The speed of light in a gravitational field
The discussion revolves around the behavior of photons in a gravitational field, particularly whether a photon gains speed when it travels in free-fall toward the Earth. Participants explore concepts related to the speed of light, gravitational effects, and the implications of general relativity.
  • Some participants propose that a photon, like a mass particle, might gain speed when in free-fall toward Earth, drawing parallels between mass and energy.
  • Others argue that the speed of light remains constant in a vacuum, regardless of gravitational effects, and that mass and energy are not equivalent in the context of gravitational mass.
  • A participant mentions the Schwarzschild solution, suggesting that the coordinate speed of light appears to slow down as it approaches Earth, affecting all objects with a coordinate velocity above a critical speed.
  • One participant discusses the synchronization of clocks at different heights and how this affects the perceived speed of light, suggesting that an observer on Earth might conclude that the speed of light increases due to time dilation effects.
  • Another participant counters that the speed of light remains constant and that any perceived increase in speed is due to the effects of clock synchronization and distance measurement in a gravitational field.
  • Some participants highlight the importance of measurement models and the complexities involved in defining speed in non-inertial frames, emphasizing that different measurement approaches can yield different results.
  • There are mentions of energy gain for photons falling in a gravitational field, with some asserting that this gain manifests as an increase in frequency rather than speed.
  • One participant challenges another's understanding of general relativity, suggesting that meaningful calculations can be made using the Schwarzschild solution, while criticizing a lack of practical engagement with the topic.
Participants express differing views on whether photons gain speed in a gravitational field, with some asserting the constancy of light speed and others proposing that perceived changes occur due to relativistic effects. The discussion remains unresolved, with multiple competing perspectives presented.
Participants note the complexities of measuring speed in gravitational fields, including the effects of time dilation and clock synchronization, as well as the dependence on the chosen measurement models and coordinate systems.
e2m2a
Does a photon gain speed if it travels in "free-fall" toward the earth? A particle of mass gains speed as it free-falls to the earth, and yet, mass is just another form of energy. Light is energy. So, does light gain speed?
No the speed of light is constant (in a vacuum)
Mass is not just another form of energy, energy can be converted into mass and v.v. but gravitational mass is not equivalent to energy.
I suspect you will get probably 10 postings that will only give you information about the speed of light measured locally, which is always c. But of course people deserve more information.
In the case of Earth we can use the Schwarzschild solution as an approximation, in this case, in Schwarzschild coordinates, the coordinate speed of light actually slows down the closer it gets to the Earth. This is not only true for light but for all objects that have a coordinate velocity above a critical speed of:
[tex] 3^{-1/2}[/tex]
This is also the case for the proper velocity (e.g. the velocity wrt local shell observers) but in this case the critical velocity is
[tex] 2^{-1/2}[/tex]
I can understand that relative to an observer on the earth, clocks would tick at the same rate locally at any point above the earth. The problem appears to arise when time measurements are made at different points.
For example, if the observer synchronized two clocks, one at the Earth's surface and one at a certain height above the earth, measured the distance between the two points, and released a photon by some mechanism when the clocks were at the same time relative to the earth-observer's frame, the observer would measure the photon takes less time to reach the Earth for the pre-measured distance traveled by the photon because the clock at the Earth's surface would tick slower non-locally relative to the clock at the higher point. (The observer would be "blind" to this.)
Now, of course, an observer sufficiently far away from the Earth would correctly state that this apparent increase in speed is due to the earth-observer's two clocks are always out of synchronization, the distance traveled by the photon contracted, and the clocks run at different rates, but this is the observations of someone outside of the frame of the earth.
Therefore, wouldn't it be correct for the observer on the Earth to conclude that the speed of the photon increased relative to the Earth observer's frame?
the photon will gain energy, exactly equivalent to the amount it would have gained if it's speed had increased through falling. But the energy gained is in the increase in frequency, not speed, which is constant.
Not really.
The solution to the problem of clocks ticking at different rates at different heights is easy.
If the accuracy of the experiment is limited by the change in clock rates with altitude, you only need to measure the velocity over a smaller altitude change. In the limit as the altitude change approaches zero, there's no effect on the velocity measurement - and in practice, there's very little effect even with relatively large altitude changes.
Curious what you think these speeds mean. Personally, the only thing meaningful is to model a process for measurement in a given scenario. For inertial frames in SR, you can generally dispense with this only because all reasonable approaches agree with commonly chosen coordinate values. In all other scenarios (including non-inertial frames in SR), the scenario and measurement model are crucial, and different choices lead to different answers.
