Belts & Friction: 25 ld-ft Torque, 6 in. Drum, 0.30 µ
  • Thread starter Thread starter GSXR1000
    Friction
The discussion focuses on calculating the minimum allowable tension in a flat belt transmitting a torque of 25 lb-ft from an electric motor to a drum with a diameter of 6 inches and a static friction coefficient of 0.30. The key equations utilized include T1 = T2e^(µß) and the torque balance equation ΣM = 0, leading to T2*r - T1*r = 0. The participants emphasize the importance of correctly determining the normal force (dN) to avoid slipping, and they suggest solving the two equations to find the unknown tensions.
  • Understanding of torque and its application in mechanical systems
  • Familiarity with static friction and its role in belt drive systems
  • Knowledge of basic equations of motion and equilibrium in mechanics
  • Ability to solve exponential equations involving tension and friction
  • Study the principles of belt drive systems and their mechanical advantages
  • Learn about the calculation of normal force in friction problems
  • Explore the implications of torque in rotational dynamics
  • Investigate the effects of varying coefficients of friction on belt performance
Mechanical engineers, physics students, and anyone involved in the design or analysis of belt-driven systems will benefit from this discussion.
GSXR1000
A flat belt is used to transmit the 25 ld-ft torque developed by an electric motor. the drum in contact with the belt has a diameter of 6 in., and the coefficient of static friction between the belt and the drum is 0.30. Determine the minimum allowable value of the tension in each pert of the belt if the belt is not to slip.
T1=T2e^(µß)
ß=2.79 rad
µ=0.30
please see attached for attempts at solution
I think that my assumption that force of friction (Ff ) is equal to µdN is wrong. I am not sure how to determine what dN is in this problem. If anybody has suggestions it would be greatly appreciated.
Ok I have realized that the motor produces torque M and ΣM about G =0, T2*r-T1*r=0 (See attachment in post #1 for FB)
If you set M=T2*r-T2*r this will be when incipient slipping of the belt is about to occur. Using this with T1=T2*e^(µß) we have two equations and two unknowns. Solve for the unkowns!
  • · Replies 45 ·
26K
