Combinatorial Theory (f*h=g*h) g=f?
  • Thread starter Thread starter bloynoys
    Theory
The discussion revolves around the properties of functions, specifically regarding the relationship between two functions f and g when composed with a one-to-one function h. The original poster questions whether the equality f * h = g * h implies f = g, particularly in the context of finite versus infinite sets.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of one-to-one and onto functions, particularly in relation to finite and infinite sets. There is a discussion about constructing counterexamples and the conditions under which f may not equal g.
Some participants have provided insights into the definitions of one-to-one and onto functions, while others have suggested specific examples to illustrate the concepts. There is an ongoing exploration of the relationship between the functions and the nature of the set X.
Participants note the distinction between finite and infinite sets, with specific emphasis on the properties of the function h in each case. The original poster expresses uncertainty about applying these concepts effectively.
bloynoys
If f :X -> X and g:X -> X are functions, and h:X -> X is a one-to-one function such that
f * h = g * h need it be the case that f = g? Prove it or give a counterexample. What if, in addition, X is finite?
I know that f does not equal g for an infinite set but is for a finite set. I know to prove that it isn't when it is infinite set it is the difference between the onto function. I am not sure how to relate that to the problem and build a proof out of it.
Thanks!
Yes, g must equal f in your example, i do not have time to answer your question fully, but I would first say you have not correctly defined a one-to-one function appropriately. Look into defining similarity of classes of a one to one relation.
Thanks!
I think you've got the right idea. If X is finite and h is one-to-one, then h is also onto. So f=g. So if you want to construct a counterexample (and you DO), pick X to be an infinite set and h one-to-one but not onto. Try it.
I am not sure where to go from here. I understand all the basics of onto and one to one functions but am struggling to apply them here.
What I have:
X is an infinite set, h is a one to one function, but not an onto function. Thus when using the function h, the two infinite X sets do not have matching ranges. Thus, there could be two different h values and so f does not have to equal g for infinite sets.
When X is a finite set, and h is one to one, then it has to be onto, thus stating that through the function h, the number is equal to it's output and thus h=h and so f has to equal g.
Is that right? I feel like I am missing something. Thanks again for all your help!
What I have:
Try an example. Pick X=Z, the integers. Define h:Z->Z, by h(x)=2x. Is h one-to-one? Is it onto? Use that to make your counterexample.
