Electrochemical cells: Is gibbs free energy dependent upon concentration?
The Gibbs free energy of reactions in electrochemical cells is indeed dependent on reactant concentration, as established by the Nernst equation, which links open circuit potential to concentration levels. This relationship suggests that changes in concentration will affect the Gibbs free energy, supporting the intuition that higher concentrations correlate with lower entropy and thus higher Gibbs free energy. Some confusion arises from the distinction between standard potentials and actual free energy changes, but the fundamental thermodynamic principles affirm the concentration dependence. The discussion emphasizes the importance of understanding these concepts to avoid misconceptions in electrochemistry. Overall, the consensus reinforces that Gibbs free energy is influenced by reactant concentration, aligning with established thermodynamic equations.
Topher925
Is the gibbs free energy of some reaction in an electrochemical cell dependent upon reactant concentration? The Nernst equation clearly states that open circuit potential is dependent upon concentration, and basic thermodynamics states that open circuit potential is directly proportional to gibbs free energy, so my intuition says yes. However, some sources (not the most credible) I have found say no. My electrochem text doesn't seem to give a definitive answer.
Approaching the question from another angle, I would think that entropy would be higher with a system with a lower concentration of reactants so given a constant temperature the gibbs free energy should be less via \DeltaG = \DeltaH - T\DeltaS.
Chemistry news on Phys.org
You need to go back to the fundamentals. Entropy tends to increase unless energy is expended to reduce it within a closed system. Therefore, the more concentrated a solution is (be it solid liquid or gas) the less entropy it has. COncentrating and purifying takes enormous energy (heat, financial, & human). Think of it this way - a single crystal silicon, sapphire or diamond has less entropy than a multicrystalline form of the same material. It takes more effort to process these from impure natural materials states into single crystalline form than to make them into multicrystalline form. As they weather, age, or wear in service their entropy is increasing as the 2nd law of thermo holds true.
Please reorient yourself to see the forest through the trees. Take time to review and reflect on the fundamentals. Ask for help. If you are indeed truly overwhelmed, then perhaps you should orient your studies elsewhere. Only you know the answer to that...
looking at this another way. If as you mention delta T = 0 then delta H = 0. Therefore, delta G = (-1)* T * delta S, subsequently if concentration increases delta S is negative. Negative times negative is positive therefore delta G is positive! I hope that simplifies the concept and brings clarity for you. :)
How's the view from up there on your high horse? You've only just reiterated what I already said in my second paragraph.
I didn't mention this.
Maybe the 'no' comes from a confusion with 'standard potentials' and 'standard free energy', something like that?
Your intuition is right. E.g. eliminating complicating factors of different materials, imagine a 'concentration cell', so same electrode material both sides, same ions but 2 different concentrations. If the concentrations on both sides are equal there will be no current nor potential, so that answers you question, it must depend on concentration. For an electric current to flow is a way towards equalising the concentrations. So that will happen unless stopped by an opposing potential. Magnitude RT ln (c1/c2). (Ignoring junction potentials.) You worry about the sign! :biggrin: (However in any given setup this will be clear, so this is just about conventions.)
Same damned RT ln c that you get in every damned chemical thermodynamic thing.
I would not completely agree that anyone whose grasp of thermodynamics is shaky, unconfident, unstable should get out of the field because that would be a lot of people, also in any other field at all nearby they will still need the thermodynamics.
epenguin said:
Maybe the 'no' comes from a confusion...
THANK YOU! I knew that I wasn't crazy, even though some fellow colleges and some people of "academic authority" said otherwise. I really needed a sanity check.
I thought it would be a well understood concept given the popular equation RTln(K) = \DeltaG, but when everyone tells you "no" you start to question your intuition. That darn equation shows up in all of my electrochem, combustion, and stat thermo books.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
