SR, LET, FTL & Causality Violation
  • Thread starter Thread starter stglyde
    Causality Ftl Sr
stglyde
In SR. Anything FTL or superluminal can affect causality because there would be some frame where things move backward in time. Since SR is equivalent to Lorentz Ether Theory. And LET is about additional dynamics that occurs in the backdrop of Newtonian absolute space and time. Then how can you model FTL and LET and things moving back in time since the background is supposed to be absolute space and time (where things moving backward is in conflict with its main postulate)? I've been googling this but can't find the information. Thanks.
In SR and LET (the form that is equivalent to SR), every inertial frame is a preferred coordinate system, and in that sense physics in an inertial frame is "as good" as Newtonian absolute space and time (Rindler, p43).
However, what fundamentally distinguishes SR/LET and Newtonian physics, since both have inertial frames or preferred coordinate systems, is the transformation between the inertial frames. In SR/LET, the transformation between inertial frames is given by the Lorentz transforms, whereas in Newtonian physics it is given by the Galilean transform. This is why forms of FTL that violate causality are still forbidden in LET.
What FTL scenario would break causality? I can understand that FTL would mess up measurements of time/distance for that FoR. You mean "move backward" in propertime, not coordinate time right?.
So then what does negative propertime mean? Seems meaningless.
So I think that means FTL breaks the "all physics the same in all FoR", not causality.
I don't know for sure but isn't a postulate of SR that c is the maximum whatever? Seems like this would have to be assumed for the rest of the theory to "work". Said differently SR doesn't (directly) address FTL. Is that right?
https://www.physicsforums.com/showthread.php?t=522200
Picturing the light cone in 3D (as a sphere) was pretty enlighting, including seeing that speed of cause isn't as "important" as it preceeds effect.
See post #133 here (and post #138 for the correction of a typo).
Oh cool that's looks quite detailed. I'll read that on my lunch.
My post above though, is only suggesting that besides the point of whether FTL is possible, it would mean measurements done in that FoR aren't "transferable" / "applicable" to the reality.
I read that post and I don't understand this part;
"If she doesn't receive a message at (0,0), she sends 1 at (8,0). Bob receives that message at (8,10), and replies with 1 at (8,10). So Alice receives 1 at (0,0), and we still have a contradiction."
That part I don't get. I haven't drawn the diagram (will at home). But Ima guess it's because it's a ST diagram where it's always implied that 1ct = 1x. and that slope seprates timelike from spacelike which also happens to illustrate the line between cause/effect.
Any cause effect relationship (from a time perspective, I guess the ONLY way causality can appear broken, but is propertime that's "broken" :smile:) that's on the spacelike side means causality isn't illustrated by the photon path anymore. It would be illustrated by the tachyeon things path.
Said differently a ST diagram where 1ct=1x; 1ct=1x is the speed limit. Seen as the path of a photon (null line) on the diagram. Anything faster and wouldn't ct have to be redefined? I'd say clearly because of cause->effect.
That's my understanding of FTL and causality.
With all that being said, I see you qualified the statement with "...the standard argument for why it can't be possible to send instantaneous messages in a special relativistic universe." Which I take as meaning 1ct=1x in this context.
This short reply is all I have time for today, but I can probably answer follow-up questions tomorrow.
The contradiction is that she both receives a message at (0,0) and doesn't receive a message at (0,0). I'm just making sure to cover all possibilities about what can happen at (0,0). The possibilities are: a) she receives 1, b) she receives 0, c) she receives nothing. And in all three cases, we end up with a contradiction.
The most important part of what "special relativistic universe" refers to is that the simultaneity lines of an observer with speed v have slope v in the diagram. (In a Galilean spacetime, the slope would be 0, and that makes it impossible to obtain these paradoxes).
I know FTL is forbidden in SR.. but we have many examples what would happen if FTL occured... that is.. there would be frames in which it would move backward in time. I just want to know how to model it in LET. If you don't know what I mean. Look at the following web illustration of what would happen if FTL occurred in SR.
http://sheol.org/throopw/tachyon-pistols.html
Now. How do you model the same thing using LET (just for sake of discussion because we knew there was no FTL).
That's an interesting question that I don't know the answer to, because I've never studied LET or spent any significant time thinking about it. Is there a way to see that my Alice/Bob scenario is logically inconsistent in LET too? If someone who reads this has thought about such things, I wouldn't mind being told the answer so that I don't have to think about it. :smile:
In LET only one inertial frame is absolute frame. You just don't know which one.
For that reason Lorentz transform is not symmetric - it only appears symmetric.
