Relativity and fuel consumption
The discussion revolves around the relativistic effects on fuel consumption as perceived by two observers: one stationary (C) and one moving (B) at a high constant velocity. Participants explore how fuel consumption is measured and perceived differently in each frame of reference, considering concepts from relativity such as time dilation and length contraction.
  • Some participants propose that the fuel consumption rate measured by C may differ from what B experiences, potentially altered by the gamma factor due to relativistic effects.
  • Others argue that C, as a stationary observer, would perceive B's fuel consumption to be higher than it actually is because B's clock runs slower from C's perspective.
  • A few participants express confusion about how fuel consumption is measured, suggesting methods like measuring the height of fuel in a tank or counting droplets injected into the engine.
  • Some participants note that while C sees a longer distance traveled due to relativistic effects, B will actually traverse a shorter distance due to length contraction.
  • There is a suggestion that despite differing perceptions of fuel consumption and distance, both observers ultimately agree that B finishes the race.
Participants generally agree that relativistic effects influence the measurements of fuel consumption and distance, but there is no consensus on the specifics of how these measurements are made or interpreted. Multiple competing views remain regarding the implications of these effects.
Limitations in the discussion include assumptions about how fuel consumption is measured and the dependence on the definitions of fuel consumption rates in different frames of reference. The discussion does not resolve the complexities of these measurements.
Nebula
I've got a little question here. Basically we've got this guy named "B" driving a straight track with a high constant velocity u. His buddy, "C" on the side of the track measures B's fuel consumption to be dn/dt. Now C filled the tank with just enough gas to make it the distance of the track. What rate does "B" measure for fuel consumption? So what happens to B's car in the end. Does he make it, come up short or what?
-Well here is my crack at it. I'm not exactly sure how dn/dt will look in B's frame. Maybe altered by the gamma factor. One thing for sure is that if B is hauling then obviously relativity takes over. C would see B travel gamma times further. So would C think he ran out of fuel? But in B's frame, the proper time interval... ugh... I dunno. I suppose that's why I'm asking.
Thanks in advance!
Thanks in advance!
How are you measuring fuel consumption? It would seem to be to be difficult to measure the mass of the fuel on a moving train, so I'd guess maybe you're measuring the volume? Or are you conceptually counting molecules (i.e. wanting to know how many moles of fuel are left).
If you just put the fuel in a vertical tank of constant cross-sectional area, and measure the height of the tank, you'll have a measure of the fuel which won't vary with motion, but I assume that's too simple a solution or not what you're looking for?
if you think about it. C is a stationary observer measuring fuel consumption for a moving frame of reference "B" going at speed u. "C" would measure fuel consumption as a lot more than it actually is, since the frame is moving and the guy "B" is having a slower time than outside. Making the fuel consumption less than observed by the outside.
I'm still confused about how fuel consumption is being measured - I'm assuming for the time being one is just looking at a "fuel gage" which is vertical to the direction of the motion, or looking directly at the height of the fuel in a transparent fuel tank.
From the viewpoint of the stationary observer, the clock on the moving train would be ticking slowly. So the stationary observer sees the train as having a slow clock, but moving along a full-length track with no length contraction. So the fuel is flowing longer, but at a slower rate, than the case below.
The moving observer thinks his clock is just fine, thank-you-very-much, but sees a track that's length contracted.
The result is that everyone agrees on how much fuel is used at the end.
I knew I forgot something. The length contraction plays a part. Srry I left that out.
The rate is droplets of fuel injected in the carburetor per second. As to how the heck C measures the fuel consumption from where he standing, I dunno. But I don't think it matters. What matters is that he is going to see a different distance which means his fuel assumptions arent going to work out. Will C see a longer distance? Gamma times further...? therefore we would think the fuel would run out? But physically the distance would be traversed so he would end up at the finish line in the end. :confused:
---> u (constant)
----------------------track---------------------
Pit Stop: C
---> u (constant)
Pit Stop: C
Yes, C would see a onger distance traveled than B actually traveled, but C will also see a different rate of fuel consumption than B. He will see a slower rate than B. In each case, both observers are right when they say that the car DOES wind up finninshing the race.
  • · Replies 101 ·
10K
  • · Replies 16 ·
  • · Replies 84 ·
  • · Replies 30 ·
  • · Replies 20 ·
  • · Replies 26 ·
