Launch a Ping Pong Ball with a Planar Bistable Mechanism: Step-by-Step Guide
  • Thread starter Thread starter Jps
    Ball Launch
The discussion focuses on designing a planar bistable mechanism to launch a ping pong ball, emphasizing the need for two stable positions and an unstable equilibrium for maximum energy storage. The mechanism is activated by a slight push on the club link, which is 2 inches between pivots. Key concepts include the use of Mohr's circle for spring orientation and Hooke's Law for energy calculations. The user shares insights from their project using a rat trap ballista, demonstrating potential energy principles through vertical setup and weight variations.
  • Understanding of planar bistable mechanisms
  • Familiarity with Mohr's circle for analyzing forces
  • Knowledge of Hooke's Law for spring mechanics
  • Basic principles of potential energy and energy storage
  • Research the design and mechanics of bistable mechanisms
  • Study Mohr's circle applications in mechanical systems
  • Explore advanced applications of Hooke's Law in energy storage
  • Investigate different types of springs suitable for mechanical launching systems
Mechanical engineers, physics students, hobbyists in robotics, and anyone interested in designing launching mechanisms or studying energy storage systems.
Jps
Hello all,
Basically we need to come up with a planar bistable mechanism that will launch a ping pong ball. Here's a quick image I made: http://freewebsite.0nyx.com/images/mech.html
The club link is supposed to hit the ping pong ball and the goal is to make it go as horizontally far as possible.
By bistable it means that the mechanism must have two positions with unstable equilibrium position of max. energy storage somewhere in between. The mechanism is triggered with a slight push to the club link.
So how do I approach this problem. Say I know that the length between two pivots is 2 inch. And I'm supposed to figure out the dimensions of the links and what type of spring to use. If someone can throw some background info to this mechanism or some equations for energy storage of spring etc. will be helpful.
Thank you.
For my project I used a rat trap ballista (so called catapult) To get the energy Iwas suposed to use Mohr's circle because of the orientation of the spring. But you should be able to use the energy version of http://en.wikipedia.org/wiki/Hooke%27s_law" law.
The way I cheated my lecturer was to set the device up vertically and I proved the potential energy by the change in static height maintained by the spring for different weights hung off it. Hope this helps.
  • · Replies 16 ·
9K
9K
13K
14K
