Calculating real power and power factor
The discussion revolves around calculating real power and power factor in AC circuits using circuit voltage and current measurements from a current transformer (CT). Participants explore theoretical concepts, practical applications, and measurement techniques related to power calculations in electrical systems.
  • One participant expresses uncertainty about calculating real power without knowing the circuit resistance, suggesting formulas involving apparent power and power factor.
  • Another participant explains that real power is dissipated only in resistive components and that reactive components do not contribute to power dissipation, introducing the concept of power factor.
  • A different viewpoint presents real power as the dot product of voltage and current phasors, indicating that this method does not require knowledge of resistance or power factor directly.
  • Several participants discuss the relationship between real power, apparent power, and power factor, with one participant seeking to measure total energy consumption and power factor across multiple circuits.
  • There is a mention of using phasors to describe AC, with some participants expressing a desire to understand this concept further.
  • One participant raises a question about how to find instantaneous voltage and current, suggesting the use of an industrial controller for measurements.
Participants do not reach a consensus on the best method for calculating real power and power factor, with multiple competing views and approaches presented throughout the discussion.
Participants express various assumptions about the relationships between voltage, current, and power, and there are unresolved questions regarding the practical implementation of measurements and calculations.
Individuals interested in electrical engineering, power systems, and those looking to understand the nuances of power calculations in AC circuits may find this discussion beneficial.
pmn
I have been trying to understand how to calculate real power and power factor in an AC circuit when given only circuit voltage and real/true current as measured by a current transformer (CT).
What I (think I) know:
1. Real power P = I^2 * R (but I don't know the circuit resistance)
2. Real power = apparent power * power factor
3. Apparent power S = RMS source voltage * RMS current
I believe I can take (source voltage ) / √2 to get the RMS of the voltage then (measured amperage) / √2 to get the RMS of the amperage and can then calculate the apparent power as the product of those two values but I don't know how to get to real power and power factor from there.
Thanks for any direction you can give me!
Phil
Are you familiar with the idea that power is only dissipated in resistance.?
And that no power is dissipated in reactive components (inductance and capacitance)?
If the supply voltage is out of phase with the current in a series circuit then the power dissipated = voltage across R x current
The voltage across R = supply voltage x Cos θ
Cosθ is known as the power factor.
The disadvantage of having the supply voltage out of phase with the current is that a voltage,
V, is being generated but only a fraction (VCosθ) is delivering power
'Real Power' is V.I (the dot product of the two phasors) or VI cos (phase).
You can measure it by putting the V and I waveforms into an analogue (four quadrant) multiplier and then an leaky integrator / Low Pass filter meter. This will multiply the instantaneous values of V and I, which is instantaneous power. The value of this will vary and always be greater than zero (and corresponds to I^2R). When you take the mean of this, you will get the average power.
This way, you neither need to know the Resistance nor the Power Factor (you are including it in the cos(phase) term.
I assume that those things the Gas Board supply you with do it this way. There's a current transformer on the consumer meter lead and a wireless link to the unit, which is mains powered and measures the voltage.
Your formula will tell you the power transferred in the resistor (natch) but, as you say, you need to know the value of resistance.
Thanks for the replies! I get the concept of reactive power being a function of a shifting of the voltage / current phases. (Thus a power factor of 1 means that the voltage and current rise in unison, correct? Inductance or capacitance in the circuit cause the two waves to become out of phase?) I don't get the statement "'Real Power' is V.I (the dot product of the two phasors) or VI cos (phase)". I do get "which is instantaneous power. The value of this will vary and always be greater than zero (and corresponds to I^2R)".
Since I believe that I can calculate apparent power as Vrms * Irms (where rms is a/√2 and a=peak value), and real power can be derived from an instantaneous measurement of voltage and amperage, then power factor can be calculated as real / apparent?
Ultimately I want to be able to put CTs on incoming mains power and several branch circuits as well as measure the voltage on the circuits and be able to make some statement about how much energy is being consumed in total (mains) and by each branch circuit as well as how close I am to a PF of one.
The dot product is just 'vector speak' and takes you further into the business if you're interested. Have you not heard of using Phasors to describe AC?
This is great stuff as a thought experiment but all this stuff is readily available to buy. Furthermore, it is 'Electrically Safe'.
btw, how were you proposing to find the instantaneous V and I?
Short answer is 'no' but... I understand the vectors in the 'AC triangle' showing the relationships to real, apparent and reactive power. I will dig in a little to understand phasors.
Readily available to buy as in 'purchase a Fluke power quality meter'? :-) I am enjoying the exercise at the moment but at times of weakness I do admit to browsing the Fluke website and lusting over their tools.
Using an industrial controller to sample the line voltage and real current via CT. I believe I could probably make a reasonable calculation of the power factor by simply timing the (V)peak to (A)peak. (I have a controller, I don't have a Fluke.)
  • · Replies 38 ·
  • · Replies 18 ·
