Thompson's cathode ray tube experiment
Thompson's cathode ray tube experiment established the charge-to-mass ratio (m/q) of the electron, which was significantly smaller than that of charged ions in a chemical solution. Direct measurement of a single electron's charge was impractical due to the experimental limitations of the time, particularly before Millikan's oil drop experiment, which quantified the charge of an electron. The challenges included the difficulty in isolating a single electron and accurately measuring the charge deposited on the anode. The m/q ratio was easier to determine as it relied on macroscopic measurements of radius, voltage, and magnetic fields.
  • Cathode ray tube fundamentals
  • Understanding of charge-to-mass ratio (m/q)
  • Basic principles of electromagnetism
  • Familiarity with Millikan's oil drop experiment
  • Study the methodology of Millikan's oil drop experiment
  • Explore the principles of cathode ray tube operation
  • Research historical experiments leading to the discovery of the electron
  • Investigate modern techniques for measuring charge and mass of subatomic particles
Physics students, educators, and researchers interested in the historical development of atomic theory and the experimental techniques used to measure fundamental particle properties.
Pranav Jha
Why couldn't Thompson just let one electron fly across the gap before disconnecting the battery and turning off the beam, and then measure the amount of charge deposited on the anode,thus allowing him to measure the charge of a single electron directly?
also, after Thompson found the m/q ratio of an electron (which was very small compared to that of charged ions in a chemical solution) was there any way by which he could have found out if it was either the mass being too small or the charge being too large which led to the small m/q ratio ( i don't think he could have done so because Millikan hadn't determined the value of "q" by then)
That would have been very difficult - and still would be. Can you suggest how he could have measured it? Millikan had enough trouble - months / years of measurements, I believe.
e/m was easier to measure because he 'only' needed to measure macroscopic quantities like radius, volts and a magnetic field.
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 16 ·
