Projectile: Find initial velocity without time
The discussion focuses on calculating the initial velocity (v0) of snow discharged at a 40-degree angle without knowing the time variable. The solution involves using the equations for horizontal and vertical motion: L = v0 t cos(θ) and Δy = v0 t sin(θ) - (1/2) g t². By solving the first equation for time (t) and substituting it into the second equation, the initial velocity can be determined. The final calculated initial speed is 6.98 m/s, confirming the accuracy of the approach.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions in physics
  • Knowledge of kinematic equations
  • Basic algebra for solving equations
  • Study the derivation of projectile motion equations
  • Learn about the effects of angle on projectile trajectories
  • Explore the use of quadratic equations in physics problems
  • Investigate the role of gravitational acceleration (g) in motion calculations
This discussion is beneficial for physics students, educators, and anyone involved in solving projectile motion problems, particularly those seeking to understand the relationship between angle, velocity, and time in motion analysis.
JJBladester
Knowing that snow is discharged at an angle of 40 degrees, determine the initial speed, v0 of the snow at A. Answer: 6.98 m/s
I have found the x and y velocity and position formulas. Now since I don't know time, should I solve both position equations for time (t) and set them equal to each other to get my only unknown, vi? The quadratic equation for time in the y-dir seems a bit hectic. Is there an easier way to go about trying to find vi?
Start with
L = v0 t cosθ
Δy = v0 t sinθ - (1/2) g t2
Solve the first equation for t and replace in second equation. Solve the ensuing equation for v0.
kuruman said:
Start with
L = v0 t cosθ
I believe this is what you had in mind. The answer matches the professor's answer. Thanks again kuruman!