For example, let's say you have two observers on opposite sides of the center of Swarzchild solution. Well, let's immediately choose not to; your results are strongly affected by lensing, and one observer may see the other as a ring, and have a hard time defining simple measuring schemes.
Ok, choose observers on near opposite sides, so a light path between thme passes within e.g. 1.5 times the event horizon (or any other scenario of you choice; but it must be specified). Now propose how to measure speed of light. No single, simple, method can be used. Radar ranging gives you a proper time interval along one observer's world line. To get distance, you typically assume c. That won't do if you're trying to measures it. Ok, define some separate procedure (e.g. idealized parallax distance) to get an apparent distance. Now finally you have a distance and a time. I would be surprised if any such measurement procedure gives results matching any of the commonly used coordinate values.
You seem to have the impression that nothing physical can be calculated from using the Schwarzschild solution. If that is so then you are completely wrong.
If you pay attention I and a few others constantly use the Schwarzschild solution to make physical meaningful calculations on this forum. But I have not seen one single calculation from you using the Schwarzschild solution, or any other solution for that matter, all you seem to do is criticize those who actually do make the effort here.
Curious why you are at all interested in GR if you never want to do any calculations.
I certainly could make physically meaningful calculations about what I wrote above or quote several papers that discuss this situation. If you cannot, then if you want to learn about GR, I strongly suggest you are going to start making an effort. Looking at GR from a 30,000ft height and thinking you know it all without being able to do even simple calculations using the Schwarzschild solution is in my opinion being in a state of delusion.
Relative to any fixed observer, the frequency is constant. Relative to a series of observers at different potentials, the frequency increases as the photon falls, because their clocks are increasingly time dilated.
An easier point of view is to look at momentum. Relative to an isotropic coordinate system, the rate of change of momentum of a test particle of energy E (which could be a photon), in a central weak field is given by the following expression:
[tex] \frac{d\mathbf{p}}{dt} = \frac{E}{c^2} \, \mathbf{g} \, \left ( 1 + \frac{v^2}{c^2}} \right )[/tex]
where g is the Newtonian gravitational acceleration of the field and all of the quantities including c, the coordinate speed of light, are measured in the coordinate system rather than in local space.
Note that as for Newtonian gravity, this expression does not depend on the direction of motion, although unlike for Newtonian gravity, it does depend on the speed.
For a vertical photon, the change in momentum is entirely due to the change in the coordinate value of c.
I assume anything can be calculated from given coordinates, and to understand what coordinates mean, I would do calculations. My question, and it is purely a question is, as someone who has investigated these coordinates, what measurements do they correspond to? That is a perfectly fair and reasonable question, irrespective of whether I can answer it. At the present time, I am not interested in doing calculations (I last did such calculation over 30 years ago, am professionally involved in an unrelated field, and am not motivated to refresh and modernize my skills enough to readily do calcuations. I remain conceptually interested in GR and SR, and recognize the severe limitation of not doing calculations on my own. I will continue to ask questions I cannot answer myself).
Also, I have actually done a few calculations in and for my posts. In some cases, I don't put them in the post because I hate latex. In other cases, I have put results in using crude notations. But generally, I have not and don't plan (for now) to do any systematic calculations.
Getting back to something like the original question on this post, the way I would set up the problem would be:
Assumming R is the event horizon radius, and a worldline of an observer maintaining fixed position 2R, and another world line at e.g. 3R, what speed of light would be measured between them? For me, this would immediately raise the question of what points of the world lines to consider simultaneous, because I can't conceive of measuring distance without this, and can't see how to measure speed without measuring distance. This would immediately put me in a quandary. I would attach no meaning to coordinate time. For one thing, both of these world lines are *extremely* non-inertial observers (think of the rocket g forces required to mainain constant position; barring tidal effects, they would correspond to Rindler observers with very high G, different for each world line; time would run very differently for each world line.). Normally, I would say a simple, light based simultaneity definition is good for many purposes. However, here the goal is to measure the radial speed of light, so I would consider any simultaneity definition involving light to be circular for this purpose and any using the coordinate time of the overall solution to be meaningless for such observers. I would be stuck, but at least I would feel I've asked relevant initial questions. I don't know whether Passionflower has gone through this exercise or not, but I don't see such issues even being mentioned.
For me, I wouldn't see how to use Born rigidity either. The simple definitions I've seen are in terms of a comoving inertial frame. Over a span like 2R to 3R, I would be stumped by the fact that there is no remotely inertial frame that can cover this range distance.
So I would be completely stumped by how to compute what GR predicts for this measurement, but I would at least feel I have asked relevant starting questions.
