Zz.What is the theory behind Dual Gate MOSFETs and current controlled diodes?
The discussion centers on Dual Gate MOSFETs and current-controlled diodes, highlighting their structure, functionality, and advantages. Dual Gate MOSFETs, particularly in high-speed transimpedance amplifier designs, function similarly to cascode stages, effectively reducing Miller capacitance and enhancing frequency response. The conversation also touches on the application of Dual Gate MOSFETs as variable gain amplifiers in ultrasound scanner designs, noting challenges faced in practical implementations. Additionally, participants seek resources for further understanding of current-controlled diodes.
  • Understanding of Dual Gate MOSFET structure and operation
  • Familiarity with high-speed transimpedance amplifier design
  • Knowledge of cascode amplifier configurations
  • Basic principles of current-controlled diodes
  • Research Dual Gate MOSFET applications in RF and analog circuits
  • Study the impact of Miller capacitance on amplifier performance
  • Explore the theory and applications of current-controlled diodes
  • Investigate design methodologies for variable gain amplifiers
Electrical engineers, circuit designers, and students interested in advanced semiconductor devices and amplifier design techniques.
pottan
Hi,
I want to know more about Dual Gate MOSFETs, i.e, their structure, working, advantages etc... Googling "Dual Gate MOSFET" didn't help at all! So please suggest some sources (online) where I can find more information on them.
Also, where can I find more information on current controlled diodes (i.e, the theory)?
http://www.hamanuals.com/S1/CX7/Articles/Mosfet.pdf
I used Dual Gate MESFET before for high speed trans impedance amp design before. Basically it is like a cascode stage. The advantage is if you ac grounded the top gate, it become a cascode stage and you get rid of the Miller capacitance and increase the frequency response. By changing the bias on the top gate, you can change the gain of the stage.
In the first design in the front end of the ultrasound scanner in Siemens, the first engineer use the dual gate mosfet as a variable gain amp by adjusting the bias of the gate 1. Didn't workout very well, I changed it to a differential amp front end.
pottan said:
Hi,
Welcome to the PF.
Since these are schoolwork questions, you are required to do the bulk of the work on them.
Also, what is a current-controlled diode? Can you provide links to where you have heard about them?
  • · Replies 42 ·
