Simple problem: logarithmic decrement
  • Thread starter Thread starter joriarty
    Logarithmic
The discussion revolves around calculating the logarithmic decrement for a lightly damped harmonic oscillator with a frequency of 10 kHz, where the amplitude decays by 25% over 300 oscillations. The logarithmic decrement was calculated to be 9.59 x 10-4. The correct expression for amplitude as a function of time is A(t) = A0e-9.59t, as opposed to the incorrect formula A(t) = e-9.59t found in course notes, which fails to account for the initial amplitude A0.
  • Understanding of harmonic oscillators
  • Familiarity with logarithmic decrement calculations
  • Knowledge of exponential decay functions
  • Basic physics concepts related to damping
  • Study the derivation of logarithmic decrement in damped oscillators
  • Learn about the physical significance of damping ratios
  • Explore the applications of harmonic oscillators in engineering
  • Investigate the relationship between frequency and damping in oscillatory systems
Students studying physics, particularly those focusing on oscillatory motion and damping, as well as educators preparing materials on harmonic oscillators and logarithmic decrement calculations.
joriarty
Note this is exam revision rather than actual course work worth marks, so there is no need to be deliberately vague :)
The question comes in two parts, regarding a lightly damped harmonic oscillator with frequency 10 kHz and an amplitude that decays by 25% over 300 oscillations. First I am asked to calculate the logarithmic decrement, and then to make an expression that allows the amplitude to be calculated as a function of time elapsed.
δ=(1/N)ln(A0/AN)
The log decrement is 9.59x10-4. Easy. For the second part, simply rearranging the log decrement formula gives AN=A0e-Nδ. Knowing that N = 10,000*t, I get A(t)=A0e-9.59t.
What I do not understand is why my course notes give A(t)=e-9.59t. Why is this answer not multiplied by A0? Mathematically and physically, this does not make sense to me - the amplitude as a function of time definitely does depend on the initial amplitude! Am I right in thinking that is a mistake?
Thanks!
Yes, you're right. If nothing else, the units don't match, that tells you the formula in your notes can't be correct.
Ah good, thanks for confirming that!
