Problem on Rotational mechanics / Conservation of angular momentum.
The discussion centers on the problem of determining the angular speeds of two cylinders after slipping ceases due to friction. The equations governing the system include the conservation of angular momentum and the relationship between angular speeds and radii, expressed as w1' * r1 = w2' * r2. The user successfully derived an expression for the new angular speeds using angular impulse but seeks clarification on achieving the correct final expressions for w1' and w2'. The correct formula for w1' is given as ω1' = (I1ω1r2 + I2ω2r1) / (I1r2² + I2r1²) r2.
  • Understanding of angular momentum and its conservation principles.
  • Familiarity with rotational dynamics and the moment of inertia (I).
  • Knowledge of angular velocity and its relationship with radius in rotational systems.
  • Basic grasp of friction's role in rotational motion.
  • Study the principles of conservation of angular momentum in closed systems.
  • Learn about the moment of inertia for various shapes and how it affects rotational motion.
  • Explore the effects of friction on rotational dynamics in detail.
  • Practice solving problems involving multiple rotating bodies and their interactions.
Physics students, mechanical engineers, and anyone studying rotational mechanics and angular momentum conservation principles.
cantgetaname
The figure shows two cylinders rotating about their axes, all the variables involved are shown.
The two cylinders are moved closer to touch each other keeping the axes parallel. The cylinders first slip over each other at the point of contact but slipping finally ceases due to friction between them.
Find the angular speeds of the cylinders after the slipping ceases.
  1. After slipping ceases, if w1' and w2' are new angular speeds then...
    w1' * r1 = w2' * r2
  2. Angular momentum = Iw.
I have succeeding in solving the problem by equating the angular impulse due to friction to the change in angular momentums of both cylinders and eliminating friction force from the two equations.
But I'd like to solve this using conservation of angular momentum as well since it should be pretty straightforward and easy.
Since no external torque acts on the system, conserving angular momentum, I get:
[tex]I_{1}\omega_{1}+I_{2}\omega_{2}=I_{1}\omega_{1}' + I_{2}\omega_{2}'[/tex]
Using this with w1' * r1 = w2' * r2, I get
[tex]\omega_{1}' = \frac{I_{1}\omega_{1}+I_{2}\omega_{2}}{I_{1}r_{2}+I_{2}r_{1}} r_{2}[/tex]
and a similar expression for w2'.
The answer, however, is [tex]\omega_{1}' = \frac{I_{1}\omega_{1}r_{2}+I_{2}\omega_{2}r_{1}}{I_{1}r_{2}^{2}+I_{2}r_{1}^{2}} r_{2}[/tex]
Anyone?
  • · Replies 45 ·
  • · Replies 17 ·
