Water density and compressibility
Water is compressible, requiring significant pressure to achieve a density increase of 10 to 20%. At a pressure of 1086 bar (15750 psi), pure water reaches a density of 1205.154 kg/m3, while at 263.835 bar, it achieves a density of 1100 kg/m3, which is approximately 20% higher than typical pressures in a Pressurized Water Reactor (PWR). Salt water can reach a maximum density of around 12700 kg/m3. The discussion highlights the importance of water's density and compressibility in geological processes and its application as a hydraulic fluid.
  • Understanding of water density and compressibility concepts
  • Familiarity with pressure measurement units (bar and psi)
  • Knowledge of hydraulic fluids and their applications
  • Basic geology related to lithosphere and aquifers
  • Research the effects of pressure on water density using the "Water Density Calculator"
  • Explore deep ocean pressure measurements and their implications for marine science
  • Investigate the geological formation of leucogranites and their relationship with water pressure
  • Study the properties and applications of salt water as a hydraulic fluid
Geologists, marine scientists, hydraulic engineers, and anyone interested in the physical properties of water and its geological implications.
Astronuc
Staff Emeritus
2025 Award
Water is compressible, but it takes a lot of pressure to increase the density by 10 or 20%
Deep Ocean pressure measurements
http://nctr.pmel.noaa.gov/Dart/Pdf/Eble_J_atmo_91.pdf
http://seagrant.gso.uri.edu/factsheets/abyss.html
http://www.windows2universe.org/earth/Water/density.html
http://www.csgnetwork.com/water_density_calculator.html
Pure water would have a density of 1205.154 kg/m3 at pressure = 1086 bar
1086 bars (15750 psi) from en.wikipedia.org/wiki/Mariana_Trench
or a density of 1100 kg/m3 at pressure at 263.835 bar, which is about 20% higher than the pressure in a PWR.
Salt water has a maximum density of ~12700 kg/m3.
Was there a question in there?
That's one reason water is used as a hydraulic fluid. Add a little anti-bacterial and presto! Water is also under immense pressure in the lithosphere. Leucogranites form when expelled water melts its new host rock environment - found in places like Tibet. My home state of Texas sits ontop of North America's 3rd largest aquifer - the Gulf Coast aquifer, formed from high pressures of slumping mud wedges going into the Gulf of Mexico basin.
  • · Replies 19 ·
13K
  • · Replies 39 ·
18K
  • · Replies 25 ·
