Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
gmax137
Education Advisor
Does anyone have any reliable info on the nuclear plants - the reports on the news seem garbled to me.
Edit by Borek:
To All:
Please stick to technical aspects and to things happening at the Fukushima Daiichi NPP.
There are several other threads discussing different aspects of the disaster:
Why is Fukushima nuclear crisis so threatening?
Fukushima radiation detection and measurement
The "more political thread" besides "Japan Earthquake: nuclear plants" scientific one
Japan earthquake - contamination & consequences outside Fukushima NPP
Unless one has direct contact from someone in the plant, the best one can do is the releases by TEPCO or METI, but METI is probably getting it second hand. I haven't seen any official releases from METI though.
TEPCO press releases
http://www.tepco.co.jp/en/index-e.html
http://www.tepco.co.jp/en/press/corp-com/release/11031103-e.html
http://www.tepco.co.jp/en/press/corp-com/release/11031104-e.html
WNN - http://www.world-nuclear-news.org/RS_Massive_earthquake_hits_Japan_1103111.html
IAEA - http://www.iaea.org/newscenter/news/2011/tsunamiupdate.html
WANO is behind the curve.
I have not found any direct press release from METI, but
Fukushima reactor pressure may have hit 2.1 times capacity: METI
http://www.reuters.com/article/2011/03/11/us-japan-quake-tepco-pressure-idUSTRE72A7DB20110311
Woah - not good. That's a big NO-NO.
Problems at a second unit
TEPCO: loses control of pressure at 2nd nuclear plant
http://www.reuters.com/article/2011/03/11/us-japan-quake-tepco-daini-idUSTRE72A8GM20110311
If this is true, I can see a lot of managers getting sacked.
And there is this AP article on Yahoo - http://finance.yahoo.com/news/Japan-quake-causes-apf-1121920057.html?x=0
Is there any real chance at a meltdown or is that just the typical media hype?
At the moment, I don't see a 'real' chance of a meltdown. It is a worst case scenario, which is what licensing space is all about.
Some of the worst case scenarios involve extraordinary, and not necessarily physical real situations. It's a bit like crash testing a car by dropping it out of an airplane at several thousand feet, knowing full well that such a car would never be able to achieve such a velocity on level ground since the engine could not achieve the speed or the tires would blow out well before the speed could be achieved.
Some in the media will sensationalize the situation in order to grab the audience in order to sell commercials for useless stuff. But I digress. :rolleyes:
I'd like to keep the discussion here on the technical aspects - as soon as we learn from reliable sources.
We have the earthquake thread in P&WA.
Ok. This question is pretty 'elementary' but I do not know much about how a NPP works. I read an http://news.yahoo.com/s/nm/20110311/pl_nm/us_japan_quake_nuclear_clinton" that said that the US delivered coolant to Japan. Why does Japan need the coolant? I don't understand how an earthquake and a tsunami can make a NPP lose its coolant? Also, what specific purpose does the coolant serve in the plant (what exactly does it cool) and what would happen if Japan could not get more coolant?
There was some miscommunication. I'm not sure who said what to whom, but apparently Sec of State Clinton mentioned coolant was being flown to Japan. That is incorrect.
They might airlift some generators, but I have not heard any details.
A light water reactor (LWR) uses water coolant under pressure to both moderate the neutrons and cool the nuclear fuel. The Fukushima units are boiling water reactors (BWRs), in which the water is boiled in the core at a pressure of ~1055 psia at Tsat ~ 286 C. The steam is sent directly to a high pressure turbine, and then the exhaust of the high pressure turbine feeds a set of low pressure turbines. The units are about 33% efficient, so about 67% of the heat is rejected through condensers to the environment, which at Fukushima is the sea.
When the reactor shutdowns, there is still some heat being generated from the decaying fission products. "At the moment of reactor shutdown, decay heat will be about 7% of the previous core power if the reactor has had a long and steady power history. About 1 hour after shutdown, the decay heat will be about 1.5% of the previous core power. After a day, the decay heat falls to 0.4%, and after a week it will be only 0.2%." Ref: http://en.wikipedia.org/wiki/Decay_heat#Power_reactors_in_shutdown
So it is important to cool the reactor for several days following shutdown.
