Where Can I Find Yield Stress and Endurance Limit Data for ASTM A513 Steel?
  • Thread starter Thread starter JD88
    Limit Yield
The discussion centers on locating yield stress and endurance limit data for ASTM A513 steel, specifically for 1" OD steel tubing with a 1/8" wall thickness, identified as ASTM A513-07. Participants clarify that ASTM A513 is a specification for electric-resistance-welded carbon and alloy steel mechanical tubing, which includes multiple alloys with varying properties. A key resource mentioned is the table in the back of the specification that outlines approximately 15 alloys. Additionally, the MMPDS and MIL-HDBK-5J are recommended as valuable references for material properties.
  • Understanding of ASTM A513 specifications
  • Familiarity with material properties of steel alloys
  • Knowledge of MMPDS and MIL-HDBK-5J publications
  • Basic comprehension of mechanical tubing applications
  • Research ASTM A513 specifications for detailed alloy properties
  • Explore the MMPDS publication for material property data
  • Investigate MIL-HDBK-5J for additional alloy information
  • Learn about the mechanical properties of carbon and alloy steels
Engineers, material scientists, and professionals involved in mechanical tubing applications or those requiring specific material property data for ASTM A513 steel.
JD88
Does anyone know or know of a good resource where I can find the yield stress and endurance limit of ASTM A513 steel?
ASME Section II
I am sorry, how is this supposed to help. I google ASME section II and found nothing useful. Am I missing something? If anyone knows the values or can give a good resource I would really appreciate it.
ASTM A513 is a spec for tubing using carbon or alloy steel. Can you be a bit more specific with what you need?
I am sorry if I am not specific enough, I unfortunately don't know much about this kind of thing. Anyways, all I really know is that we have 1" OD steel tubing with 1/8" wall thickness and I was told that it is ASTM A513-07.
Hopefully this helps.
Whoever told you that you can find material properties from that spec is mistaken. The spec covers multiple alloys and governs the geometric manufacturing properties of tubes more specifically "Standard Specification for Electric-Resistance-Welded Carbon and Alloy Steel Mechanical Tubing."
There is a table in the back of the spec that covers approximately 15 alloys having varying properties. You need to find out the exact alloy used to make the tube you have. I have attached a snippet of the total table that gives the varying alloy requirements. Hopefully since it is only a single page there won't be any issues with copyright stuff.
I might try looking in the MMPDS or MIL-HDBK-5J to see if the specific alloy you're looking for is in there. Both publications are a strong resource for a limited number of steel, alumuinum, magnesium, and titanium alloys.
