Which is More Acidic: 4-Nitrophenol or 2-Fluoro-4-Nitrophenol?
  • Thread starter Thread starter chunkytuna21
2-Fluoro-4-nitrophenol is more acidic than 4-nitrophenol due to the presence of two electron-withdrawing groups, which enhance acidity. The discussion highlights the importance of resonance in stabilizing the phenolate anion, as the para nitro group effectively draws electrons away from the aromatic ring. The inductive effect of the fluorine atom further contributes to the increased acidity of 2-fluoro-4-nitrophenol compared to its counterpart.
  • Understanding of acidity and electron-withdrawing groups in organic chemistry
  • Knowledge of resonance and its impact on molecular stability
  • Familiarity with the structure and properties of nitrophenols
  • Basic concepts of inductive effects in chemical compounds
  • Research the effects of electron-withdrawing groups on acidity in organic compounds
  • Study resonance structures and their role in stabilizing anions
  • Explore the properties and reactions of nitrophenols in organic synthesis
  • Investigate the inductive effects of halogens on acidity in aromatic compounds
Chemistry students, organic chemists, and researchers interested in acidity trends and the effects of substituents on aromatic compounds.
chunkytuna21
Which is more acidic, 4-nitrophenol or 2-fluoro-4-nitrophenol?
I think it would be 2-fluoro-4-nitrophenol because acidity is increased by the presence of electron withdrawing groups. 2-fluoro-4-nitrophenol has two electron withdrawing groups as opposed to only one for 4-nitrophenol. Is that correct? Should I also consider resonance when answering this question?
Sounds good to me. I would say that yes, you probably should consider resonance (the more resonance forms, the more stable the phenolate anion), just to show why the para nitro group draws electrons away from the ring. Also, since there's only one F, that shouldn't interfere with anything, it'll just inductively draw electron density from the ring.
19K
50K
