tex] a_n x^n + a_{n-1}x^{n-1} + \cdots + a_1 x + a_0 = b_n x^n + b_{n-1} x^{n-1} + \cdots + b_1 x + b_0 [/tex]
for all x, then
[tex] (a_n - b_n) x^n + (a_{n-1} - b_{n-1})x^n + \cdots + (a_1 - b_1) x + (a_0 - b_0) = 0[/tex]
for all x, so the second polynomial has more than [tex]n[/tex] zeros, and so must itself be the zero polynomial. This means [tex]a_i = b_i \, \, i = 1, \dots, n[/tex]
Yes, that is in fact "linear independence". The textbook may not say that, however, if it does not have linear algebra as a prerequisite. More advanced DE textbooks will, of course, mention the concept of "linear independence".
I would like to add some things.
There are a variety of ways to define polynomials -- in at least one of them, "equal polynomials" actually literally means "they have the same coefficients".
Equality of the functions these polynomials represent is a slightly trickier issue. The result statdad mentioned is the typical approach.
It turns out that in familiar situations, equality of polynomials and equality of the functions they represent turn out to be the same.
In some more esoteric situations, two polynomials may be different despite representing the same polynomial function. If you're familiar with modular arithmetic, you can check that if we define the functions
[tex]f(x) = x \pmod 2[/tex]
[tex]g(x) = x^2 \pmod 2[/tex]
then f=g, despite [itex]x \pmod 2[/itex] and [itex]x^2 \pmod 2[/itex] being different polynomials.
  • · Replies 0 ·
