Last Steps of the Quadratic Sieve (Matrix Onwards)
  • Thread starter Thread starter My Name Is D
    Quadratic
The discussion centers on the final steps of the Quadratic Sieve algorithm, specifically focusing on the Gaussian elimination of a matrix derived from the factor base and how to identify combinations of rows that yield a square number. Participants explore the relationship between the matrix and the factor base, as well as the implementation of these concepts in programming.
  • Homework-related
  • One participant seeks guidance on how to relate the Gaussian form of the matrix back to the factor base to find a square number.
  • Another participant explains that a combination of rows producing all even numbers corresponds to a square number when working mod 2.
  • There is a suggestion to perform Gaussian elimination on the original matrix while tracking row combinations to identify suitable combinations that yield squares.
  • Participants discuss the need to XOR the entire row for other rows with a one in the pivot column, emphasizing that the choice of pivot can be arbitrary.
  • One participant expresses difficulty in generating correct results in their program, noting that derived values do not always lead to factors despite being squares.
  • Another participant provides an example involving specific primes and smooth numbers, detailing the elimination process and the resulting matrix transformations.
Participants generally agree on the method of using Gaussian elimination and the importance of row combinations to achieve the desired results. However, there are differing opinions on specific implementation details and the effectiveness of the approach, particularly regarding the generation of factors from derived square values.
Some participants note that the example matrices discussed are small, which may limit the visibility of certain behaviors in the elimination process. There are also mentions of specific primes and smooth numbers that may not yield the expected factors, indicating potential limitations in the approach.
My Name Is D
Hi. I've got the matrix from the Quadratic Sieve down to Gaussian Form and I'm wondering how to find the factor base which leads to a square number now.
The Factor Base:
$${29,782,22678}$$
The original Matrix:
\begin{pmatrix}
0 & 0 & 0 & 1\\
1 & 1 & 1 & 0\\
1 & 1 & 1 & 1\\
\end{pmatrix}
The Matrix after being transposed and Gaussian Elimination:
\begin{pmatrix}
1 & 0 & 1\\
0 & 1 & 1\\
0 & 0 & 0\\
0 & 0 & 0
\end{pmatrix}
I know I have to relate this back to the factor base somehow? I can see that $$29*782*22678 = 514291684 = 22678^2$$ But how does that relate to the matrix? I'm trying to implement it in Java and am using the Matrix package JAMA for computations. Any help would be much appreciated!
You're looking for a combination of the rows which produces all even numbers (which, since this matrix is exponents, corresponds to a square number). Working mod 2, that's all zeros.
This set is "lucky" to have a solution at only three rows and four columns, but generally there will be a suitable subset if there are more rows than columns.
I think you can just eliminate down from the top, picking the first non-zero column in each row and xor-ing to any rows below that have 1 in that column, and keeping track of which rows have been summed in each case. Of course if I add row 1 into rows 3 and 4, and I later add rows 3 and 4, I have eliminated row 1 from that sum because adding twice is the same as not adding at all, working mod 2.
In your particular case, the numbers are coded in the matrix by the exponents of 2, 17, 23 and 29. Adding all three rows means that the product of the three numbers has exponents of 2, 2, 2 and 2 for those primes and is thus the square of 2*17*23*29.
[ for this example, which is actually worked in Wikipedia, http://en.wikipedia.org/wiki/Quadratic_sieve , there is actually another row that could be in the matrix: 0, 0, 2, 0 :but of course this works on its own without combining with any other row, so does not illustrate the method. I found a similar issue when trying out 559423. Note that dividing out the base primes should be exhaustive when sieving - if dividing out 7, for example, do it repeatedly, and keep track of the total factor count separately from your mod 2 elimination matrix. ]
Specifically on what to do to find the suitable combination, you could do a form of Gaussian elimination on the originally orientated matrix
Start state:
Exponents (corresponding to powers of 2, 17, 23 and 29, for 29, 782 and 22678)
\begin{pmatrix}
0 & 0 & 0 & 1\\
1 & 1 & 1 & 0\\
1 & 1 & 1 & 1\\
\end{pmatrix}
Row-sum tracker (initially identity matrix)
\begin{pmatrix}
1 & 0 & 0 \\
0 & 1 & 0 \\
0 & 0 & 1 \\
\end{pmatrix}
Find non-zero entry for row 1 @ column 4, xor to lower rows with non-zero column 4:
\begin{pmatrix}
0 & 0 & 0 & 1\\
1 & 1 & 1 & 0\\
1 & 1 & 1 & 0\\
\end{pmatrix}
\begin{pmatrix}
1 & 0 & 0 \\
0 & 1 & 0 \\
1 & 0 & 1 \\
\end{pmatrix}
Find non-zero entry for row 2 @ column 1, xor to lower rows with non-zero column 1:
\begin{pmatrix}
0 & 0 & 0 & 1\\
1 & 1 & 1 & 0\\
0 & 0 & 0 & 0\\
\end{pmatrix}
\begin{pmatrix}
1 & 0 & 0 \\
0 & 1 & 0 \\
1 & 1 & 1 \\
\end{pmatrix}
Find only zero entries for row 3, read combination rows from tracking matrix for result
\begin{pmatrix}
1 & 1 & 1 \\
\end{pmatrix}
which implies that all three smooth values multiplied together will satisfy the conditions.
