Matlab Plotting of QM double-potential-barrier
  • Context: MATLAB
  • Thread starter Thread starter dLo R6
    Matlab Plotting Qm
The discussion focuses on plotting the Transmission Coefficient T(E) for a double-potential barrier using MATLAB. The parameters include a barrier width of 3nm, spacing of 9nm, and a potential of 0.5eV, with energy sweeping from 0 to 1eV. The user implemented the cascading matrix method but encountered an issue where the graph is inverted and the y-axis values range from infinity to 1 instead of the expected 0 to 1. The MATLAB code provided is intended to calculate the transmission coefficient but requires debugging to correct the output.
  • Quantum Mechanics concepts, specifically double-potential barriers
  • MATLAB programming, particularly matrix operations
  • Understanding of wavefunction coefficients and transmission coefficients
  • Familiarity with the cascading matrix method in quantum mechanics
  • Debug the MATLAB code to correct the inversion of the Transmission Coefficient plot
  • Research the cascading matrix method for quantum mechanics applications
  • Learn about MATLAB's plotting functions for accurate graph representation
  • Explore the relationship between energy and barrier width in quantum tunneling scenarios
Quantum mechanics students, MATLAB programmers, and researchers working on quantum tunneling problems or transmission coefficient calculations.
dLo R6
Hey everyone, I have a quantum mechanics/matlab issue. I'm trying to plot the Transmission Coefficient T(E) of a double-potential barrier with barrier width 3nm and spacing 9nm, potential V = 0.5eV and sweeping energy from 0 to 1eV. Using the cascading matrix method where, given a matrix M of each interface, the beginning and end coefficients of the wavefunctions can be found, with the end wavefunction having a coefficient t and |t|^2 gives the transmission. One would have to probably be familiar with this QM problem to get the whole idea.
Anyway, I wrote out a function to do just what was described, and came across an oddity. I get the correct graph, except it's flipped upside down and rather than being between 0 and 1, it's between infinity and 1, but on the correct scale. see the image below; can anyone pick through this code and possibly see where I've gone wrong or why this graph is showing up the way it is? if someone had some free time i'd really appreciate it, I've been hitting my head against the wall for 2 days now. thanks!
top: desired plot
bottom: my plot (notice the y axis)
code
%EE270 HW3 Problem 1
% Ryan Dumlao
%Consider a double barrier quantum well with a well width of L= 9 nm,
%barrier widths of d=3 nm, and a barrier height of V0=500 meV. Assume
%that you are considering the GaAs/AlGaAs material system, with an
%electronic effective mass of m*=0.067m0.
clc;
%code for getting a(n) vector
syms x1 x2 x3 x4 x5 aip ain Vo Eo L d r;
N = 2; %number of barriers
x = zeros(2*N);
%for 2-barrier only
L = 10e-9;
d = 10e-9;
x = [-(L/2+d) -L/2 L/2 L/2+d]';
%x = [x1 x2 x3 x4 x5];
Mi = zeros(2,2);
Mf = eye(2,2);
hbar = 6.626e-34/(2*pi);
me = 9.109e-31;
m = 0.067*me;
syms k1 k2 k3 k4 k5;
k = zeros(2*N+1,1);
V = zeros(2*N+1,1);
ai = zeros(2,1);
af = zeros(2,1);
ai = [1;.28];
%funsies
%E1e = hbar^2*pi*2/(2*m*d^2)*6.241e18
%E1GaAs = hbar^2*pi*2/(2*me*d^2)*6.241e18
%fill the potential barrier potential energy vector
for n = 1:2:2*N+1,
V(n) = 0;
V(n+1) = 0.100*1.602e-19;
end
%loop for many energies
for p = 1:1:1400,
E = p*.0001*1.602e-19;
%for each loop we will calculate the M for going in then out of one
%barrier
k(1) = sqrt(2*m*(E-V(1))/hbar^2);
k(2) = sqrt(2*m*(E-V(2))/hbar^2);
k(3) = k(1);
kmax(p) = k(2);
kmin(p) = k(1);
% pass into barrier 1
A = [exp(i*k(1)*x(1)) exp(-i*k(1)*x(1));
i*k(1)*exp(i*k(1)*x(1)) -i*k(1)*exp(-i*k(1)*x(1))];
B = [exp(i*k(2)*x(1)) exp(-i*k(2)*x(1));
i*k(2)*exp(i*k(2)*x(1)) -i*k(2)*exp(-i*k(2)*x(1))];
M1 = inv(B)*A;
% pass out of barrier 1
C = [exp(i*k(2)*x(2)) exp(-i*k(2)*x(2));
i*k(2)*exp(i*k(2)*x(2)) -i*k(2)*exp(-i*k(2)*x(2))];
D = [exp(i*k(1)*x(2)) exp(-i*k(1)*x(2));
i*k(1)*exp(i*k(1)*x(2)) -i*k(1)*exp(-i*k(1)*x(2))];
M2 = inv(D)*C;
% pass into barrier 2
F = [exp(i*k(1)*x(3)) exp(-i*k(1)*x(3));
i*k(1)*exp(i*k(1)*x(3)) -i*k(1)*exp(-i*k(1)*x(3))];
G = [exp(i*k(2)*x(3)) exp(-i*k(2)*x(3));
i*k(2)*exp(i*k(2)*x(3)) -i*k(2)*exp(-i*k(2)*x(3))];
M3 = inv(G)*F;
% pass out of barrier 2
H = [exp(i*k(2)*x(4)) exp(-i*k(2)*x(4));
i*k(2)*exp(i*k(2)*x(4)) -i*k(2)*exp(-i*k(2)*x(4))];
J = [exp(i*k(1)*x(4)) exp(-i*k(1)*x(4));
i*k(1)*exp(i*k(1)*x(4)) -i*k(1)*exp(-i*k(1)*x(4))];
M4 = inv(J)*H;
Mtot = M4*M3*M2*M1;
af=Mtot*ai;
tt(p) = Mtot(1,1)-Mtot(2,1)/Mtot(2,2);
T2(p) = abs(tt(p))^2;
%T(p) = -abs(af(1))^2;
En(p) = p;
end
figure(1);
%semilogy(En/10000,T);
%hold;
semilogy(En,T2,'r');
title('T(E) Double Barrier, d = 3nm L = 9nm, V = 0.5 eV')
xlabel('Energy (eV)');
ylabel('T(E)');
maybe you can help me with a program?
im trying to plot the transmittion coeffiecet vs energy
for an arbitrary seriers of step potencials with the same step potencial and length
please i have another problem i want to get the graph of energy vs barrier width .i have done the program in wolferm methamatica but cannot find the output .please help
  • · Replies 18 ·
  • · Replies 0 ·
