Derivative of an inverse trig function
The discussion revolves around finding the derivative of the inverse secant function, specifically for the expression y=sec^{-1}(1/t) within the interval 0
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to use u substitution to simplify the differentiation process. Some participants question the validity of a specific algebraic step in the simplification, while others suggest alternative relationships between trigonometric functions that could aid in finding the derivative.
Participants are actively engaging with the problem, with some providing clarifications on algebraic manipulations and others offering insights into related trigonometric identities. There is a recognition of a mistake in the original poster's calculations, but no consensus on a final resolution has been reached.
The original poster is working under the constraints of a homework assignment, which may limit the methods they can employ. There is an implicit understanding that the solution should align with textbook answers, prompting scrutiny of the steps taken.
efekwulsemmay
[tex]y=sec^{-1}\frac{1}{t}, 0<t<1[/tex]
[tex]\frac{d}{dx}sec^{-1} x= \frac{1}{\left|x\right|\cdot\sqrt{x^{2}-1}}[/tex]
Basically to simplify things I used u substitution so I let u=1/t then du/dt=-1/t2 and I got:
[tex]y=sec^{-1}u\rightarrow y^{,}=\frac{1}{\left|u\right|\cdot\sqrt{u^{2}-1}}\cdot\frac{du}{dt}[/tex]
which,when I substituted for u, I got:
[tex]=\frac{1}{\left|\frac{1}{t}\right|\cdot\sqrt{\left(\frac{1}{t}\right)^{2}-1}}\cdot\frac{-1}{t^{2}}[/tex]
which works out as:
[tex]=\frac{-1}{\left|\frac{1}{t}\right|\cdot t^{2}\cdot\sqrt{\frac{1^{2}}{t^{2}}-1}}[/tex]
and:
[tex]=\frac{-1}{t\cdot\sqrt{1-t^{2}}}[/tex]
however, the answer as per the back of the book is:
[tex]\frac{-1}{\sqrt{1-t^{2}}}[/tex]
what did I do wrong?
The step,
[tex]\frac{-1}{\left|\frac{1}{t}\right|\cdot t^{2}\cdot\sqrt{\frac{1^{2}}{t^{2}}-1}} = \frac{-1}{t\cdot\sqrt{1-t^{2}}}[/tex]
is incorrect. Remember
[tex]a\sqrt{b} = \sqrt{a^2b}[/tex]
so you have,
[tex]t\sqrt{1/t^2-1} = \sqrt{1-t^2}[/tex]
ooooooooh ok. that makes more sense. that's clever hehehe
thank you so much :smile:
For next time, you may remember that since [tex]\cos x = \frac{1}{\sec x}[/tex], it is true that [tex]\sec^{-1} \left(\frac{1}{x}\right) = \cos^{-1} x[/tex] and so the derivative is standard.
  • · Replies 105 ·
13K
  • · Replies 22 ·
