Quaternions angle error - correct?
The discussion revolves around the calculation of the angle and axis of rotation between two objects represented by quaternions. Participants explore the mathematical properties of quaternion differences and their implications for determining the shortest rotation needed to align the objects. The conversation includes technical details about quaternion normalization, angle calculations, and potential discrepancies in results.
  • One participant suggests that the quaternion difference calculated as qdiff = q0 * Conjugate(q1) should yield the shortest angle error and the corresponding rotation axis, but finds discrepancies in the results.
  • Another participant notes that the eigen axis of qdiff may not be meaningful, emphasizing that the eigen angle is what matters.
  • A suggestion is made to use the scalar real part or the vector magnitude of the quaternion's imaginary part to determine the angle, recommending the smaller of the two for accuracy.
  • Concerns are raised about the normalization of quaternions, with one participant indicating that the quaternions used in calculations were not unit quaternions, which could affect the results.
  • One participant provides a code snippet to illustrate the issue with angle calculations, noting that the returned angle difference does not match expected values.
  • Another participant explains that the angle can be computed using both the real part and the vector part of the quaternion, providing specific values and matrices to support their claims.
  • There is a mention of using the trace of a transformation matrix to compute the single axis rotation, although it is noted that this method may not be the most accurate in this context.
Participants express differing views on the correct method for calculating the angle and axis of rotation between two quaternions, with no consensus reached on the best approach. Discrepancies in results and interpretations of quaternion properties contribute to the ongoing debate.
Some participants highlight the importance of quaternion normalization and the potential for precision loss in calculations. The discussion also touches on the limitations of certain mathematical techniques, such as using the trace of a matrix for angle determination.
bkenwright
Hi All,
I think this is right, but not sure after doing some of the maths.
If I have two rotated objects...lets say two sticks...and each has a rotation, in quaternions q0 and q1.
Now the difference, can be calculated as
qdiff = q0 * Conjugate( q1 )
Okay?
Of course both my object quaternions are normalized rotation quaternions.
But if I calculated the axis angle for my qdiff, I would have guess it to give the shortest angle error to rotate one to the other?...and the axis would be that by which its rotated to get it?
But I found after some debugging it doesn't seem right...if I work out the rotation angle on the two sticks, the rotation axis is different, and if I do the dot product on the two sticks to get the minimum angle to rotate one to the other, its different than what my qdiff axis angle value gives.
Is there something I' missing?
Many Thanx,
Ben.
Mathematics news on Phys.org
When computing qdiff = q0 q1*, the eigen axis of qdiff doesn't have much meaning. It is the eigen angle that is meaningful.
Hi D H,
thanks for your reply.
What would you say is the best method to get the minimum axis angle between two objects then, if you have two quaternions representing there rotations, and you want to know the axis and angle to rotate on to match the other?
Thanx,
Ben.
One way to get what you want is to use the quaternion "difference" (obviously not really a difference, but it is called that).
I'm assuming here that you have placed your quaternion into canonical form (unit quaternion with a non-negative real part). You can use either the scalar real part of the quaternion or the vector magnitude of the vector imaginary part of the quaternion to give you the desired angle. So, which should you use? The answer is the smaller of the two. The inverse sine is more accurate for angles between 0 and pi/4 while inverse cosine is better for angles between pi/4 and pi/2.
Note that either acos(real part) and asin(||vector part||) will give an answer between 0 and pi/2. If the angle is between pi/2 and pi you will need to subtract the computed angle from pi to yield the correct angle.
Hi D H,
thanks for your help. I've been fiddling around with what you said, but I think I must be missing something. I did a code snippet so you could see...in a few cases the returned angle difference doesn't seem to be correct.
And example case:
// Some normalized rotation quaternions from bodies
Quaternion qrot0 = new Quaternion( new Vector3(-0.15f, 0.68f, 0.15f), 0.68f );
Quaternion qrot1 = new Quaternion( new Vector3(-0.19f, -0.67f, 0.67f), 0.19f );
// Work out the difference
Quaternion qdiff = qrot0 * Quaternion.Conjugate(qrot1);
// Get Axis angle and see what we get (angle is in the w component)
// just acos, then x2
float angle;
Vector3 axis;
ToAxisAngle(ref qdiff, out axis, out angle);
// We get, angle = 3.53900266 ? should be 2.4ish?
// Logic checks to see if our angles are right!
