PAllen
- 2,537
Unique Proper Distance and Its Physical Interpretation
This essay aims to clarify the titled question (in the
affirmative) in response to one of the two variants of proper time
that pervect originally asked about:
"I am aware of two meanings of the term "proper distance" in GR. The
first is when you have points in flat space-time, or space-time that's
locally "flat enough", in which case it is defined as it is in SR, as
the Lorentz interval between the two points. This usage of the term
implies that one is considering short distances, or is working in a
flat space-time. "
I claim to give a unique, physically meaningful, answer to this
without any limitations (assuming some conjectures are true). Of
course, most observers won't measure this proper distance, any more
than they would measure proper time. All would calculate this proper
distance the same, but for most observers it wouldn't 'look like a
distance' because the events are not simultaneous.
Along the way, I will argue that one criteria suffices to be able to
state an extremal property for geodesics, both timelike and
spacelike.
A specific motivation for all of this is a way to give a robust global
definition to J. L. Synge's 'world function' idea from his 1960 GR
book. Basically, WF(p1,p2) is +(interval squared) if p1,p2 have
timelike relation, -(interval squared) if spacelike, and 0 if they could
be on a null geodesic. (Synge deliberately glosses over the issues
below, but explicitly admits he is doing so).
Definitions
spacelike / timelike separation between events - obvious, but just for
completeness: if one event is within the forward or backward pointing
light cones of the other, the relation is timelike; if not, it is
spacelike (well, of course, if it is on the light cone, we could say
light like, but we are not interested in this case; everyone would
perceive and measure this interval as zero).
A spacelike path has ds**2 with (+++-) metric non-negative everywhere.
A timelike path has ds**2 with (+---) metric non-negative everywhere.
A null geodesic (light path) can be considered a degenerate case of either.
Interval along a path is undefined for a path that is neither timelike
nor spacelike. Otherwise, it is obviously integral of ds of
appropriate sign signature.
Geodesic - May be defined either of two ways: a curve that parallel
transports its tangent (formalization of 'straight as possible')
(affine definition); or vary a distance function. For variational
definition, you must vary among all timelike curves or all spacelike
curves (else you get imaginary contributions) (variational
definition). If you mechanically do the variation, getting the Euler
necessary condition, the result is the same as the affine
definition. See end of the essay for a comment on the significance of
this.
NNT path - (non-negative time): Given a coordinate patch, any path in
that patch which is non-decreasing in t coordinate. Obviously, which
paths in spacetime are NNT is strongly coordinate and frame dependent
(for spacelike NNT paths; I believe NNT, not NNT character of timelike
paths is invariant). For both timelike and spacelike geodesics, this
will be key to defining in what limited sense they have local extremal
properties (generally, they have no such properties, even in SR, as I
shall show).
ST foliation (for a given spacelike geodesic): A foliation in which
all points of the given spacelike geodesic are simultaneous. It seems
obvious that this is always possible (in an infinite number of ways).
Geodesic Extremal Conjecture
A geodesic represented in some coordinate system has the following
global property:
1) If timelike, it is a local maximum interval of timelike NNT paths for
that coordinate patch.
2) If spacelike,[EDIT: and if the geodesic is NNT in this coordinate system,] it is a local
minimum interval of spacelike NNT paths for
that coordinate patch. [EDIT: the additional clause about how the spacelike geodesic
is embedded is not needed for the timelike case, because no coordinate system
can change the time ordering of events on a timelike path]
I can easily argue that you can't say more than this. I can't prove
this conjecture, but believe it is true, and would be very interested
if someone came up with a counterexample.
To see that you can't say more than this, only SR is needed. Consider
the timelike geodesic from (x,t) = (0,0) to (0,1) in some inertial
frame with minkowski metric and c=1. Now consider the NNT violating
path (0,0) to (0,.5) to (.01,.1) to (0,1). This has much longer
interval than the so called proper time maximum for a timelike
geodesic. Such reverse timelike deviations can be made as small as
possible, so this violates the possibility of making even a local
maximum claim unless you rule out non-NNT paths, as I propose.
For a spacelike geodesic, consider (0,0) to (1,0) in this
frame. Consider the path (0,0) to (.5,.49) to (1,0). It is all
spacelike and has much lower interval than the geodesic. However, it
is not an NNT path.
Unique Proper Distance Definition
Proper distance between spacelike p1 and p2 is the greatest lower
bound of the intervals along all spacelike geodesics between them.
We can also define proper time between timelike p1 and p2 as least
upper bound of the intervals along all timelike geodesics between
them.
Normally, one might think there is a unique geodesic between two
points. In many non-flat geometries, this is false. I believe the
worst case is exemplified by as simple a case as the 4-sphere. If you
pick a pair of polar points, there is a 3 continuous parameter family
of geodesics between them (all with the same length).
However, I would like to boldly conjecture that the set of geodesic
intervals is never open from above for timelike points, nor open from
below for spacelike points. Then one may claim there is a possibly
non-unique extremal geodesic. All I can say to justify this is that I
can easily construct cases where the set of interval distances for all
paths between points is open, after much effort, I can't conceive of a
case for the set of geodesic intervals.
Accepting this conjecture, the physical meaning of proper time between
two events is easy to state: the proper time along a maximal geodesic
between them (the most 'pure time' path).
Meaning of Unique Proper Distance
Given any minimal geodesic between two spacelike points, and any ST
foliation for it, then the proper distance (already defined) will also
be the 3-space distance using the positive definite spatial submetric
of the ST foliation. This follows from my geodesic conjecture, because
all NNT paths for for this foliation will be in the 3 surface of
simultaneity containing the minimal geodesic.
Put succinctly, the physical meaning of unique proper distance is
the 3-distance in a 3-surface of simultaneity containing a minimal
geodesic between the points.
My claims are that even though we defined proper distance using only
spacetime invariants, and thus computable in any coordinate patch
containing the points, it has a simple interpretation as the 'best
3-distance' between the events. I conjecture that for any minimal
geodesic, and any ST foliation for it, you would find that the unique
proper distance is the 3-distance for that foliation.
Affine vs. variational definition (more)
In Physics, when one does a variation, you typically stop with what a
mathematician would call the first (of several) necessary (but not
sufficient) conditions for a local minimum or maximum. In doing so, I
think all one has established (since it comes out the same as the
affine definition) is that 'being as locally straight as possible' is
the first necessary condition for a local extremum. In other words, a
circuitous route to the affine definition. To me, the affine
definition is more meaningful than attaching meaning to a 'saddle
point'. In particular, physics is generally local, with infinitesimal
changes of state. It makes much more sense to think of light seeking
local straightness than global shortest distance; when they are the
same, it is only because local straightness is the first necessary
condition for global extremal properties. Similarly, for a more
abstract system, using Lagrangian analysis, it makes much for sense to
think of the system as trying to preserve its 'trend' or 'abstract
momentum' than magically seeking a global minimum (that it usually
fails to find anyway).