And as there is only one "real" simultaneity in LET there is no paradox with FTL particles.
That was my initial reaction, but than I thought "that would mean that the two theories aren't equivalent". Aren't they supposed to be?
In https://www.physicsforums.com/showpost.php?p=2588832&postcount=133 & https://www.physicsforums.com/showthread.php?p=2588832#post2588832 you already give the coordinates in Alice's frame. Since you only use one inertial frame for the coordinates, it is already in LET form. It looks like Bob is able to send signals back in time from (8,10) to (0,0).
OK, but is there something in the theory that suggests that if Bob uses the same kind of device as Alice to send messages, his answer will go back in time?
Ah, but you have to have meaningful description for FTL particle in SR to say that they are not equivalent.
Wordline of FTL particle propagating at constant speed is spacelike. That means that we can find inertial reference frame where it propagates from A to B, another inertial reference frame where it propagates from B to A and another one where it "happens" all at once along the path from A to B.
Now to send some information you have to perform some modulation of FTL signal and you have to be able to "read" that modulation of signal. Now the question is in what direction this modulation will propagate? Form A to B or from B to A? I would say that SR does not give you answer about that.
Yes. The Lorentz transform still applies between two arbitrary frames in LET. So use the Lorentz transform to generate a causality violation as normal. Now, the speed of the aether is unknown, so boost your solution by an unknown v. You will see that causality is violated in the aether frame regardless of the value of v.
Any scenario which violates causality in SR violates causality in LET. The only way around it is to have the aether measurably violate the principle of relativity (eg tachyonic signals go at 2c, but only in the aether frame)
They are not equivalent. There is no spacetime in LET, so in LET the Lorentz transform is something that applies to objects with respect to a single arbitrary reference frame. So time dilation and length contraction are properties of an object based on relative motion with respect that frame. Thus, this means that all particles subject to relativistic speeds must also have internal degrees of freedom (if they length contract), contrary to the view of "indivisible" particles. The is no speed limit in LET if we assume that this length contraction is a weaker or non-existent effect for some particles, such as neutrinos. The forces we know about travel up to a limit, perceived locally as c. So LET combined with the facts concerning the gravitational delay (c.f. Shapiro Delay) of light would require that the speed of light be variable even in the vacuum of space from the point of view of the single preferred frame of LET.
In other words. Anything FTL in LET would have objects that have negative contraction and negative time dilation? Is this what you mean that objects can still go back in time in LET?
Anyway. You said there was no spacetime in LET. Are you saying the length contraction or time dilation are properties of objects that occur in Newtonian absolute space and time? But PeterDonis wrote the following:
"I'm not familiar enough with Lorentz's papers to know whether he thought at first that his results could be explained by just adding on length contraction to Newtonian space and time. But I don't think it really matters, because Einstein's 1905 relativity papers did make it clear that that wasn't possible; that to make kinematics consistent with the speed of light being constant for all observers, you *had* to give up Newtonian space and time."
What do you think?
I can't think of any reason why this should be. So perhaps SR and LET are not equivalent in the realm of FTL. My inclination to try to formulate a LET tachyon was to set up a tachyonic version of Maxwell-like wave equations. Unfortunately, they don't seem to have the properties of particle tachyons in SR, at least judging by http://www.desy.de/user/projects/Physics/ParticleAndNuclear/tachyons.html. OTOH, do tachyonic waves automatically enforce FTL without paradoxes, since wave FTL requires nonlocality?
I'm saying, "[L]ength contraction [and] time dilation are properties of objects that occur in [N]ewtonian absolute space and time."
What do you think?
http://en.wikipedia.org/wiki/Relativity_of_simultaneity
Wikipedia said:
A mathematical form of the relativity of simultaneity ("local time") was introduced by [[Hendrik Lorentz]] in 1892, and physically interpreted (to first order in ''v/c'') as the result of a synchronization using light signals by [[Henri Poincaré]] in 1900. However, both Lorentz and Poincaré based their conceptions on the [[Lorentz ether theory|aether]] as a preferred but undetectable frame of reference, and continued to distinguish between "true time" (in the aether) and "apparent" times for moving observers. It was [[Albert Einstein]] in 1905 who abandoned the (classical) aether and emphasized the significance of relativity of simultaneity to our understanding of space and time. He deduced the failure of absolute simultaneity from two stated assumptions:
* the [[Principle of relativity#In special relativity|principle of relativity]]–the equivalence of inertial frames, such that the laws of physics apply equally in all inertial coordinate systems;
* the constancy of the [[speed of light]] detected in empty space, independent of the relative motion of its source.