For additional trials you might like to use 559423, 6378971 and 7171537
Thanks a lot Joffan! One question, when conducting the special Gaussian elimination, do you not need to eliminate the value you are currently using as a pivot once all lower rows have been XOR'd?
No, I think that would be confusing. As it stands, each row of the tracker matrix indicates the combination of rows in the original exponent-mod-2 matrix that was used for that row of the modified matrix.
The final outcome is some all-zero rows. They're what we're after.
Thanks, do you also need to XOR for all values of 1 in a row or does it suffice to check for just the first one?
You XOR the whole row, but only for other rows that have a one in the pivot column. Unfortunately this example is really too small to see that, so I put a slightly larger (completely made-up) example below.
The first entry of one is just an arbitrary choice. Any entry of one will work, I was just keeping it easy to remember.
[itex] \begin{pmatrix}<br /> 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 \\ <br /> 1 & 1 & 0 & 1 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> 1 & 0 & 0 & 0 \\ <br /> \end{pmatrix} ||<br /> \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 0 \\ <br /> 0 & 0 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/itex]
[itex] \begin{pmatrix}<br /> 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 \\ <br /> 1 & 0 & 0 & 0 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> 1 & 0 & 0 & 0 \\ <br /> \end{pmatrix} ||<br /> \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 \\ <br /> 1 & 0 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 0 \\ <br /> 0 & 0 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/itex]
[itex] \begin{pmatrix}<br /> 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> \end{pmatrix} ||<br /> \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 \\ <br /> 1 & 1 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 0 \\ <br /> 0 & 1 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/itex]
[itex] \begin{pmatrix}<br /> 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 \\ <br /> 0 & 0 & 1 & 1 \\ <br /> 0 & 0 & 0 & 0 \\ <br /> 0 & 0 & 0 & 0 \\ <br /> \end{pmatrix} ||<br /> \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 \\ <br /> 1 & 1 & 1 & 0 & 0 \\ <br /> 1 & 1 & 1 & 1 & 0 \\ <br /> 1 & 0 & 1 & 0 & 1 \\ <br /> \end{pmatrix}[/itex]
If it's not too much trouble, could you work through a full example? I'm having trouble getting my program to work correctly. Very few of the values it generates for all zero rows are squares, and when they are, they tend to not lead to factors once the GCD is calculated. I am using small test numbers too - up to 1000.
The values derived from all zero rows cannot be anything but squares. However sometimes (with small values, anyway) they may not give you the factors you are looking for, because the values derived are equal or sum to N.
