Does temperature in static particles increase due to gravity?
The discussion centers on the relationship between gravity and temperature in static particles, particularly those within the Earth's core. It is established that while gravity exerts a force on particles, the temperature gain due to gravity is influenced by factors such as pressure, density, and the material's equation of state. As one moves closer to the Earth's core, pressure and density increase, which in turn affects temperature, despite the net gravitational force decreasing at the core. The interplay of these factors is crucial for understanding thermal energy distribution in Earth's interior.
  • Understanding of gravitational forces and their effects on matter
  • Knowledge of thermodynamics, particularly the relationship between pressure, density, and temperature
  • Familiarity with the Earth's internal structure and composition
  • Basic principles of kinetic energy and its transformation into thermal energy
  • Research the equation of state for different materials found in the Earth's core
  • Study the thermodynamic properties of materials under extreme pressure and temperature
  • Explore the effects of gravitational forces on particle behavior in various states of matter
  • Investigate the relationship between pressure, density, and temperature in planetary interiors
Geophysicists, earth scientists, and anyone interested in the thermal dynamics of planetary interiors will benefit from this discussion.
Felian
Hello, I was wondering if particles that have a set position such as for example particles within the Earth's core would experience a temperature gain due to gravity.
If kinetic energy is applied to the particles in the air due to gravity, then kinetic energy should also be applied to particles deep inside the Earth right? But because the particles don't really have anywhere to go I would expect this kinetic energy to be transformed into temperature.
If so, how do these gains in temperature differ based on distance to the core? The total force of gravity would be higher in the core because its average distance to other particles would be lower, but the forces do balance out completely at the exact core because it would come from all sides. How would these forces translate into thermal energy?
Science news on Phys.org
I think you are confusing gravity, density and pressure. The net central force of gravity decreases as you move closer to the center of the earth, but the pressure, density and temperature all increase. How exactly they do this depends on how far down you go, what the local material composition is, and what it's equation of state is.
  • · Replies 23 ·
21K