I would drop the first assumption immediately and say that the second is also questionable. Dropping the first assumption is sufficient to reject PeterDonis' argument. As for the second one, I do think that anytime that light changes speed due to the nature of the medium, it must refract one way or another. Light travels slower in highly refractive media, and faster in relatively non-refractive media. Our time keeping devices are not altered by such media in the same way that light is. This might also be true in the space between stars, but in the opposite way.
What do you think?
Instead or reading what PeterDonis wrote you might want to read this Lorentz ether theory
and Einsteins 1905 relativity paper - On the Electrodynamics of Moving Bodies
I we look at this quote from Einsteins 1905 paper:
"The introduction of a “luminiferous ether” will prove to be superfluous inasmuch as the view here to be developed will not require an “absolutely stationary space” provided with special properties, nor assign a velocity-vector to a point of the empty space in which electromagnetic processes take place."
it says "superfluous" not "contradictory".
And in 1920 Einstein wrote in some letter that:
"More careful reflection teaches us, however, that the Special Theory of Relativity does not compel us to deny the Aether."
So I would like to encourage you to take "more careful reflection".
Really? You would drop two assumptions that are experimentally verified to a very high accuracy? (Unless by "dropping the assumptions" you actually mean "dropping the SR framework that predicts experimental results in accordance with these assumptions, and using the LET framework instead, that predicts exactly the same experimental results but claims it's for an entirely different reason.")
Also, you have mis-stated the first assumption slightly. Here's how it should read: "The laws of physics can be expressed in a form that is the same in all inertial coordinate systems." (This is the SR version; the GR version expands it to say that the laws of physics can be expressed in a form that is the same in *all* coordinate systems, inertial or not.) The first assumption does not rule out the possibility that there may be other ways of expressing the laws that look different in different inertial coordinate systems; it just says that you don't have to use such expressions. As I understand it, LET is an alternate expression of the physical laws that privileges some particular inertial coordinate system (but we don't know which one) as being the "absolute rest frame", such that the laws of physics look simplest in that frame. So LET does not really drop the first assumption.
See above; you haven't actually dropped it. Unless I'm misunderstanding something about LET and it actually makes different predictions than standard SR does, in which case it's falsified by experiment.
(Edit: See additional comment in my next post.)
Is this just handwaving, or does LET actually model light traveling in vacuum this way? If so, does this model make different predictions than standard SR? If it does, again, it's falsified by experiment.
If you think so, you have misunderstood my argument. The local Lorentz invariance of spacetime, as opposed to Galilean invariance, is an experimental fact, not an assumption. Newtonian physics requires Galilean invariance; you can't change Galilean invariance to Lorentz invariance just by "overlaying" additional structure on top of Newtonian physics. You have to get rid of the underlying Newtonian structure altogether and replace it with the Lorentz invariant kinematics.
They may not be equivalent from a metaphysical or philosophical standpoint, but they are experimentally equivalent. Both SR and LET use the Lorentz transforms to make their experimental predictions, therefore they both always produce the same predictions.
If you believe that in some circumstances the Lorentz transform would not apply then you are no longer discussing LET, but perhaps some sort of generalization or extension of it.
It doesn't appear to me that LET requires that every kind of matter be subject to contract to arbitrarily small lengths when approaching c - only those obseved to do so. If infact it does not forbid variations of this contraction (i.e. some not patterned after the "Lorentz contraction"), then it would seem that it does not forbid faster than light travel so as the contraction toward zero length could occur at a higher speed than c, or perhaps not at all.
And what equations would it use to predict the results of experiments?
That's an open question, but providing answers for this is not appropriate for this forum at this time.
It is not, in fact, an open question. LET uses the Lorentz transform to make it's experimental predictions. If you are using some other equation then you are not using LET, by definition.
So are you trying to imply that LET does "forbid variations of this contraction (i.e. some not patterned after the 'Lorentz contraction')"? In other words, does the logic of LET entail exclusivity of the Lorentz transform, making any other transform allowing FTL incompatible with LET?
Yes, the LET uses the Lorentz transform to make its experimental predictions. Therefore "variations of contraction" that are not derived from the Lorentz transform are inconsistent with LET.
Newtonian structure says there is absolute space and time. Overlaying additional structure on top of it means that when an object moves, it physical contracts and slow downs which has same effect as length contraction and time dilation... which falls under Lorentz Transformation. Therefore by merely adding physical length contraction and time slowing down in moving objects over Newtonian structure. This LET like mechanism produce the same prediction as SR. Hence by this mechanism one can change "Galilean invariance to Lorentz invariance just by "overlaying" additional structure on top of Newtonian physics.
