Lorentz Force Question - Where did the y dot come from ?
Physics Enemy
Basically the question is about a penning ion trap. You need to use the equation for the Lorentz Force, which I have. It says the trap electrodes have a potential:
V(x,y,z) = A(2z^2 - x^2 - y^2); There's a superimposed uniform B-Field B = B(z hat)
It then asks you to write down an expression for the z-component of the total electromagnetic force on a particle of charge q, explaining why it doesn't depend on B. I did that. It then says write down the equation of motion. I did that.
It then asks you to do the same thing with the x and y components i.e.) Find the x and y components of the total force, write down the equations of motion, etc.
But the solution shows a y dot in the equation of motion in the x-direction:
x double dot = q/m[2Ax + B(y dot)]
Where did this y dot come into it? Any ideas? I thought a V term is next to B?
Thanks guys, muchly appreciated. :smile:
\dot{y} is the y-component of the velocity.
Thanks, I realized a few mins ago lol. The x and z cross to give the y-direction. For some reason I also thought V was potential, not velocity. It's a little v, of course. :redface:
I actually disagree with their answer, shouldn't it be -y dot? x cross z gives -y, I think ...
The equation you wrote above was for this x component of the force, which contains (\vec{v} \times \vec{B})_x = v_y B_z.
Yes you're right. V x B = (V_y * B)xhat - (V_x * B)yhat + (0)zhat
So the x component is B*ydot, and y component is -B*xdot
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