Looking at 13987, and using the first six primes where that is a quadratic root: 2, 3, 7, 13, 17, 23, I get seven smooth numbers corresponding to numbers between 119 and 167: 122, 125, 127, 131, 134, 145 and 161, whose squares mod 13987 are 897, 1638, 2142, 3174, 3969, 7038, 11934, all of which are composed only of the above prime factors. I discarded 134 & 3969 because 3969 = 632 (a square, so not interesting for this exercise), giving the following factor exponent matrix:
\begin{pmatrix}
0 & 1 & 0 & 1 & 0 & 1 \\
1 & 2 & 1 & 1 & 0 & 0 \\
1 & 2 & 1 & 0 & 1 & 0 \\
1 & 1 & 0 & 0 & 0 & 2 \\
1 & 2 & 0 & 0 & 1 & 1 \\
1 & 3 & 0 & 1 & 1 & 0 \\
\end{pmatrix}
Reducing this matrix mod 2, the elimination goes as follows:
[tex]\begin{pmatrix}<br /> 0 & 1 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 & 0 & 0 \\ <br /> 1 & 0 & 1 & 0 & 1 & 0 \\ <br /> 1 & 1 & 0 & 0 & 0 & 0 \\ <br /> 1 & 0 & 0 & 0 & 1 & 1 \\ <br /> 1 & 1 & 0 & 1 & 1 & 0 \\ <br /> \end{pmatrix} || \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 0 & 1 & 0 \\ <br /> 0 & 0 & 0 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/tex]
xor row 1 to rows 4 and 6
[tex]\begin{pmatrix}<br /> 0 & 1 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 & 0 & 0 \\ <br /> 1 & 0 & 1 & 0 & 1 & 0 \\ <br /> 1 & 0 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 0 & 0 & 1 & 1 \\ <br /> 1 & 0 & 0 & 0 & 1 & 1 \\ <br /> \end{pmatrix} || \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 & 0 \\ <br /> 1 & 0 & 0 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 0 & 1 & 0 \\ <br /> 1 & 0 & 0 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/tex]
xor row 2 to rows 3,4,5,6
[tex]\begin{pmatrix}<br /> 0 & 1 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 1 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 & 1 \\ <br /> 0 & 0 & 1 & 1 & 1 & 1 \\ <br /> 0 & 0 & 1 & 1 & 1 & 1 \\ <br /> \end{pmatrix} || \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 1 & 0 & 0 & 0 \\ <br /> 1 & 1 & 0 & 1 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 1 & 0 \\ <br /> 1 & 1 & 0 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/tex]
xor row 3 to rows 5 & 6
[tex]\begin{pmatrix}<br /> 0 & 1 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 1 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 & 1 \\ <br /> 0 & 0 & 1 & 0 & 0 & 1 \\ <br /> 0 & 0 & 1 & 0 & 0 & 1 \\ <br /> \end{pmatrix} || \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 1 & 0 & 0 & 0 \\ <br /> 1 & 1 & 0 & 1 & 0 & 0 \\ <br /> 0 & 0 & 1 & 0 & 1 & 0 \\ <br /> 1 & 0 & 1 & 0 & 0 & 1 \\ <br /> \end{pmatrix}[/tex]
xor row 4 to rows 5 & 6
[tex]\begin{pmatrix}<br /> 0 & 1 & 0 & 1 & 0 & 1 \\ <br /> 1 & 0 & 1 & 1 & 0 & 0 \\ <br /> 0 & 0 & 0 & 1 & 1 & 0 \\ <br /> 0 & 0 & 1 & 0 & 0 & 1 \\ <br /> 0 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 0 & 0 & 0 & 0 & 0 \\ <br /> \end{pmatrix} || \begin{pmatrix}<br /> 1 & 0 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 0 & 0 & 0 & 0 \\ <br /> 0 & 1 & 1 & 0 & 0 & 0 \\ <br /> 1 & 1 & 0 & 1 & 0 & 0 \\ <br /> 1 & 1 & 1 & 1 & 1 & 0 \\ <br /> 0 & 1 & 1 & 1 & 0 & 1 \\ <br /> \end{pmatrix}[/tex]
This gives us two all-zero rows and hence two solutions (which both work): combine the first five numbers, or combine the 2nd, 3rd, 4th and 6th (reading from the corresponding rows of the tracker). This means going back to the original factor exponents above - the mod-2 matrix shouldn't be used for the final calculation.
So taking the first of these, 811 == (122*125*127*131*145) mod 13987 and 897*1638*2142*3174*7038*11934 is a square whose root 265149612 == 12040 mod 13987.
GCD(13987,12040-811) = 197
GCD(13987,12040+811) = 71
Thanks! It's now at least working! :) Is there any documentation you can refer me to for choosing good values for the size of the sieve and what to use as β for the smoothness bound?
Again, much appreciated.
Also, I am now trying numbers > 20 digits long and the method seems to have broken down as the matrix doesn't produce 0 rows anymore. I think this is down to do with having more columns than rows
Yep. You need more rows than columns to be sure of getting a zero row, and it's better to get several. So just keep sieving until you have enough candidates. While I'm sure there will be some guidance out there, the discussion of polynomial forms in Wikipedia suggests that straight prime searches of the type we've been doing here won't be sufficient (or not efficient, anyway) for large numbers.
I don't know enough about the subject to recommend anything at high numbers. Pomerance's 1996 paper http://www.ams.org/notices/199612/pomerance.pdf (from Wikipedia) is readable and give some additional references.
I neglected to mention that the 134/3969 combo in my example, while not illustrating the elimination phase, is actually the most direct route to the answer, so would be very interesting if encountered in a real factoring problem.
ETA: http://www.cs.virginia.edu/crab/QFS_Simple.pdf seems good.
15K
