How Can I Measure Tesla's or Gauss Without a Gauss-Meter?
  • Thread starter Thread starter mvan4310
    Gauss
The discussion revolves around measuring the magnetic field strength in teslas or gauss from an electromagnet without a gauss-meter. Participants explore various methods, calculations, and considerations related to different types of electromagnets, including air-core and iron-core designs, as well as the implications of using different materials for the core.
  • Michael inquires about methods to measure magnetic field strength without a gauss-meter, specifically for a DC air-core electromagnet.
  • Some participants suggest calculating the magnetic field using formulas for solenoids, but note that the calculations may vary for finite length and diameter solenoids.
  • Bob S mentions the use of Hall Effect probes as a potential measurement method and provides links to relevant resources.
  • Michael expresses confusion and requests simpler explanations and guidance on using the suggested methods.
  • Participants discuss the need for formulas that account for off-axis field strength and the complexities introduced by different core materials.
  • Michael raises questions about measuring the magnetic field in various configurations, including multilayer solenoids and curved shapes.
  • Bob S provides links to resources for calculating magnetic fields in different scenarios and mentions the limitations of certain formulas.
  • Michael seeks advanced resources for understanding the principles behind electromagnet design and calculations.
  • Bob S explains that superconducting coils can achieve high magnetic fields but may saturate iron cores, indicating a need for different considerations when using various materials.
Participants do not reach a consensus on a single method for measuring magnetic field strength without a gauss-meter, and multiple competing views and approaches remain throughout the discussion.
Limitations include the dependence on specific configurations of electromagnets, the need for knowledge of core materials to determine permeability, and the unresolved nature of how to apply formulas to multilayer or curved solenoids.
mvan4310
Hello,
Im wondering how I would go about getting the amount of tesla's or gauss from an electromagnet without using a gauss-meter.
Thank you in advance,
Michael
Hi Michael-
Are you talking about an air-core electromagnet, or an iron-dominated one? Is this a dc electromagnet, or an ac (or pulsed) one? Is there a particular place in the electromagnet where you want to know the magnetic field? Is this a real magnet, or a paper design?What is the purpose of the magnet?
Bob S
Would be a DC Air-Core electromagnet. There is no particular place, but having the option to find the strength from any point would be a plus. It would be a real electromagnet. And the purpose is studying electromagnets.
EDIT: Also, I know the strength relies on the permeability of the core, so, is there a list with permeabilities of different materials, both plastic and metal? Also, I know I am getting complicated, but let's say I don't know the materials I am using, how would we get the permeability?
Thank you,
Michael
The magnetic field calculation in post #2 is incorrect for a finite length, finite diameter solenoid coil. Use
http://www.netdenizen.com/emagnettest/solenoids/?solenoid
The simplest way of measuring the magnetic field is a Hall Effect probe, such as the linear ones from Allegro Micro like the A321. See
http://www.allegromicro.com/en/Products/Part_Numbers/1321/index.asp
http://www.allegromicro.com/en/Products/Part_Numbers/1321/1321.pdf
Get the SIP package. You might be able to get a free sample.
Bob S
Ok, now would it possible for you to explain this newbie style. I am looking at it a little confused, but can grasp a basis of it. Now if you can run me through actually using it, I would greatly appreciate it.
Thank you,
Michael
OK, After doing some more research on the formulas, I had found a simpler one:
http://www.netdenizen.com/emagnettest/solenoids/?thinsolenoid"
But that explains how to get field strength on the axis, what about any point around that finite size solenoid?
Thanks,
Michael
Here is an off-axis field-strength formula and calculator for a simple finite-size solenoid. See
http://www.vizimag.com/calculator.htm
It requires evaluating complete elliptic integrals of the first and second kind. There may be a Mathematica application that does this calculation.
Bob S
Ok, Now would something like the link below work as well or not really?
http://www.netdenizen.com/emagnet/offaxis/mmoffaxis.htm"
Thanks,
Michael
Thanks,
Michael
Note that there are no coil dimensions in it. You can use this for a very small single-turn coil field distribution.
Bob S
Ok, I know Mathematica will do the calculations easy, And Wolfram provides and online resource for calculating this, but a quick question, can you explain them a little for me, as far as the inputs in the current context of this thread?
Are you interested in the magnetic field in the gap of a "C" magnet, like in the thumbnail?
Bob S
Now that you ask, I was actually looking into that as well. I was going to end up asking later about other types of electromagnets as well. Because all of the equations I have found have dealt with Solenoids, but now am looking into other types of electromagnets so i don't end up asking this question later on. Do you happen to have equations for various types like the one you have provided?
Thanks,
Michael
Or if you can give me a resource that I can look all this information up in, that would be a great help as well. I am looking around the web, but havnt found much but straight solenoids. If you can provide a solution for a whole variety or a resource to help me out instead of bugging you, I would greatly appreciate it.
Thanks,
Michael
Ok, Another post. Sorry about all of the posting. After looking around a little bit more, I have found some more on the subject, some in a few physics books and other resources. So what I have found is a formula for a solenoid of a specific length, certain number of turns, and such. But out of all of the different solutions, I havnt found any that would include a certain number of layers of turns. So let's say we have a solenoid, we have the equations to figure it out if it was straight with a single layer of N turns. What about x amount of layers of N turns?
And let's say the solenoid isn't straight, and it is curved, in various shapes, would that be evaluated the same way as a straight one if we are looking at the center of the core? Lots of questions, so if you can point me to an advanced book that explains this to me instead of having to type everything down, that will be fine. I am just looking to get a good understanding of the whole process and how each is figured out.
Thanks again,
Michael
This formula gives the correct on-axis field for a finite-lengh multilayer air-core solenoid:
The thumbnail in post # shows a straight multilayer solenoid, with an iron core. Some physics E & M books provide simple magnet designs. Also look at pages 100-101 in Humphries' free online downloadable book on principles of charged particle acceleration:
http://www.fieldp.com/cpa.html
Bob S
Ok, the link for the solenoid, if I wished to use a different type of core, say an iron core or later on some type of superconducting materials, what modifications to the equation would need to be made? I imagine superconducting materials require a bit more then say an iron core, but just curious how to account for different cores and coil materials.
Thanks,
Michael
The magnetic field of a superconducting coil will saturate any iron core. You can easily get B = μ0NI = 3 Tesla in the superconducting coil, but the iron saturates at 1.5 Tesla.
Bob S
  • · Replies 37 ·
  • · Replies 34 ·
