Magnetic field generated by current in semicircular loop at a point on axis
The discussion revolves around determining the magnetic field strength and direction at a point on the axis of a semicircular current loop of radius R, utilizing the Biot-Savart Law.
  • Participants discuss the complexity of the problem compared to a full current loop, considering the need to analyze the semicircular arc and the straight line base separately. Questions arise regarding the calculation of the z and x components of the magnetic field, as well as the appropriate representation of position vectors and the unit vector in the context of cylindrical coordinates.
The conversation includes attempts to clarify the setup and representation of the problem. Some participants have expressed understanding, while others are still seeking clarity on specific components and the transition to cylindrical coordinates. There is an indication of collaborative support, with offers to check results.
Participants are navigating the complexities of the problem, including the need for a parametric representation of points on the semicircle and the implications of using cylindrical coordinates. There is a focus on ensuring all components of the magnetic field are appropriately addressed.
SOMEBODYCOOL
Determine the magnetic field strength and direction at a point 'z' on the axis of the centre of a semi-circular current loop of radius R.
Biot Savart Formula
[tex]d\vec{B}=\frac{\mu_{0}Id\vec{r}\times\hat{e}}{4\pi|\vec{R}-\vec{r}|^{2}}[/tex]
e being the unit vector from r to R
A much simpler problem is a full current loop, because one component of the magnetic field cancels out. For this problem, you'd have to deal with the half-circle arc and the straight line base separately. I was also wondering whether its easier to calculate the z and x components of B separately as well... One component is straightforward enough... I just really don't understand where to start.
This should be a pretty straightforward application of the Biot-Savart Law. Start by finding expressions for [itex]\textbf{r}[/itex], the position vector for a general point on the semi-circular arc, and [itex]\textbf{R}[/itex] the position vector for a general point on the [itex]z[/itex]-axis...what do you get for those?...What does that make [itex]\hat{\mathbf{e}}[/itex]? What is [itex]d\textbf{r}[/itex] for a semi-circualr arc?
To makethings easier, you will want to use cylindrical coordinates.
So, the parametric representation of a point on the semi-circle would be (0, bcos(t), bsin(t)) where b is the radius of the semi-circle.
The vector R is just [d, 0, 0] where d is the distance on the axis of the point
and then the e is the unit vector from R-r
But what's dr? And where does the switch to cylindrical coord come in?
I think I got it. Thanks
If you'd like to post your result, we''ll be able to check it for you.
9K
