Power usage of LED light using AC adapter
The discussion centers on the power consumption of a modified Sylvania Lighting Dot It Black LED Swivel light powered by an AC-DC adapter. The LED light originally consumes approximately 0.25 watts on batteries but operates at maximum brightness when connected to the adapter, which outputs 4.5V at 600mA. The adapter's input is rated at 8W, and the user inquires about the actual power usage when the light is connected. It is confirmed that the 8W rating refers to the maximum input power under load, and the effective power consumption is calculated to be around 1W, significantly lower than the previous 25-watt R14 miniflood light.
  • Understanding of AC-DC power conversion
  • Basic knowledge of LED lighting specifications
  • Familiarity with electrical measurements (voltage, current)
  • Knowledge of power supply ratings and efficiency
  • Research "AC-DC power supply efficiency ratings"
  • Learn about "LED driver specifications and performance"
  • Investigate "measuring power consumption of electronic devices"
  • Explore "calculating power usage in modified LED lighting systems"
This discussion is beneficial for electronics hobbyists, DIY enthusiasts modifying lighting solutions, and anyone interested in optimizing power consumption in LED lighting systems.
daddybruce56
I have a question about how much power I’m using to run a LED light that I modified to
run off an AC-DC adapter instead of 3 AAA alkaline batteries. The light is a Sylvania Lighting Dot It Black Led Swivel, which uses about 1/4 of a watt (4.5 V X 54.7mA) on batteries. The light would dim unacceptably after about 20 hours of use. So as to not burn through lots of batteries I did this modification (I know I could have purchased rechargeable batteries but since I hang on to old AC-DC adapters for this very reason, it was a no cost project. It works great – always max brightness.
Here are the specs on the adapter:
INPUT: AC 120V 60HZ 8W
OUTPUT: DC 4.5V 600mA
Class 2 Power Supply for use with audio products without antenna connections. Masugarbagea Electric CO. LTD. Made in China. It has a polarized two-prong plug. I have no idea how old it is, what it was originally used for or, what the exactly is the internal circuitry. It gets moderately warm after running a while with nothing connected.
Measured 6.1VDC unloaded output of the adapter (Measured same with adapter connected to light – LED OFF, at the battery terminals where adapter wires are soldered. Measured 5.25V DC at terminals with light ON. I also measured the current -- about 55mA DC approximately the same as the battery amount above, which comes from www.ledmuseum.org’s[/URL] review of the “puck”, style Dot-It.
Is the 8W AC standby or max? (Is that the power it uses just plugged in with no load or what it uses with the DC load drawing the full 600mA?) Can I take the actual DC load (55mA) divided by the max DC load (600mA) and multiply that by 8W to get .73W that gives me ~=1W used total? Am I assuming anything that is wrong? Also, is the 5.25V DC a problem?
Any way it comes out it is still less power than the 25-watt R14 miniflood light I was using. The LED does not put out as much light as the miniflood but it‘s enough to illuminate a computer keyboard in semi-dark room, which is what I wanted.
Thanks, daddybruce56
The 8W is the total input power when it is putting out the rated load (2.7W). The VA (volt-amps) will be more.
Bob S
  • · Replies 31 ·
  • · Replies 27 ·
