How can I use the Greens function method to solve a PDE with the given equation?
  • Context: Graduate
  • Thread starter Thread starter hunt_mat
    Functions
The discussion focuses on solving the partial differential equation (PDE) given by \(\frac{\partial^{2}u}{\partial t^{2}}+2\frac{\partial^{2}u}{\partial t\partial x}+\frac{\partial u}{\partial x}+\frac{\partial u}{\partial t}+k^{2}u=f\) using the Greens function method. The user correctly formulates the Greens function equation and applies the Fourier transform, leading to the expression \(\hat{g}=\frac{4\pi e^{i\xi X'}}{i\xi (1+2\omega i)+k^{2}-\omega^{2}-\omega i}\). The discussion concludes with the suggestion to utilize contour integration and Cauchy's integral formula to evaluate the Greens function, indicating a solid understanding of the method.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the Greens function method
  • Knowledge of Fourier transforms
  • Experience with contour integration and Cauchy's integral formula
  • Study advanced applications of Greens functions in solving PDEs
  • Learn about the properties and techniques of Fourier transforms in depth
  • Explore contour integration methods and their applications in complex analysis
  • Investigate specific examples of PDEs solved using the Greens function method
Mathematicians, physicists, and engineers who are involved in solving complex partial differential equations, particularly those utilizing the Greens function method for analytical solutions.
hunt_mat
Homework Helper
I have to solve the following PDE:
[tex] \frac{\partial^{2}u}{\partial t^{2}}+2\frac{\partial^{2}u}{\partial t\partial x}+\frac{\partial u}{\partial x}+\frac{\partial u}{\partial t}+k^{2}u=f[/tex]
I use the Greens function method and examine the equation:
[tex] \frac{\partial^{2}G}{\partial t^{2}}+2\frac{\partial^{2}G}{\partial t\partial x}+\frac{\partial G}{\partial x}+\frac{\partial G}{\partial t}+k^{2}G=4\pi\delta (x-x')\delta (t-t')[/tex]
I then write:
[tex] G=\frac{1}{2\pi}\int_{-\infty}^{\infty}g(X|X')e^{i\omega (T-T')}d\omega\quad \delta (T-T') =\frac{1}{2\pi}\int_{-\infty}^{\infty}e^{i\omega (T-T')}d\omega[/tex]
The equation then becomes:
[tex] (1+2\omega i)\frac{\partial g}{\partial X}+(k^{2}-\omega^{2}+i\omega)g=4\pi\delta (X-X') [/tex]
Take the Fourier transform to obtain:
[tex] i\xi (1+2\omega i)\hat{g}+(k^{2}-\omega^{2}-\omega i)\hat{g}=4\pi e^{i\xi X'}[/tex]
Rearrange and take the inverse Fourier transform to obtain:
[tex] g=\frac{1}{2\pi}\int_{-\infty}^{\infty}\frac{4\pi e^{-i\xi (X-X')}}{i\xi (1+2\omega i)+k^{2}-\omega^{2}-\omega i}d\xi[/tex]
Am I on the right track here?
I think that I can find g by using contour integration. Write:
[tex] \frac{1}{2\pi}\oint_{\gamma}\frac{4\pi e^{-iz(X-X')}}{iz(1+2\omega i)+k^{2}-\omega^{2}-\omega i}dz[/tex]
Which can then be evaluated via Cauchy's integral formula:
[tex] g=4\pi ie^{i(X-X')h(\omega )},\quad h(\omega )=\frac{k^{2}-\omega^{2}-\omega i}{1+2\omega i}[/tex]
Thoughts?
  • · Replies 0 ·
