'floating' DC supply design needed
The discussion revolves around the design of a floating DC power supply for a digital panel meter intended for use on a boat. Participants explore various options for powering the meter using the boat's 12V system, while addressing specific voltage requirements and the need for isolation from the boat's ground.
  • One participant seeks a DC power supply that can provide 7 to 12V for a digital panel meter, expressing a preference for a solution that utilizes the boat's existing 12V power system.
  • Another participant suggests looking into DC-DC converters available from suppliers like Digikey, noting that some converters require a minimum input voltage of around 10.8V.
  • A third participant provides a link to a resource for DC-DC converters and discusses the possibility of using a lower voltage isolator combined with a three-terminal regulator to accommodate deep discharge scenarios.
  • One participant shares their experience with older LCD voltmeters that required a floating ground, contrasting them with newer models that do not have this requirement and providing links to specific products that operate within the desired voltage range.
  • Another participant mentions the current draw of the suggested meters and their limitations, such as the inability to measure negative voltages and the absence of mounting boxes.
  • A later reply indicates that the original poster has resolved their issue, although the specifics of the solution are not detailed.
Participants express varying opinions on the best approach to powering the meter, with no clear consensus on a single solution. Some participants highlight the advantages of newer meters over older models, while others focus on the technical aspects of DC-DC converters and power supply design.
Participants mention specific voltage requirements and the need for isolation, but do not resolve the implications of these requirements on the overall design. There is also a lack of clarity on the exact specifications of the power supply needed for the meter.
sophiecentaur
Homework Helper
I am going to put a digital panel meter on my boat to measure the battery volts and a few other things. For this, I need a DC power supply for the meter with a negative which is below the boat ground.
I could easily use a 9V battery and a push button to keep it on just for taking readings.
But it would be better and more satisfying to provide a supply, using the boat's 12V power. I have looked for something on the web which can give me 7 to 12V, which is what the meter needs but I only seem to find unsuitable voltages.
Has anyone any ideas, please, about a suitable chip for the job (I only need a few mA!)? I am a bit out of touch with this stuff and there must be plenty of solutions if only I could get to them.
Digikey carries a huge varety of this sort of DC-DC converters.
http://www.murata-ps.com/data/power/ncl/kdc_nke.pdf
some will operate right off 12 volt battery, but they tend to need around 10.8 volts minimum.
"""something on the web which can give me 7 to 12V, """
is that what you want to hand the meter for power, or the range you want to track battery?
a lower volt isolator and 3 terminal regulator would let it follow the battery clear down into deep discharge..
Thanks for those posts, chaps.
There is a fair bit of choice there, altogether.
I'll see how I get on with the mini project. It's a bit more hi tech than most of the varnishing, cabling and drilling I seem to be doing all the time! Electronics is pretty predictable most of the time- unlike the wind (or even the tide, actually).
""It's a bit more hi tech than most of the varnishing, cabling and drilling I seem to be doing all the time! ""
in S Florida i grew to like white teak and green bronze...
I like to show her I love her.
Older LCD voltmeters needed a power source that had a floating ground. I have one of these that works OK but it has remained unused for 20 years because of this peculiar power requirement.
You can get meters now that do not require this.
Just as an example, I have some of these :
http://www.ebay.com.au/itm/4-Digit-Digital-Panel-Voltmeter-0-33V-Red-LED-Voltmeter-/120751739881?pt=AU_B_I_Electrical_Test_Equipment&hash=item1c1d5d53e9
They are about 4.2 pounds delivered.
They run off any power source from 7 to 30 volts (so they probably use 5 volt regulators internally), and they measure from zero to 33 volts with 2 decimal place precision. Seem pretty accurate.
The power source and the measured voltage have to have the same ground. There are 3 wires that come out of the device, ground, measured voltage and positive power.
The measured voltage can be greater than the supply voltage.
They have a bright red display and take about 22 mA supply current, depending on the displayed digits.
Possible disadvantages are that they do not come with a mounting box and they can't measure negative voltages.
The same company have lots of other meters as well as a lot of cheap power supply modules.
You can get other meters that would be OK for a boat where the voltage should never go to zero:
http://www.ebay.co.uk/itm/Blue-LCD-Digital-Voltmeter-Battery-Monitor-Panel-Meter-/270911120283?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item3f138fa39b
This one works from 7 volts upwards. Looks easy to mount.
I'm fixed up now, thanks.
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 36 ·