  • #31
I'm not so sure how you come with that conclusion. How exactly are "variations of contraction" inconsistent with LET? That's like saying that the existence of a black swan is inconsistent with an argument that depends on the existence of white swans.
  • #32
The black swan analogy doesn't make sense to me.
Please answer this clearly: Do you agree or disagree that LET uses the Lorentz transform to make its experimental predictions?
  • #33
I agree. But I disagree with the implications. The way I see it, this simply means that "LET uses the Lorentz transform to make its experimental predictions". It doesn't entail exclusion of other transforms to make its experimental predictions. Likewise, one can state that "Science uses the Lorentz transform to make its experimental predictions". Again, such a statement does not exclude other transforms be used to make experimental predictions in science.
  • #34
I would like to say that I agree with DaleSpam. If you speak about different transformation than Lorentz transform then don't say that this is LET you are speaking about. Then this is you own speculation that uses LET as a starting point.
You can arrive at LET if you assume that structure of matter is maintained by means of electromagnetic interactions that all propagate at speed of light.
If you want to modify LET you have to introduce some additional factors that will complicate picture. So this modification can not be viewed on equal level as original simple version.
  • #35
And that information can propagate with infinite velocity, so that Galilean invariance holds. If that isn't part of your definition of "absolute space and time", then you are not talking about "Newtonian structure", you're talking about something else.
Doing this is *not* overlaying additional structure on Newtonian physics; it is *changing* the causal structure of Newtonian physics, i.e., it is *destroying* the old causal structure and replacing it with a new one. SR doesn't just introduce length contraction and time dilation; it introduces a finite speed of light (i.e., finite speed of information propagation). That changes the causal structure of spacetime; events that would have been causally connected under Galilean invariance are no longer causally connected under Lorentz invariance. You can't do that with just an "overlay".
  • #36
Such a theory (one that changes its method of making predictions on a whim) is non-falsifiable and therefore non-scientific. If you want to have a scientific theory then you have to make a specific prediction that is subject to experimental falsification. You should read up on falsifiability.
With regards specifically to LET, can you provide any authoritative source claiming that the LET uses any other mathematical framework besides the Lorentz transform?
  • #37
stglyde said:
[Overlaying additional structure on top of it means that when an object moves, it physical contracts and slow downs which has same effect as length contraction and time dilation... which falls under Lorentz Transformation. Therefore by merely adding physical length contraction and time slowing down in moving objects over Newtonian structure. This LET like mechanism produce the same prediction as SR.] Hence by this mechanism one can change "Galilean invariance to Lorentz invariance just by "overlaying" additional structure on top of Newtonian physics.
Lorentz invariance is a property of spacetime. LET does not have spacetime. Time and space are not linked in LET. There is no such thing as a spacetime interval in LET. In LET, causal structure is only "real" in the preferred inertial frame of LET. So LET cannot have Lorentz invariance. In the strict sense of the way the term "Lorentz transformation" is now used, LET cannot even have a Lorentz transformation, because this term now refers to the transformation of space and time as described by SR.
LET cannot be accurately described as a theory of "Lorentz transformations". The Lorentz-FitzGerald contraction hypothesis applied to an "immobile aether" is what LET ultimately relies upon to make predictions also made by SR. That contraction was originally conceived in three dimensional Euclidean space, no spacetime.
  • #38
In light of my recent post just above that the Lorentz transform involves spacetime, while LET has no spacetime, I retract my agreement. Now my corrected response is: I disagree.
  • #39
OK, thanks for the clarification. That at least crystallizes the real issue: this is simply a misunderstanding of LET. I would be glad to provide references if you wish, but LET does in fact use the Lorentz transform to make its experimental predictions.
  • #40
I would like to see one reference that LET involves spacetime. Thanks.
  • #41
Which inertial frame is that? Nobody knows, nor does LET give any way of finding out. So this statement may sound good, but doesn't actually say anything useful.
Also, unless LET claims that whether two events are causally connected is observer-dependent (which would contradict SR), LET and SR must agree on which pairs of events are and are not causally connected. So the above statement is also irrelevant, since SR doesn't care whether the causal structure is "real" in every inertial frame; it only cares that the causal connection, or lack thereof, between any given pair of events is invariant.
How do you make these predictions if you don't know which inertial frame is the "immobile aether" frame?
What about time dilation?
  • #42
You don't need spacetime to have a transform. E.g. the Galilean transform. I never claimed that the LET uses spacetime, only that it uses the Lorentz transform.