From the information you give it is very easy to calculate the physical distance and roundtrip time (both in proper time for R2 and R3's clock) in terms of R.
Both yuiop and I have done similar calculations in various topics. This time I really leave it as an exercise to calculate it, it is straightforward and in no way ambiguous.
It is very easy to calculate the coordinate time in terms of R and from this you can calculate the proper time both for R2 and R3.
Another good reason to actually make the calculations and plot them for various actual values of R. If you do that you will find out that you are wrong calling those observers *extremely* non-inertial observers. How 'non inertial' really depends on the actual value of R. For instance if R is very large the proper acceleration of the stationary observers could be much smaller than 1g. Also in another calculation I made last week on this forum I demonstrated that those observers would not exactly correspond to Rindler observers. Also this calculation is trivial, we can immediately calculate the difference from Rindler acceleration in terms of R.
Both yuiop and I have made similar calculations and by using prior postings you can obtain the correct formulas on how to calculate this situation. Basically all you need is the integrated distance between R2 and R3, the integrated coordinate time light takes to go from R2 and R3 and vice versa and on how to convert this time to proper time for both R2 and R3. Again, this is another good example why it is very important to do exercises, both yuiop and I went through these issues but you do not seem to realize it, and the reason I expect is that you have not tried the calculations yourself.
I do not see how Born rigidity is relevant when we want to measure the roundtrip speed of light between two stationary points.
Again measuring the distance and roundtrip speed of light, in proper time for both endpoints R2 and R3 is trivial and unambiguous.
What I would suggest is to measure the speed between points that are closer together, i.e between 2R and 2.0001R, or more generally between R' and R'+epsilon.
Then, you can use a co-located and instantaneously co-moving inertial frame to measure the speed of light, because you've limited yourself to a region of space-time that's small enough that it's essentially flat.
Though if you look at the accelerating elevator problem, there isn't that much of a problem with accelerating clocks, as long as you make the region of your measurement small enough.
The problem of not being able to measure the one-way speed of light without defining how to syncrhronize clocks is a problem left over from special relativity. It has various resolutions - the most common is to measure the round trip speed, and state that you are explicitly assuming isotropy, so that the time is equal forwards and backwards.
Technically, nowadays, the speed of light is defined as a constant. So if you're actually measuring the speed of light, you probably should note that you're using a physical standard meter rod as your reference.
This then gives the question of what mathematical model to use for your physical meter rod - since you are calculating the result rather than performing the experiment. Born rigidity immediately comes to mind, and would be my suggestion. Basically you can figure out the expected stretch in your actual physical meter rod due to the stresses on it, and either call them experimental error, or make a note of how big they are and say that you are compensating for them.
In general coordinate anything doesn't have any particular physical meaning, unless one chooses the coordinates correctly. In the Schwarzschild geometry it happens to have some significance as a killing vector.
Well - if you've done the calculation, you should be able to answer Pallen's questions, of how you define simultaneity, and along what particular curve you integrate the distance.
Just coming up with an answer isn't very convicing, if you can't show your work and define what it is that you're calculating when asked for details.
And Pallen is asking the right questions about the problem setup.
Round trip time is in R2's proper time, for example, is straightforward. For distance, a pair of events considered simultaneous is required to do it any invariant way. What points on the the two world lines should be considered simultaneous?
I was assuming small R to make any effect on speed of light larger.
I also explicitly said it wasn't exactly Rindler, just similar until tidal effects come into play.
Integrated distance between which pair of events at R2 and R3? Which coordinate times at each location would you consider simultaneous? I consider this not meaningful without some operations definition appropriate for, e.g., the non-inertial observer at R2. And given the purpose, this operational definition should not involve light. I disagree that 'same coordinate time' in the Swarzchild coordinates has any meaning as a definition of which point in the R3 world line should be considered simultaneous to a given point on the R2 time line for an R2 observer. Once that is answered, it is trivial, but to me that is a non-trivial question.
Passionflower said:
I do not see how Born rigidity is relevant when we want to measure the roundtrip speed of light between two stationary points.Again measuring the distance and roundtrip speed of light, in proper time for both endpoints R2 and R3 is trivial and unambiguous.
Born rigidity would provide a possible answer, without relying on light, to define which events at R2 and R3 could be considered simultaneous by an observer at R2.
You have still not given any definition of the simultaneity condition. The same Swarzchild t values at R2 and R3 I claim has no physical meaning for a real observer at R2 (at least until validated with some procedure for simultaneity that invovolves neither light nor coordinates).
