Solving inequalities with three variables
The discussion focuses on solving the inequality \(\frac{1+(\gamma+x(r-\alpha)-1)t}{1+\frac{\gamma+x(r-\alpha)-1}{2}}>0\) under the constraints \(\gamma>1\), \(00\). Participants emphasize the importance of considering two cases based on the sign of the denominator when multiplying both sides of the inequality. The approach involves transforming the inequality into a product form, leading to the conclusion that the product of two expressions must be positive for the inequality to hold. This method simplifies the analysis of the signs of the expressions involved.
  • Understanding of inequalities and their properties
  • Familiarity with algebraic manipulation of expressions
  • Knowledge of the implications of multiplying inequalities by variable quantities
  • Basic grasp of mathematical notation and symbols
  • Study the properties of inequalities involving multiple variables
  • Learn about the implications of sign changes in inequalities
  • Explore algebraic techniques for solving inequalities with rational expressions
  • Investigate the use of graphical methods to visualize inequalities in three dimensions
Mathematicians, students studying algebra, and anyone interested in advanced inequality solving techniques will benefit from this discussion.
matteo86bo
Can you help me solve this inequality for x?
[tex] \frac{1+(\gamma+x(r-\alpha)-1)t}{1+\frac{\gamma+x(r-\alpha)-1}{2}}>0[/tex]
where [tex]\gamma>1, 0<t<1, 0<r<3\alpha, \alpha>0[/tex]
I really don't know where to start ...
I would multiply both sides of the inequality by what's in the denominator, and then make two cases: one in which the denominator is assumed to be positive, and the other in which the denominator is assumed to be negative.
The reason for the two cases is that if you multiply both sides of an inequality by a variable quantity, the direction of the inequality symbol changes if what you multiplied by is negative. If the quantity you multiply by is positive, the inequality symbol doesn't change direction.
For example, 2 < 3, and 2(2) < 2(3), but -1(2) > -1(3).
Well, my way of thinking of solving such inequalities is similar to the one presented by Mark44, I just get to it in a different way. Since it's fairly obvious, that [tex]\frac{x}{y} >0 \iff xy>0[/tex], you can simply write:
[tex](1+(\gamma+x(r-\alpha)-1)t)(1+\frac{\gamma+x(r-\alpha)-1}{2})>0[/tex]
insted of the fraction. And the product of 2 numbers is >0 only if both of them are of the same sign.
Just choose whatever interpretation you prefer.
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 20 ·