Whether you take Minkowski's approach and combine space and time into spacetime or you take Lorentz's approach and keep them separate, the experimental predictions are determined by the Lorentz transform. Spacetime is simply an elegant way of expressing the Lorentz transform, not a necessary part of it.
  • #43
As it was long ago conceived at the prior turn of the century, LET and SR have to agree on the predicted observational measurements.
However, whether those observational measurements actually reflect "causality" or just "order of appearance" is where LET begins to stray from SR (or vice versa). SR invokes relativity of simultaneity. LET rejects relativity of simultaneity.
In LET, time dilation was conceived without the spacetime metric.
http://en.wikipedia.org/wiki/Lorentz_ether_theory
A substantially extended work (the so called „Palermo paper“)<ref group=A name=dynam>Poincaré (1906)</ref> was submitted by Poincaré on 23 July 1905, but was published on January 1906, because the journal only appeared two times in a year. He spoke literally of "the postulate of relativity", he showed that the transformations are a consequence of the [[principle of least action]]; he demonstrated in more detail the group characteristics of the transformation, which he called [[Lorentz group]], and he showed that the combination <math>x^2+ y^2+ z^2- c^2t^2</math> is invariant. While elaborating his gravitational theory he noticed that the Lorentz transformation is merely a rotation in four-dimensional space about the origin by introducing <math>ct\sqrt{-1}</math> as a fourth imaginary coordinate, and he used an early form of [[four-vector]]s. However, Poincaré later said the translation of physics into the language of four-dimensional metry would entail too much effort for limited profit, and therefore he refused to work out the consequences of this notion. This was later done by Minkowski, see "The shift to relativity".<ref group=B>Walter (2007), Kap. 1</ref>
  • #44
What does this mean? Does it mean that the "order of appearance" of two spacelike-separated events is not different for different observers in LET? How does that work?
Or does it just mean that LET admits that the "order of appearance" of spacelike separated events can be different for different observers, but still claims those events can be causally connected? This would mean that LET denies that invariant time ordering is a necessary condition for causal connection. This would not necessarily contradict SR, since strictly speaking, SR's definition of "causality" only requires that spacelike-separated experiments must commute (i.e., the results must be independent of which experiment occurs "first"); it does not require that we absolutely rule out causal connection between spacelike-separated events. (For example, the quantum experiments that violate the Bell inequalities are consistent with SR.)
If you don't mean one of the above, but you are saying that LET's definition of "causal connection" is different from SR's, then I don't understand LET's definition of "causal connection".
Yes, so was standard SR. That's not what I was asking. You said LET conceives length contraction in 3-dimensional space, which obviously can't hold for time dilation. So how does LET conceive time dilation?
  • #45
Exactly. The concept of spacetime was developed after the fact -- and by Poincare, not Einstein. The two key Lie groups that pertain to special relativity are the Lorentz group and the Poincare group. Lorentz and Poincare: These just happen to be the two key people behind Lorentz Ether Theory. The concept of spacetime as an algebraic structure was developed first for LET, and then carried over to simplify/solidify the description of special relativity. That wasn't that hard to do because mathematically, LET and special relativity are one and the same. The two theories differ only in their postulates. Physically, they are not one and the same because we physicists have this nifty little tool called Occam's razor.
  • #46
The difference between LET and SR is in the second postulate. Einstein claims that light propagates at c in any rest state whereas LET postulates that light propagates at c only in one rest state. Since we cannot know what that rest state is, LET interprets virtually all rest states as being in inertial motion with respect to that one preferred rest state and therefore experiencing time dilation and length contraction (but of some unknowable amount). SR interchanges these two rest states, any rest state is exactly like the LET preferred absolute rest state of the ether where the speed of light is c and so experiences no time dilation or length contraction--all other frames in relative inertial motion are the ones that experience the time dilation and length contraction.
Aside from that one ever-so-minor point of view, there is no difference between LET and SR.
  • #47
Exactly. And this is a direct result of the fact that both use the Lorentz transform to predict all experimental measurements.
Are you back in agreement now?
  • #48
Einstein's postulate that the speed of light is the to all observers is simply stated. Seemingly paradoxical, but simple. Compare that to the ad hoc LET postulates of length contraction and time dilation.
But that wasn't what ultimately did LET in. What did it in was that the rest frame of the luminiferous aether, while central to the theory, was inherently unknowable and untestable.
  • #49
OTOH, couldn't one say LET "did itself in" (the part about there being only one preferred frame) by being successfully predicting:) the existence of the whole class of Lorentz inertial frames?
  • #50
I suppose.
OTOH, telling physicists that the central thesis of LET was inherently unobservable and untestable was probably a bit too much in and of itself.
12K