Yes, that would be much easier. I was trying to accentuate a hypothetical possibility you would measure something different from c in trip up and down the gravity well. I was aiming to see if you could define a measurment over a span where flatness cannot be assumed.
I am familiar with this issue and choosing to ignore it. But even for a two way measurement of lightspeed, you first have to come up with a distance, which seems to require simultaneity, which I couldn't solve, and still don't understant how to solve for a distance like 2R to 3R.
Yes, Born rigidity is what I gave some thought to, but again, for my purpose of measuring lightspeed where flatness is not approximately correct, I didn't see how to apply definitions of Born rigidity I've seen.
I expect it has significance, but not obviously for the purpose here, since it has nothing to do with how an (accelerated) observer held at 2R would measure simultaneity to 3R.
Ok, so we have a Schwarzschild radius of R and two stationary observers R2 and R3.
Then the ruler distance between them is:
[tex] \rho = R \left( \sqrt {3}\sqrt {2}-\sqrt {2}+\ln \left( -\sqrt {3}+\sqrt {3}<br /> \sqrt {2}-\sqrt {2}+2 \right) \right) [/tex]
Now the radar distance T in coordinate time between them is:
[tex] T = R+R\ln \left( 2 \right)[/tex]
The radar distance in proper time for R2 is:
[tex] \tau_{R2} = 1/2\, \left( R+R\ln \left( 2 \right) \right) \sqrt {2}[/tex]
And for R3:
[tex] \tau_{R3} = 1/3\, \left( R+R\ln \left( 2 \right) \right) \sqrt {6}[/tex]
From this you can calculate the (average) speed of light, if you do this you will find that both the coordinate speed and the speed from r1 to r2 (r1 < r2) in proper time is always < c. Only the speed from r2 to r1 in proper time is > c.
This is the key point. Which events are 2R and 3R are used to calculate this? That I what I am asking about (as was Pervect). Given an answer to this, a calculation is easy, but what criterion is used? If one rules out using a light based definition of simultaneity (else circularity for this problem) and Born rigidity (because you don't have approximate flatness), then what do you use? I hope there is a good answer, but you haven't given it.
[EDIT] Actually, given a simultaneity criterion, proper distance between the events at 2R and 3R becomes easy. However, there is still a further question of whether this is what an observer fixed (by rocket thrust) at 2R would measure using some procedure. The follow up question becomes what is induced 3-metric on some spatial hypersurface for the non-inertial observer at 2R.
Events? What events?
I provided the calculations of the ruler distance and the radar distance both for coordinate and proper time between two stationary observers.
I am asking what your definition of ruler distance is? To me it must mean:
There a set of events from 2R to 3R that the observer at 2R considers to be simultaneous. If the observer at 2R is non-inertial, this spacetime path is not generally a geodesic. Given this path, you can then easily compute its proper length. The problem I have is how define, for a realistic observe at 2R, what is the path of simultaneity between 2R and 3R?
[EDIT] What I am concerned about is, for example, the distance between 2R and 3R measured by a free falling observer would (I think) be quite different from the distance measured by an observer held in fixed position at 2R. Thus the idea of "the ruler distance" without further definition, does not make sense to me.
I gave you the answers to the questions you were asking.
I do not believe there is anything I can add as clearly you do not think too highly of my understanding of GR.
Reading Passionflower's #3, it seems to me that the following statement is clearly well defined and relates directly to quantities that can be measured in fairly obvious ways:
For example, the Schwarzschild coordinate r can in principle be determined by measuring the Kretschmann invariant, and the Schwarzschild coordinate t can then in principle be determined by transporting a clock to the appropriate location along a radial path from some reference point and using the Schwarzschild metric to connect the clock time to the Schwarzschild t coordinate, based on the clock's known trajectory (measured in the form of r as a function of proper time).
Since the statement is well defined in relation to actual observables, the next question is whether it's true. The answer is yes, as can be determined by setting the line element in the Schwarzschild metric equal to zero and solving for dr/dt's dependence on r.
The next question is whether the statement is of any physical interest. I don't see any reason to think that it is. It refers to a coordinate velocity, and in general coordinate velocities are of no physical interest.
There are lots of things that are of physical interest that one can calculate from the Schwarzschild metric. Examples include the result of the Hafele-Keating experiment, the precession of Mercury's perihelion, the Shapiro time delay, the deflection of light rays, the geodetic effect, and round-trip propagation times in the GPS system. What all these things have in common is that (1) they relate directly to practical experiments, and (2) they don't depend for their interest on any special coordinate system.
