Linear Algebra Standard Matrix
The problem involves finding the standard matrix for a linear transformation T defined by the projection of a vector in \(\mathbb{R}^2\) onto a given non-zero vector \(\vec{u}\). The specific vector provided is \(\vec{u} = [1, -1]\).
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to determine the images of the standard basis vectors \(\vec{e_1}\) and \(\vec{e_2}\) under the transformation T, using the projection formula. Some participants suggest that visualizing the transformation could aid understanding.
Participants have acknowledged the correctness of the original poster's calculations, while also noting a minor error in the labeling of equations. The discussion appears to be constructive, with participants providing feedback and affirmations.
The original poster expresses uncertainty regarding the concepts of matrix transformations, indicating a learning phase in their understanding of the topic.
Screwdriver
Let [tex]\vec{u}\neq 0[/tex] be a vector in [tex]\mathbb{R}^2[/tex] and let
[tex]T:\mathbb{R}^2 \to \mathbb{R}^2[/tex] be described by
[tex]T:\vec{v} \to proj_{\vec{u}}(\vec{v})[/tex]
If [tex]\vec{u}=[1,-1][/tex]
Find the standard matrix for [tex]T[/tex]
[tex]proj_{\vec{u}}(\vec{v})= \frac{\vec{v}\cdot\vec{u} }{\vec{u}\cdot\vec{u}}\vec{u}[/tex]
Determine where [tex]T[/tex] sends [tex]\vec{e_1}[/tex] and [tex]\vec{e_2}[/tex]
[tex]f(\vec{e_1})= \frac{\vec{e_1}\cdot\vec{u} }{\vec{u}\cdot\vec{u}}\vec{u}[/tex]
[tex]f(\vec{e_1})= \frac{[1,0]\cdot [1,-1]}{[1,-1]\cdot [1,-1]}[/tex]
[tex]f(\vec{e_1})= [\frac{1}{2},-\frac{1}{2}][/tex]
[tex]f(\vec{e_2})= \frac{\vec{e_2}\cdot\vec{u} }{\vec{u}\cdot\vec{u}}\vec{u}[/tex]
[tex]f(\vec{e_2})= \frac{[0,1]\cdot [1,-1]}{[1,-1]\cdot [1,-1]}[/tex]
[tex]f(\vec{e_2})= [-\frac{1}{2},\frac{1}{2}][/tex]
So does that mean that the standard matrix is
[tex] \begin{bmatrix}<br /> \frac{1}{2} & -\frac{1}{2} \\ <br /> -\frac{1}{2} & \frac{1}{2} \\<br /> \end{bmatrix}[/tex]
[Edited twice for LaTex mistakes]
Seems correct!
This is correct, although your derivation in section 3 has a typo: the fourth through sixth equations should begin with [tex]f(\vec{e}_2)[/tex] rather than [tex]f(\vec{e}_1)[/tex].
It's easier to see where this operation should send the unit vectors by drawing a picture.
Pretty much okay I'd say.
Thank you, gentlemen. We just learned all this crazy stuff about matrix transformations and I'm still a little iffy on the concept :biggrin:
  • · Replies 17 ·
  • · Replies 20 ·