The reactor core isolation cooling (RCIC) system in a boiling water reactor (BWR) is a safety system which serves as a standby source of cooling water to provide a limited decay heat removal capability whenever the main feedwater system is isolated from the reactor vessel.
The RCIC requires power from off-site or emergency diesel generators. Well the plant lost off-site power. The EDGs worked for about 1 hour then stopped. Now plant personnel are trying to get power from some other source. It's not clear why the EDGs quit, but they are supposed to work for days.
5.4.6 REACTOR CORE ISOLATION COOLING SYSTEM (BWR)
Ok. Thank you for all of the information. Hopefully they can get the problems resolved soon.
So the coolant system was knocked out, can't they scram the reactor?
The reactor is off but keeps producing heat has radioactive isotopes decay. Basically when it is on it produces a heat and radioactive isotopes which decay to more stable isotopes and give off more heat in the process. You can't turn this second process off, it just keeps going. The amount of heat the second process gives off goes down over time. However that means you have to keep cooling it for a number of days otherwise it would melt into a pile of radioactive goo (and take your expensive reactor with it).
So it's already off and won't explode? Cool, thanks.
It looks like the containment building has exploded. My educated guess is, what they feared might happen at TMI has happened here. The core melted down, releasing lots of hydrogen gas in the chemical reaction with the cladding, which then ignited.
[PLAIN]http://img855.imageshack.us/img855/1472/20mai00383969.gif
Is it safe to assume the winds go towards the Pacific Ocean at the site? In case of an exposed meltdown?
At the time of the explosion, the wind was apparently moving toward the northeast, so any vapor would be carried out to sea.
However, I understand that the building where the explosion has occurred is not associated with containment, but I have not been able to verify this.
From World Nuclear News -
http://www.world-nuclear-news.org/RS_Battle_to_stabilise_earthquake_reactors_1203111.html
Tepco has said that the pressure within the containment of Fukushima Daiichi 1 has reached around 840 kPa, compared to reference levels of 400 kPa.
So pressure in containment is about 8.4 atm rather the 4 atm, the nominal design pressure.
and
Television cameras trained on the plant caputured a dramatic explosion surrounding unit 1 at around 6pm. Amid a visible pressure release and a cloud of dust it was not possible to know the extent of the damage. The external building structure does not act as the containment, which is an airtight engineered boundary within. The status of the containment is not yet known.
and meanwhile at the plant next door, Fukushima Daiini (plant 2)
Unit 1's reactor core isolation cooling system had been operating normally, and this was later supplemented by a separate make-up water condensate system. However, the latter was lost at 5.32am local time when its suppression chamber reached 100ºC. This led Tepco to notify government of another technical emergency situation.
The situation is serious. What has happened, shouldn't have happened.
A TEPCO spokesperson made a statement on Japanese TV about 20 minutes ago. The explosion was supposedly from a buildup of hydrogen around the containment vessel. Apparently, they will flood the containment vessel with seawater (and boric acid?) Does that make sense? They also increased the evacuation zone to 20km. The reporters present didn't seem to like the contradiction of TEPCO's claim that everything was still safe and the expansion of the evacuation zone.
Caveat: my Japanese is not so great, so I may have misunderstood some of it.
EDIT: after checking online, looks like I got most of it right, but it was a government official, not a TEPCO spokesperson
I have to say I don't understand how you can have a hydrogen explosion blowing apart the confinement building, and not the reactor vessel.
I also don't understand how you can let any pressure build up in the confinement building at the risk of rupture if it is slowly. One should prefer steam releases (even contaminated) in order to ensure the integrity of the confinement building if ever the reactor vessel breaks, no ? Now we are not very far from a full release of the core in the environment.
I tried to consult the japanese dose rate surveillance site, but it appears they don't have information for the northern prefectures:
http://www.bousai.ne.jp/eng/
I don't know how they transmit their measurements, supposedly via internet. Did the internet break down completely in the northern part of japan?