One stationary space station, a known distance from the surface of a planet, could calculate the ruler distance to another stationary space station by measuring the round trip time of light, from the elapsed proper time he could derive the ruler distance by calculating the coordinate speed of light using Schwarzschild coordinates.
Passionflower said:
One stationary space station, a known distance from the surface of a planet, could calculate the ruler distance to another stationary space station by measuring the round trip time of light, from the elapsed proper time he could derive the ruler distance by calculating the coordinate speed of light.
I gave one impractical method by which the statement could be connected in a well-defined way to experimental observables. This is another impractical method by which the statement could be connected in a well-defined way to experimental observables. This has nothing to do with whether or not the statement is of any physical interest.
Another thing to consider is whether or not the statement answers the OP's question. It doesn't, because the OP's question was not asked in terms of Schwarzschild coordinates. The OP naively imagined that the question had a definite answer without regard to any specific coordinate system. The helpful way to answer the OP's question was to point out that the question was ill-defined.
The difficulty I have with this is the coordinate speed of light. Whose? Consider 2 cases: two space stations stationary relative to each other by being in different positions on the same orbiot; two stations under power, held stationary above the Earth as if it weren't rotating. Each of these observer would be quite different frames of reference, and the Swarzchild coordinate speed of light would not seem to have relevance to either of these scenarios.
Different positions in the same orbit?
Let me cut this short: do you think my calculations are right or wrong?
If they are wrong please say what you think is wrong and provide the right answer.
If they are right we are done.
There is no point in arguing with people who keep on going on about 'it is not defined', 'it is too hard', 'define it', 'it depends' and who never bother to write a single formula or do one single calculation, then when you confront them with hard formulas and answer they neither confirm nor deny it is right or wrong, they simply ignore the work and go on as they did before. Perhaps some of those 'high level' folks should take the famous 'shut up and calculate' saying to heart. Implying one knows it all but never showing any work does not impress me at all, on the contrary I fear many of those think they know more than they actually do.
Definition comes before calculation. I have given a set of requirements for a definition of distance from 2R to 3R, without using light (since we want to independently measure lightspeed), and in reference to specific world lines at 2R and 3R. I freely admit I have no idea how meet those requirements. Until that is achieved, there is nothing to calculate.
You give a calculation, but no description of how it relates to the problem (at least the specific problem I've posed, which seems like a good way to make the original post speculation concrete). I assume your calculation is a correct calculation of 'something'. I have seen no evidence that 'something' has anything to do with the problem I've posed.
Within the generalized theory of relativity (GTR), the speed of light is depending on position and on speed of the observer. This has been proved with an accuracy from about 2 per cent in 1966-1968 (radar signals). At the surface of the Earth the variation is about 2 cm per second (to be compared with c = 30 000 000 000 cm persecond).
That is not naive at all, in fact the poster is totally correct.
Below is a plot of light speeds between pairs of static observers (o1, o2) separated a fixed ruler distance of 1 with the radar distance as measured by a clock at observer o1. In the plot you can see the ruler distance (which is 1 for each pair) divided by the radar distance, this ratio is larger for pairs closer to the EH. This is a coordinate free plot as only the ruler distance and proper time is used.
[PLAIN]http://img169.imageshack.us/img169/4331/slowdownoflight.gif
On the x-axis 'd' is the ruler distance to the EH while the y-axis is 1 divided by the radar distance from 'd' to 'd+1' as measured by a clock at a ruler distance 'd' to the EH.
As you can see it is crystal clear that light slows down the closer you get to the EH.
So you are wrong, but I suspect you will simply ignore this graph or this posting or claim I lack understanding.
Below is a plot of light speeds between pairs of static observers (o1, o2) separated a fixed ruler distance of 1 as measured by a clock at observer o1. In the plot you can see the ruler distance (which is 1 for each pair) divided by the radar distance, this ratio is larger for pairs closer to the EH. This is a coordinate free plot as only the ruler distance and proper time is used.
I don't think it's really right to say that using rulers and proper times makes something "coordinate free". After all, inertial coordinate systems are typically defined in terms of a set of rulers and synchronized clocks...anything that allows you to assign a position and a time to any arbitrary event can be treated as defining a coordinate system. (and if two people describe definitions of distances and times using the exact same system of rulers and clocks, but the first uses the words says that the readings on the rulers and clocks define the 'coordinates' of events while the second just talks about 'distances' and 'times', then surely this mere difference in wording does not mean the first is giving a coordinate-dependent description of events while the second is giving a coordinate-independent description)
  • · Replies 42 ·
  • · Replies 51 ·
  • · Replies 25 ·
