What is the uniqueness of Euler angles?
The discussion centers on the uniqueness of Euler angles, specifically in the zxz convention, and the conditions under which this uniqueness holds, including the implications of gimbal lock. Participants explore references, proofs, and calculations related to this topic.
  • One participant references a Wikipedia article claiming that Euler angles in the zxz convention are unique under certain constraints, except in cases of gimbal lock.
  • Another participant questions the need for a formal theorem statement and proof in the lecture notes that were found.
  • A participant expresses confidence in the theorem but seeks a formal reference, preferring a book or paper over lecture notes.
  • A book titled "Angular Momentum in Quantum Physics" is suggested as a potential reference.
  • One participant describes their understanding of the theorem involving the relationship between the initial and final z axes and the implications for the angles alpha and beta.
  • Another participant proposes a method for verifying the uniqueness of Euler angles through matrix multiplication of the corresponding zxz rotation matrices.
  • There is a discussion about the complexity of verifying the resulting matrix and its uniqueness for different angle values.
  • A participant shares a link to a paper that details the uniqueness of Euler angles and provides calculations for arbitrary rotations.
Participants express varying levels of confidence in the uniqueness of Euler angles, with some agreeing on the need for formal references and others questioning the complexity of the calculations involved. No consensus is reached on the uniqueness under all conditions, particularly regarding the implications of beta values.
Participants discuss the uniqueness of Euler angles with respect to specific ranges of angles and the potential for multiple representations leading to the same rotation matrix. There are unresolved questions about the implications of different beta values and their effect on the uniqueness of the angles.
krishna mohan
Hi..
The wikipedia article on euler angles claims that the Euler angles in zxz convention are unique if we constrain the range they are allowed to take (except in the case of the gimbal lock).
This seems reasonable. But can someone give me a reference... a book or a paper where this is stated?
On searching the web, I was able to find some lecture notes which proved the above assertion. But it did not have references.
Sorry, I don't get a thing... If you found lectures that proved the assertion, then in the same lectures the assertion must also have been stated, in something like this:
Theorem: (assertion)
Proof: (proof)
...or not?
Yes... the proof is there...
And I do believe the statement.. the theorem seems alright..
But just want to be sure...and would like to have something to give as a reference when I use this fact... I cannot give lecture notes as reference...
That is why I need a book or a paper...
I found a book..
Biedenharn, L. C.; Louck, J. D. (1981), Angular Momentum in Quantum Physics, ReadingOne of the references in the wikipedia article...
The way I understand the theorem is like this...
The angle between the initial z axis and the final Z axis is beta...
If we know the position of the initial z axis and the final Z axes, then the two axes together form a plane... beta rotation must have been performed about an axis perpendicular to this plane...
This leaves two choices for the axis of rotation...either along z x Z direction or along Z x z direction... choosing either of the two directions perependicular to the plane as the positive axis...
For one choice, if beta=theta...then for the other choice, beta= - theta...
Also, the two choices are related by N(the line of nodes) going to - N...
Which can be accomplished by alpha going to alpha+ 180 deg...
Thus, assuming beta is not zero or 180... the relative position of z and Z axes can be achieved by two choices of alpha and beta..
1) alpha and beta...
2) alpha+180 and -beta (or 360- beta)...
for beta zero or 180...it is easy to see that alpha angle is inconsequential...We can fix one choice by requiring beta to be between 0 and 180...then alpha is also fixed..
[wikipedia article seems to suggest that beta between -90 and 90 will also work..but this goes against my argument...using mathematica, I got the result that the sets (alpha,beta,gamma) as (135,60,270) and (315,-60,90) gave the same rotation matrix...so this particular point is most probably wrong...]Once alpha and beta are fixed, it is easy to see that gamma is unique... of course all the while assuming that we are considering only the range 0 to 360...
An idea:
(1) write the 3 matrices corresponding the 3 zxz rotations. This is easy.
(2) multiply them in the correct order. Also easy, but you get a lot of sin and cos.
(3) verify that the matrix obtained is different for different values of the 3 angles, in their range. Very easy.
...so...it should be easy! :biggrin: Worth doing this calculation once in a life.
Agreed that the first two steps are simple... even simpler if implemented in something like mathematica..
lt
The resulting matrix is already given in the wikipedia article...
But I do not see how the third step can be easy...
Just have a look at the resulting matrix in wikipedia...
If you copy and paste that matrix here we'll have it a look...:wink:
I think I do understand.. Your idea must be something like the one detailed in the link below...
http://www.gregslabaugh.name/publications/euler.pdf
Yes. The calculation in that link is a bit "longer" of what I meant because, not only it shows the "essential" uniqueness of Euler angles, but it actually calculates them for an arbitrary rotation.
  • · Replies 18 ·
  • · Replies 62 ·
13K
  • · Replies 21 ·
  • · Replies 33 ·
11K