I have read much the same in English. So far, I have heard conflicting claims - that the explosion was / was not the containment building. I'd have to find a map of the site to figure out if the explosion was near unit 1 or 4. Unit 1 has the most severe problem, while unit 4 was shutdown cold already. From the picture, it looked like the explosion was near unit 4.
See this article - http://mdn.mainichi.jp/mdnnews/news/20110312p2g00m0dm073000c.html
If the containment is breached with an uncooled reactor, that is very serious.
I have heard that Chief Cabinet Secretary Yukio Edano mentioned cooling unit 1 with seawater, but I don't know where he is getting the information.
Cooling directly with seawater would be a drastic step.
The news from the area is rather sketchy.
The articles are just popping up on Japanese pages. The latest may not be translated to English yet. Every Japanese channel has been showing explanations about the containment vessel and the seawater insertion, so I guess they are going to do it.
More than like the explosion was within the Off-gas system external to the reactor building and below the off-gas vent towers you see. Primarily due to radiolytic hydrogen build-up. Radiation level increases would be due to premature release of radioactive noble gases (Ze, K, I whcih are normal held up for decay).
The suppression chamber at 100 C appears to be within or at the limit of DBA parimeters. It is doing what it is supposed to do cool the water and provide cooling water to the LPCIS. The steam driven HPISs are probably out due to lack of vaible carry over steam in the system. If the diesel generators went south then the LPCIS will be failling.
BTW, 1,000 times increase in radiation levels is not that serious, in that the baseline measurement point is background levels in the control rooms and environment. This results in about 50-100 mrem in control room and 30 mrem immediately external to the plant out to the licensee controlled perimeter. Airborne doses to K, Ze, I would be measurable, but a very small portion of allowed emergency doses.
The reactor in question is I believe a BWR 4 GE designed unit. This model is over 40 years old and use less robust safety system that more modern BWRs use.
Others I have heard a suggesting the hydrogen many have been used in the generator as a lubricant which is housed near the reactor. Any coment on that?
Hydrogen is used to cool generators. Hydrogen gas has good thermal conductivity and low viscosity. The generator is housed in the auxilliary building or turbine hall, which is adjacent to the containment. The generator is not housed near the reactor.
Steam from the reactor is passed in steam lines (massive pipes) to the turbines, and the turbines drive the generator.
Here is a link to some expert testimony:
http://news.yahoo.com/s/nm/20110312/ts_nm/us_japan_quake_experts
They seem to think that everything is under control.
The best statement:
"We don't have any information from inside the plant. That is the problem in this case.
Otherwise, everyone outside is simply speculating.
They certainly are cautious with public announcements.
http://www.tepco.co.jp/en/press/corp-com/release/11031225-e.html
"Today at approximately 3:36PM, a big quake occurred and there was a big
sound around the Unit 1 and white smoke."
otherwise known as an explosion...
and here:
http://www.tepco.co.jp/en/press/corp-com/release/11031224-e.html
this update is called "occurrence of a specific incident stipulated in article 15, clause 1 of the act on special measures concerning nuclear emergency preaparedness"
if you look up article 15, clause 1 in said document you can see that the title of the update basically translates to "occurrence of abnormally elevated radiation levels".
Something I don't understand. How would you get K, Ze & I out of the core without melting part of the fuel?
From what I understand, this type of BWR has instead of a strong outer concrete containment like PWR's have, it has a smaller steel containment dome around the reactor pressure vessel, and a weaker outer containment building. So it is possible that the hydrogen was released from the inner containment, and then blew up the outer containment, but leaving the reactor more or less in tact. However, reports I read indicate they are detecting cesium and iodine in the vicinity, indicative of core damage and release.
The story also said dose rates were 1500 micro Sv/hour 5km away from the plant around the time of the explosion (150 mrem/hr). Far above background levels, but not a health hazard. The situation may have changed since last night though.
I doubt there is enough hydrogen in the generator to create an explosion that big, especially since it is not contained in a pressurized container. The pictures clearly show the containment building exploding, and there is a visible fireball with the shockwave.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
469K
21K
  • · Replies 763 ·
283K
  • · Replies 38 ·
16K
12K
