Analogy of casimir effect with moving boats
  • Context: Graduate
  • Thread starter Thread starter meichenl
    Analogy Casimir effect
The discussion centers on the analogy between the Casimir effect and the attraction between two parallel boats due to water wave dynamics. It is established that the pressure between the boats is lower than the surrounding water, potentially leading to an observable attraction. While some participants suggest this phenomenon may relate more to the Bernoulli effect, the Casimir effect itself involves fluctuating electric and magnetic fields in a vacuum, altering vacuum energy when scatterers are introduced. The conversation highlights the need for further investigation into the physics of this analogy.
  • Understanding of the Casimir effect and its principles
  • Familiarity with fluid dynamics, particularly the Bernoulli effect
  • Knowledge of wave quantization in fluid systems
  • Basic grasp of vacuum energy concepts in quantum physics
  • Research the Casimir effect in detail, focusing on its implications in quantum field theory
  • Explore the Bernoulli effect and its applications in fluid dynamics
  • Investigate the physics of wave interactions in fluids, particularly in constrained environments
  • Examine real-world applications of these principles in maritime engineering
Physicists, marine engineers, and anyone interested in the intersection of quantum physics and fluid dynamics will benefit from this discussion.
meichenl
During lunch today a friend told me that two boats running parallel to one another can be attracted to each other by an effect similar to the Casimir effect. The water waves between the boats are quantized, and there winds up being slightly less pressure from between the boats than from outside. She indicated this was an observable thing - something you actually have to take into consideration if you ever have two boats sailing side by side.
Has anybody heard of this, know a name for it, can give a good reference of where to learn more about the effect, or have any comments on the physics?
*If* there exists such a "force", which I have not heard of previously, I would expect that it is more due to the Bernoulli effect from the wind/current being forced between the boats than to any Casimir effect analog having to do with the waves.
In any case, a quick google search reveals that this is probably all nonsense anyway:
http://www.sciencebase.com/science-blog/casimir-effect-shipping.html
Whether or not such effects are actually observed at sea, the description is close to what happens. The Casimir effect occurs because the vacuum state has fluctuating electric and magnetic fields. This gives rise to a vacuum energy (which is infinite but actually it could be zero in our case because forces deal with the change in energy, so we can renormalize it at will and not change the results). Placing scatterers into the vacuum changes the allowable modes for the fluctuating fields. This in turn changes the energy of the vacuum. If we were to infinitesimally shift one of the scatterers, it would in turn infinitesimally shift the vacuum energy. This change in energy due to a displacement is the Casimir force.
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 16 ·