Matrix mat0 = Matrix.CreateFromQuaternion( qrot0 );
Matrix mat1 = Matrix.CreateFromQuaternion( qrot1 );
Vector3 checkDir0 = new Vector3(mat0.M31, mat0.M32, mat0.M33);
Vector3 checkDir1 = new Vector3(mat1.M31, mat1.M32, mat1.M33);
float checkAngle = acos( Vector3.Dot( checkDir0, checkDir1 ) );
// testAngle => 2.471772 /// expected value
bkenwright said:
Hi D H,
And example case:
Those are *not* unit quaternions, not even in single precision land.
Try normalizing your quaternions.
Quaternion qdiff = qrot0 * Quaternion.Conjugate(qrot1);// Get Axis angle and see what we get (angle is in the w component)
float angle;
Vector3 axis;
Should be 2.7316764521066457 ish. I would expect some error from using single precision arithmetic. However, you have done something here that has made you lose all precision.
That is just the angle between the z axes. It is not the eigen rotation angle.
Think of it this way. Consider the matrices A and B:
[tex]A = \bmatrix<br /> \phantom{-}1 & \phantom{-}0 & \phantom{-}0 \\<br /> \phantom{-}0 & \phantom{-}1 & \phantom{-}0 \\<br /> \phantom{-}0 & \phantom{-}0 & \phantom{-}1<br /> \endbmatrix[/tex]
[tex]B = \bmatrix<br /> -1 & \phantom{-}0 & \phantom{-}0 \\<br /> \phantom{-}0 & -1 & \phantom{-}0 \\<br /> \phantom{-}0 & \phantom{-}0 & \phantom{-}1<br /> \endbmatrix[/tex]
By your logic, the rotation between these matrices is zero. That obviously is not the case.
I'd cut the decimal places a few when I dumped the values out, the full values are:
(which are normalized)
Quaternion qrot0 = new Quaternion( new Vector3(-0.1564176f, 0.6895894f, 0.1564176f), 0.6895894f );
Quaternion qrot1 = new Quaternion( new Vector3(-0.1965395f, -0.6792439f, 0.6792439f), 0.1965395f );
All the quaternion rotations are normalized and I check for that in the code.
I draw the two bodies, and extract the extruded body length which I used to check for the angle (as can be seen in the screenshot).
https://www.physicsforums.com/attachment.php?attachmentid=31983&stc=1&d=1297024503
Not sure why it works for smaller angles, less than 90. I'll have a poke around and see why.
Thanx,
Ben
It works for all angles.
In your example, the quaternion product q0q1* is -0.2035261 - 0.4695329 i + 0.5287143 j - 0.6771832 k. Note that the magnitude of the vector part is 0.9790695. The angle can be computed using 2*acos(0.2035261) or by 2*asin(0.9790695), both of which yield 2.731676.
The matrices corresponding to q0 and q1 are
[tex]T_0 = \bmatrix<br /> -1.457167719820518\text{e-16} & -0.42070530006186835 & 0.90719736028047004 \\<br /> 0 & 0.90719736028046993 & 0.42070530006186835 \\<br /> -0.99999999999999989 & 0 & -1.457167719820518\text{e-16}<br /> \endbmatrix[/tex]
[tex]T_1 = \bmatrix<br /> -0.8511340206185567 & 0 & -0.52494845360824727 \\<br /> 0.52494845360824727 & -2.2204460492503131\text{e-16} & -0.85113402061855647 \\<br /> 0 & -0.99999999999999978 & -2.2204460492503131\text{e-16}<br /> \endbmatrix[/tex]
(Note: I use the left quaternion convention, v -> qvq*. If you use the right quaternion convention, v-> q*vq the matrices will be the transpose of the above.)
The product T0T1T is
[tex]T_0T_1^T = \bmatrix<br /> -0.47623185139671659 & -0.77214653675005762 &0.42070530006186801 \\<br /> -0.22084859669227144 & -0.35807659353719445 & -0.90719736028046982 \\<br /> 0.8511340206185567 & -0.52494845360824705 & 3.2355623065705562\text{e-32}<br /> \endbmatrix[/tex]
There are a number of ways to compute the single axis rotation from a transformation matrix. One simple way is to use the trace of the matrix: tr(T) = 1 + 2*cos(theta). The trace of the above matrix is -0.8343084449339111. Thus cos(theta) = -0.91715422246695555, or theta = 2.731676, which is the same as the value calculated using the quaternions.
(Note: The trace is not the most accurate technique in this case.)
9K
  • · Replies 20 ·
