Electric Race Car: What Gauge Wire & Fuse/Circuit Breaker?
The discussion focuses on the optimal gauge wire and fuse or circuit breaker for an electric race car powered by five HR22-12 batteries in series, totaling 60V and 20AH. The recommended wire gauge should minimize heat loss while handling a current of 12 to 20 amps. The resistance calculations provided indicate that using AWG10 wire results in a minimal voltage drop and heat loss, making it a suitable choice. Additionally, the discussion emphasizes the importance of selecting an appropriate fuse or circuit breaker to ensure safety during the race.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with wire gauge standards, specifically AWG
  • Knowledge of battery specifications, particularly HR22-12
  • Basic concepts of circuit protection devices, including fuses and circuit breakers
  • Research the specifications and installation of AWG10 wire for electric vehicles
  • Learn about different types of fuses and circuit breakers suitable for 60V systems
  • Explore calculations for voltage drop and power loss in electrical wiring
  • Investigate local suppliers in Tampa, FL for wiring and circuit protection components
This discussion is beneficial for electric vehicle builders, automotive engineers, and hobbyists interested in optimizing electrical systems for performance and safety in racing applications.
james138698
I am in the process of building an human sized electric race car, and am wondering what gauge wire would best benefit me.
The car will be powered by 5 HR22-12, data sheet attached, batteries in series running at 12 V 20AH each for a total of 60V 20AH. This is an endurance race lasting one hour. Based on this time frame and the battery profile, these batteries should be able to supply somewhere between 12 and 20 amps.
I am wondering what gauge wire would I be able to use, so as to not burn out the wire or have excessive losses from to large a wire.
Also these races require the use of a fuse or circuit breaker. I am wondering which would be the best option for me.
The HR22-12 have a type B1 terminal. I am wondering what is the best way to connect the terminals with the cable.
I am located in Tampa FL, and am looking to get the cabling and fuse/circuit breaker locally.
I greatly appreciate any help given.
While you wait for a more concrete answer to your query, let me help you along with the basics:
Any loss in the wire will be due to the ohmic resistance, R, in ohms
R = ρL/A
where ρ is the resistivity of the material (for copper, ρ = 1.724 x 10-8 Ωm at room temperature), L is the length in meters, and A is the wire cross-sectional area in m2.
If you know how long your wire needs to be, you can calculate the loss P = I2R in that wire segment. For example, a 2 meter long AWG10 (diameter = 0.1019 in = 0.259 cm = 0.00259 m) copper wire would have a resistance of
R = 1.724 x 10-8 Ωm x 2 m / (0.001295 m2) = 6.5 mΩ
The loss (in the form of heat) due to a current of 20A through that wire would then be
P = (20A)2 x 6.5mΩ = 2.6 W
Or, in terms of voltage that would equivalent with a voltage drop over that wire segment:
V = IR = 20A x 6.5mΩ = 0.13V
13K
  • · Replies 29 ·
21K
