davenn
- 11,858
Philosophaie said:The sun flips polarity about every 11 years. Its cycle changes the amount of solar activity from little to a peak around reversal time. The next sun reversal will occur in 2012.
Not quite right :) ... you are getting a bit confused, The 11 (approx) year cycle always changes polarity at solar minimum which we have just had and are slowly clawing our way out of. Solar max is at 2012-2013 approx
Philosophaie said:The sun flips its magnetic field every 11 years. This is a common event although the solar flare activity heightens.
http://solarscience.msfc.nasa.gov/predict.shtml
Also not quite right... You need to remember that there are 2 magnetic cycles happening in the sun.
1) ... the reversal of the sunspot magnetic fields 11 years and
2) the reversal of the actual solar magnetic field which is 22 yrs.
That article you cited is referring to the sunspot cycle ( ~ 11 yrs) I say ~ 11 yrs because it isn't a constant length of time. This last cycle transition from cyc23 to cyc24 produced one of the longest minimum period for a 100+ years
cheers
Dave
